Reading: PLC Programming Projects for Beginners
Inst Tools > Blog > PLC Tutorials > PLC Programming Projects for Beginners
Programmable Logic Controllers are a cornerstone of modern industrial automation. Get the PLC programming projects for beginners.
Last updated: April 10, 2024 4:28 pm
PLC Tutorials Projects
10 Min Read
Programmable Logic Controllers (PLC) are a cornerstone of modern industrial automation, offering unmatched reliability and flexibility in controlling machinery and processes. If you’re an engineering student looking to delve into the world of industrial automation, PLC programming is a vital skill to acquire.
PLC Programming ProjectsConclusion
To help you navigate this domain, we have prepared a list of 100 PLC programming projects. These PLC projects range from beginner to advanced levels and cover various industrial scenarios.
  1. Start-Stop Control: Implement a basic start-stop control circuit for a motor.
  2. AND, OR, NOT Gates: Use PLC ladder logic to simulate basic logic gates.
  3. Forward-Reverse Motor Control: Implement control logic for forward and reverse motion of an electric motor.
  4. Traffic Signal Control: Program a PLC to control a basic traffic signal setup.
  5. Temperature Monitoring: Use a temperature sensor and a PLC to monitor and control temperature.
  6. Level Control System: Implement a liquid level control system using float switches.
  7. Digital Counter: Design a digital counter that counts objects passing on a conveyor belt.
  8. Batch Process Control: Implement a batch process control system to mix substances in defined quantities.
  9. Timer-based Automation: Use PLC timers to control a process based on time.
  10. Shift Register Operation: Implement shift register operations to track the movement of objects in a process.
  11. Speed Control of DC Motor: Use a PLC to control the speed of a DC motor through PWM.
  12. Emergency Shutdown: Design an emergency shutdown system for a process plant.
  13. Door Lock System: Create a security system for door lock control.
  14. Data Logging: Store sensor data in PLC memory for analysis.
  15. Pump Alternating Logic: Implement logic to alternate between pumps in a multi-pump setup.
  16. Lighting Control System: Automate the lighting system of a building.
  17. Hopper Feeding Control: Control the feeding mechanism of a hopper in a manufacturing process.
  18. Automatic Sorting System: Sort objects based on weight or size on a conveyor belt.
  19. Analog Signal Processing: Implement analog signal scaling and offset correction.
  20. Recipe Management: Store and manage different recipes for a batch process.
  21. Cyclic Operation of Valves: Automate the cyclic operation of valves for a process.
  22. SCADA Integration: Integrate a PLC with SCADA for remote control and monitoring.
  23. Drum Sequence Control: Implement a drum sequence in a conveyor system.
  24. Energy Meter Monitoring: Read and store energy meter data.
  25. OEE Calculation: Calculate Overall Equipment Efficiency for a manufacturing process.
  26. Machine Downtime Record: Track and log machine downtime.
  27. Fan Coil Unit Control: Implement control logic for a Fan Coil Unit in HVAC systems.
  28. Modbus Communication: Establish Modbus communication between a PLC and other equipment.
  29. Servo Motor Positioning: Control the position of a servo motor.
  30. Alarm Acknowledgment System: Create an alarm system that requires acknowledgment.
  31. Wind Turbine Control: Implement a control system for a small-scale wind turbine.
  32. Solar Tracking System: Use a PLC to automatically orient a solar panel towards the sun.
  33. VFD Control via PLC: Control a Variable Frequency Drive (VFD) using a PLC.
  34. CAN Bus Communication: Implement CAN bus communication with PLC.
  35. Automated Packaging System: Design a system for automated packaging of products.
  36. Vibration Monitoring: Monitor machine vibrations and trigger alarms if necessary.
  37. Phase Failure Detection: Detect the failure of phases in a three-phase system.
  38. Clock Synchronization: Synchronize PLC time with an external clock source.
  39. PLC to PLC Communication: Enable data sharing between two PLCs.
  40. Ethernet/IP Communication Setup: Establish Ethernet/IP communication for a PLC.
  41. Barcode Reader Integration: Integrate a barcode reader to scan and log product information.
  42. Water Treatment Plant Automation: Implement controls for a water treatment plant.
  43. Pick and Place Robot: Program a PLC to control a pick and place robotic arm.
  44. Multi-threading in PLC: Implement multiple tasks running in parallel.
  45. Security Access Control: Implement an RFID or card-based security access control system.
  46. PID Control Loop: Implement a PID control loop for temperature control.
  47. Sludge Density Control: Control the density of sludge in a water treatment process.
  48. Remote I/O Configuration: Set up remote I/O modules and communicate with them via a PLC.
  49. Automatic Drilling System: Implement an automated drilling system in a CNC machine.
  50. Power Factor Correction: Automate the correction of power factor in an electrical system.
  51. Email Notification System: Send email alerts based on process alarms.
  52. FIFO and LIFO Implementation: Implement FIFO and LIFO algorithms for material handling.
  53. Weighing Scale Integration: Integrate an industrial weighing scale with PLC.
  54. Automated Guided Vehicle (AGV) Control: Program a PLC to control an AGV.
  55. Database Connection: Connect a PLC to a SQL database for data storage.
  56. Product Traceability System: Create a system to trace the production history of products.
  57. Batch Counting System: Implement a batch counting system for pharmaceuticals.
