Reading: What is PCS 7?
Inst Tools > Blog > Control Systems > What is PCS 7?
What is PCS 7?
PCS 7 means a Process Control System is an integrated DCS control system developed by Siemens. It uses AS-400 (Automation System).
Last updated: March 4, 2021 11:26 am
Control Systems PLC Tutorials
5 Comments
3 Min Read
In this article, we will learn about PCS 7.
PCS 7 Control System LayoutSiemens PCS 7
PCS means a Process Control System is an integrated DCS control system developed by Siemens.
It uses a Siemens Simatic hardware platform and TIA software.
In DCS, the location of the processor, I/Os, and servers are distributed throughout the plant. You can not find any defined central location like PLC.
PCS 7 is a hybrid type controller means it has both characteristics of the DCS and a PLC.
It uses an s7-400 CPU. In DCS term it is called AS-400. AS stand for an automation system.
Like PLC has a module to connect field devices and different devices to communicate, DCS also contain device arrangement to communicate with other devices.
At the top level, it has a device like,
  • PC based engineering system
  • Operator system client
Both are connected with the operator system server via a communication cable.
The communication protocol may be ethernet or a PROFIBUS, which is Siemens standard communication protocol.
Now we know that the operating system and client and main engineering system which then connected via a communication protocol. This top-level connection is called a terminal bus.
The operator system server is connected to another connecting device normally an ethernet switch. This level is called a plant bus.
From the plant bus, the connection goes to an automation system which is a processor AS-400.
From the processor, it goes to the I/O module. Field devices connected to I/O modules.
The operator system server is used to send and receive graphical representation to the operator server-client (HMI).
The automation system is used to solve the logic, monitor, and control the field devices.
Siemens PCS 7
Below is a typical structure of the PCS 7 control system.
Siemens PCS 7
The basic PCS 7 includes AS-OS engineering station which is called a Simatic manager. This is a modified version of the step 7 software.
The operator system client is an HMI software is based on WinCC professional.
In addition to the engineering station, it covers a wide variety of software like,
  • Continuous and batch control
  • Material pathway control
  • Intelligent process device management
  • Enterprise-wide data connectivity
I hope you have an idea about PCS 7 software and its structure now.
Still, you have a question, then put your question down in the comment section.
Author: Suhel Patel
  • PLC Siemens Training
  • PLC Flexible IO Modules
  • Siemens Tia Portal PID
  • Siemens PLC Simulator
  • Pulse Generation Timer
Safety Door Interlock PLC Program
Allen Bradley PLC ControlLogix Hardware
#2 PLC Best Practices – Track Operating Modes
Communication between Factory IO and Siemens Tia Portal
Proportional Controller Principle
Boiler Drum Level Control Systems
5 Comments
  • Flávio Silveira Stefani says:
    August 15, 2020 at 8:00 pm
    Which communication protocol is most used for the Terminal Bus and Plant Bus network?
    • tianya3047 says:
      December 25, 2022 at 4:05 pm
      Terminal bus : TCP/IP Protocol
      Plant bus: ISO Protocol
  • Abid says:
    September 20, 2021 at 2:12 pm
    I understand PCS 7 but I have one question. PCS 7 have signal force option as other DCS have like ABB. Force option lead us to temporary force any signal and work done with out tripping
    • Syed Uzair Tausif says:
      November 18, 2021 at 7:56 am
      Yeah it has
  • Swaraj Kumar Jena says:
    October 31, 2022 at 1:44 am
    which networking topology is best for dcs ?
Types of Interrupt OB in Siemens Tia Portal
How to Backup and Restore from Simatic Prosave HMI?
Open User Communication in Siemens Tia Portal – PLC to PLC
How to Design an Effective HMI? – Human Machine Interface
ControlLogix Architecture – Rockwell Automation
Power Supply Sizing for Industrial Automation Systems
Structured Text PLC Programming for Two-Tanks Level Control
Structured Text PLC Programming for Two-Tanks Level Application
Comparison Instructions in PLC Programming
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
Selector Control Function in DCS
Selector Control Functions
Types of PLC
Can a PLC Function Without an HMI or SCADA
Can a PLC Function Without an HMI or SCADA?
Downloading Free PLC software
Step by Step Guidelines for Downloading Free PLC software
Omron PLC paper cutting machine automation
Automatic Paper Cutting Machine Using CX-Programmer
Dahlander Motor Control Circuit
Dahlander Motor Control Circuit and Power Circuit
Difference between Calibration and Ranging
Transmitter Questions
Practical Process Control System Questions & Answers – 4
What is Electrical Busbar
What is Electrical Busbar? Types, Advantages, Disadvantages
Thermoelectricity principle
Methods of Producing Voltage (Electricity)
PlantPAx Select Add components into Project
How to Import PlantPAx Library?
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Gas Holder Level Measurement
Measurements in Air and Fuel Circuit in Power Plant
