Root Cause Analysis (RCA): Seawater pipeline spools from day-1 leaks threaten NH3 plant indefinite shutdown.
| Category: | Mechanical |
| Equipment Type: | Pipelines and Miscellaneous Problems |
RCA Queries and answers
Why do the final spools only leak and not the rest of the seawater pipelines?
The spools that came from Japan did not fit due to excessive axial and lateral offsets between the surface condenser nozzles and the concrete floor buried pipes vertical legs connected to the nozzles.
Hence, the erectors bolted the cut flanges from the spools to condenser flanges, adapted the pipes to match the flanges, and welded these in-situ.
Then they removed the damaged lining and rush epoxy-coated the bores to meet the start-up deadline. Perhaps the rushly done epoxy coatings are inadequate. Hence, the spools only leak!
Seawater Pipeline Spools Leaks Problem
CLs’ severe lateral and axial misalignments mentioned above, precludes spools prefabrication, lining, and replacing finished spools at convenient schedules.
A week of constant thinking flashed an answer to the author He stopped the 3.5 bar pressure seawater 6-10 dia jets by driving wooden taper plugs epoxy sealed them.
Then welded longitudinally split two halves of the next larger sized pipe as a jacket (below fig). Molten asphalt fill in the annular space serves as an in‑situ jacket bore seawater corrosion even in case the entire original pipe corrodes away.
Crew jacketed the entire 42 Nos. of spools working general shift hours only.
Non-amenability to prefabrication made spools replacement impractical during the plant’s 15‑day turnaround (TA) 30-months hence.
Again, another innovation – cement lining the spools solved the problem; with two bonus benefits viz. low costs, and stronger adherence to even corroded rough surfaces. Rubber or other linings require new spools of sandblast cleaned smooth surfaces.
The innovative solution benefits
Below listed are the innovative solution benefits
- It averted rush total unplanned shutdowns from potential heavy spool leaks effectively, safely and inexpensively
- Cement lined spools last forever
- The debuting company met the export orders in time and earned a good name as a reliable ammonia supplier and a decent profit too. The cement-lined spools were performing well when the author retired from the plant several years hence.
Author: S. Raghava Chari
- Leaking Plug Valves
- Flange Joint Problems
- Pipe Elbow Sudden Burst
- Fan Motor Journal Bearing Failures
- Fired Boiler Induced Draft Fan Failures
