Reading: Under and Over-Capacity Control Valve Pose Poor Controllability
Inst Tools > Blog > Root Cause Analysis (RCA) > Under and Over-Capacity Control Valve Pose Poor Controllability
Instrumentation engineering root cause analysis (RCA) of under and over-capacity control valves pose poor controllability.
Last updated: September 28, 2022 3:02 pm
S Raghava Chari
2 Min Read
Under and Over Capacity Control ValveBenefits of the Solution
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Control Valves
Author:S. Raghava Chari
Two control valves posed problems (P) and the Author RCA solutions (S) are as under:
Problem:
Poor boiler drum level control because of just 15% open LCV 301
Solution:
Obviously poor controllability oversized control valve (CV).
Re-calibrate the 30-mm valve travel VP (valve positioner) for 20 mm travel and fix a new 20 mm marks scale.
Problem:
Even with exit PCV 213 full open, First Flash Separator pressure was > SP
Solution:
Obviously, control valve (CV) opening is insufficient;
Re-calibrate the valve positioner (VP) from 35 mm to 55 mm and fit a 55 mm marking scale
Excellent control, saved new valves purchase costs, and commissioning proceeding on schedule.
Author: S. Raghava Chari
  • Valve Positioners Failed
  • Errors and Faults in Siemens PLC
  • Repeat Failures of Letdown Valves
  • Pressure Taps Block Valves Leaks
  • Unstable & Drifting Values of Transmitter
Miscellaneous Electrical Tasks – Repaired Reformer Tubes Weld Stress Relief
High-pressure Service Level Transmitters Misunderstood Zero Drifts
Panel and Field Pneumatic Controller’ Bumpless Transfer Issues
Junction Box Internal Corrosion Problems and Solutions
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
NH3 Storage Tanks Ammonia Gas Venting Issue – Root Cause Analysis
Arc Fault Breaker (AFB) Electrical Problem Solved
Control Valve Passing Problem after Overhauling Job
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
None Could Repair Slightly Damaged Magnetic Flow Meter Flow Tube
Serious Constraints Prevent using an Available Turbine Flow Meter
Heat Exchanger Tubes Corroded Root Cause Analysis
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Supplied Screen Vibrators Perennial Problems
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
Plunger Pump
Within Few Weeks Failing Acid Dozing Pumps
Surface Condenser Condensate Evacuation Pumps
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
Fan Motor Frequent Journal Bearing Failures
Fan Motor Frequent Journal Bearing Failures Posed Plant Outages
Packing Compressing Die Set
Carbamate Plunger Pump Packing Problems Eliminated
Flash Vessel All Level Instruments Stopped Working
Ammonia Flash Vessel All Level Instruments Stopped Working
Root Cause Analysis on Hunting of Control Valves
Kalrez O-ring seal
How Kalrez O-rings Seal So effectively So Long?
Split Range in Foundation Fieldbus
Foundation Fieldbus Split Range Valves
SCADA
Top 100+ SCADA Questions
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
Bias in Proportional Controller
Why Bias used in Proportional Controller ?
DP Diaphragm Capillary Seal Level instrument
DP Diaphragm Capillary Seal Level instrument Calibration Procedure
What is HIPPS System in Oil and Gas
What is HIPPS System in Oil and Gas?