  58. Pressure Control System: Control the pressure in a reactor vessel.
  59. Compressor Control: Automate the operation of a compressor in an HVAC system.
  60. Multi-pump Control System: Control multiple pumps in a water supply system.
  61. Encrypted Data Transmission: Implement data encryption for secure communication.
  62. Redundancy Implementation: Design a system with redundant PLCs for high availability.
  63. Variable Area Flowmeter Control: Implement flow control using a variable area flowmeter.
  64. Oscillating Conveyor Control: Implement control logic for an oscillating conveyor system.
  65. Human-Machine Interface (HMI) Design: Develop an HMI for a specific process control.
  66. Automatic Defect Detection: Implement an automated system to detect defects in products.
  67. Elevator Control System: Program a PLC to control an elevator system.
  68. Optical Character Recognition (OCR): Integrate OCR to read labels or serial numbers.
  69. Automated Car Parking: Design an automated multi-level car parking system.
  70. Load Shedding Strategy: Implement an automatic load shedding system for an electrical grid.
  71. Vision System Integration: Integrate a machine vision system for quality control.
  72. Fuzzy Logic Control: Implement fuzzy logic control for an ambiguous control system.
  73. G-code Interpretation for CNC: Interpret G-codes to control a CNC machine via a PLC.
  74. Automated Agriculture System: Implement an automated irrigation and feeding system for agriculture.
  75. Clean-in-Place (CIP) System: Implement an automated cleaning process in food industries.
  76. Ethernet-Based Data Acquisition: Acquire data from various sensors over Ethernet.
  77. Fire Detection and Control: Implement a fire detection and control system in a building.
  78. Automated Test Bench: Create a test bench for automated testing of products.
  79. Hydraulic Press Control: Implement control logic for a hydraulic press.
  80. Condition-Based Maintenance: Implement predictive maintenance based on equipment condition.
  81. Automated Paint Mixing: Implement an automated paint mixing system.
  82. Vacuum Pump Control: Automate a vacuum pump in a chemical process.
  83. Zone-Based Heating Control: Implement zone-based heating control in a building.
  84. Material Transfer System: Automate the material transfer between different storage units.
  85. PLC Web Server: Host a web server on a PLC for remote monitoring.
  86. Adaptive Control System: Implement an adaptive control system that adjusts parameters dynamically.
  87. Automated Docking System: Implement a docking system for loading and unloading trucks.
  88. Temperature Gradient Control: Maintain a temperature gradient in a process vessel.
  89. Quality Inspection System: Implement an automated quality inspection system.
  90. CO2 Monitoring in Greenhouse: Implement CO2 level control in a greenhouse.
  91. RF Communication with PLC: Establish RF communication between a PLC and remote sensors.
  92. Automatic Voltage Regulator: Implement an automatic voltage regulator using a PLC.
  93. Fuel Level Monitoring in Vehicles: Implement a fuel level monitoring system for industrial vehicles.
  94. Boiler Control System: Implement controls for a steam boiler.
  95. Automated Fish Feeder: Implement an automated fish feeding system in aquaculture.
  96. Bluetooth Communication: Implement Bluetooth communication with a PLC.
  97. Real-Time Analytics Dashboard: Create a real-time analytics dashboard for process monitoring.
  98. Batch Coding Machine Control: Implement control logic for a batch coding machine.
  99. Surge Protection Control: Implement surge protection in an electrical system.
  100. Silo Filling and Emptying Control: Implement automated control for silo filling and emptying.
Learn PLC Programming in 7 Hours - Allen Bradley PLC Training Course
Conclusion
These 100 PLC programming projects cover a myriad of applications and complexity levels. These projects are designed to equip you with the practical knowledge you’ll need to excel in the world of industrial automation.
Siemens WinCC PLC HMI SCADA Complete Course
  • What is a Wet Contact?
  • Why 24 Volts DC Power Supply?
  • Interposing Relay Panel Wiring
  • Testing and Validation in PLC
  • Graphic Design in HMI SCADA
Split Range Control Application using PLC Ladder Logic
Allen Bradley PLC ControlLogix Hardware
PLC Automatic Pedal Switch for Speed Control
What is Siemens TDC? – Siemens Control System
What is Thin Client in SCADA? – Purpose, Advantages
What is a Dry Contact? – Basics of PLC Wiring
PLC based Automatic Packaging System
MOVE Instruction in PLC – What You Need to Know?
Best Practices of PLC Wiring – Programmable Logic Controller
Industrial Networking and Wireless Interview Questions
#10 PLC Best Practices – Assign Register Blocks by Function
ON Delay Timer using PLC
Omron PLC for Product Painting with Integrated Weighing System
Siemens PLC Organization Blocks used For Troubleshooting
Tia Portal – OB121 Programming Errors Interrupt Organization Block
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Distributed Control System Interview Questions
Garage Door Roller Shutter
Ladder Logic Example with Timers
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
DeMorgan's Theorems
DeMorgan’s Theorems using Ladder Diagram
What is Profibus
All About Fieldbus Protocols
Hydrogen and Glass Electrodes Questions & Answers
Rotameter
What is a Variable Area Flow Meter?
Hydrostatic Tank Gauging (HTG)
Control of the Effects of Disturbance Signals by Use of Feedback
IEC 60909 and IEC 61363 for Short Circuit
One Shot Rising PLC Example Program
Loop Diagram
15 Loop Diagram Questions
Automatic bending machine for exhaust pipe
PLC Logic for Automatic Bending Machine for Exhaust Pipe
