Reading: Seal Pressure Instruments Root Cause Analysis
Inst Tools > Blog > Root Cause Analysis (RCA) > Seal Pressure Instruments Root Cause Analysis
Instrumentation engineering root cause analysis of seal pressure instruments, gauges, transmitter, switches, and DP transmitters.
Last updated: October 17, 2023 1:57 pm
S Raghava Chari
12 Min Read
Why use Seal Pressure Instruments (SPI)?Body Type SealsSeal ProblemsAuthor’ tried SolutionsPinholes PreventionDiaphragm Replacement AttemptsEvacuation and Oil Filling the AssemblyCalibrate the assembly on a Dead Weight TesterNo Diaphragm Seal Instruments (NDSI)Body type No-Diaphragm Seals for Vertical PipelinesFlanged SealsPiston No-Diaphragm Seals (PNDS)Advantages of Piston No-Diaphragm Seals
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Sensors
Author:S. Raghava Chari
The abbreviation SPI covers Seal Pressure Gauges (PG), Pressure Transmitter (PT) and Pressure Switches (PS) and SDPT for Seal Differential Pressure Flow and Level Transmitters.
Body Type Seals (BTS fig 2) common for pipeline flowing ambient temp congealing liquids pressure measuring and flanged seals (FS fig 3) fitted SPI for vessels. Few such liquids examples are coal tar, molten sulfur, urea melt etc.
Such liquids stagnating in the process leads to the instruments attain ambient temperatures and solidify. Hence the instruments don’t read. Hence, the seals.
Seal details follow:
Body Seal of Pressure Instrument
Figure 1
Body Type Seals
A BTS (fig 2) consists of seal body with a factory welded 0.015 mm thick diaphragm (D).  A PG or other PI either directly screws on to seal body (SB) top, or capillary connects to it.  BTSs of process compatible materials are available.
The factory evacuates the assembly and fills with silicone or other oils. SB bolts on welded to pipeline weldolet (W).
Suitable gasket e.g. serrated 3 mm thick SS 316 ring makes the installation leak tight.Field crew bolts the BTS to W with factory supplied special high tensile Allen screws. Commercial studs and nuts are unsuitable
Fig 2 shows that the seal body extends into the pipe bore, where hot flowing process liquid always remains liquid and hence exerts pressure on the diaphragm.
The oil fill communicates the line pressure to the top mounted PI/PG/PS for reliable and failure free readings.
Flange Seal of Pressure Instrument
Figure 2
On the other hand, had we installed the instrument conventionally, the liquid would stagnate in the lead to the instrument, eventually cool down to ambient temp, freeze the instrument would not read the pressure.
Flanged Seal (FS) (fig 3) essentially works the same way, a diaphragm welded to a 1” RF flange of process suitable rating and material replaces the SB and bolts to the pipeline short nozzle flange (fig 3)
Seal Problems
Though the seal instruments do fine in other Urea Processes, unfortunately they did not in a Total Recycle Process Urea Plant. The process engineers to whom I pointed out this did not take it seriously and apply their minds.
Faced problems are:
  1. Diaphragm pinholes appearing within few days use rendered the SPIs worthless
  2. Consequently the  connected to seal pressure instruments e.g. PI, PT, or PS and associated automatic control and alarm did not work
  3. No field repair possibilities
  4. In the absence isolating block valves, crew putting new instruments involves plant shutdowns (SD). Urea plant shutdowns and re-start are very difficult, time and efforts intensive. Hence, plant operation continued till an opportune SD.
  5. Such blind plant runs are risky
  6. Too high seal instrument costs and long delivery times aggravated the above problems, besides crippling the company financially
The author tried different solutions as mentioned below.
Pinholes Prevention
The SPIs with ½ mm thick PTFE barriers discs to prevent process fluid wetting the diaphragms calibrated well; however the diaphragms pinholes forming persisted as before; hence the problems too.
A. Diaphragm Sandwiched Between a PTFE Gasket and Seal Body Bottom Screwed Cover (Fig 3):
Diaphragm Sandwiched Between PTFE Gasket and Seal Body
Figure 3
This too shop calibrated well; however, the well wrench and cheater tightened screwed cover was so loose after calibration that crew hand unscrewed the cover.
Since, no other gasket is suitable the author discarded it.
B. Weld New Diaphragm to the Body
The author guided workshop crew successfully argon arc welded the thin diaphragm to SB’s as under:
  1. Reduce SB length by 3-mm at the diaphragm end, and weld edge prepare
  2. Make a 3-mm thick ring of OD = Seal body diaphragm end, ID = OD-16 and edge prepare
  3. Tightly vice grip the seal body exposing 30% periphery with diaphragm sandwiched between body and ring.
  4. Argon arc weld the exposed periphery; complete welding the entire periphery re-gripping the assembly few times.
  5. 100-200 mm WC pressure air leak test and correct
  6. Machine the weld flush with SB
  7. Screw in the PG/PT directly on SB to minimize the number of joints.
Connect the readied seal instrument as in fig 4 using 6-mm metal / nylon tubes. Close needle Valve V‑2 and open V‑1.
Start the pump. The initial rapid bubbling in the oil would reduce to 3‑5 bubbles / mt in about 1-minute.
Repaired SPI Vacuuming & Oil Filling
Figure 4
Otherwise, one or more leaky joints lets air in. Identify and correct. Hold 4-5 bubble rates for about 5 minutes. Evacuation is adequate Close V‑1 and open V-2. Atmospheric pressure oil fills the SPI completely.
Apply 50 mm air pressure via V-2 for double sure fill. Carefully disconnect FP and plug it taking care to avoid spill. Wipe and solvent clean plug area. Apply epoxy or other seal as abundant leak prevention measure.
This method of restoring the failed instruments saved over Rs. 10 million per annum by way of no purchase of numerous of new assemblies.
However, poor diaphragm lives still plagued the plant necessitating the Author inventing No Diaphragm Seal Instruments (NDSI) – the ultimate solution!
Below listed steps convert diaphragm seals into No Diaphragm Seals (NDS)
  1. Remove the failed diaphragm from the seal body (SB).
  2. Modify SB as in fig 5 for horizontal line pressure taps and as in fig 6 for vertical pipelines
  3. Fill condensate, via the instrument accepting
  4. ½” threaded port and screw the instrument to that port. This way gone are the fragile
  5. capillary connection and filling difficulties
  6. Bolt the NDSI to the W as before Initially the author filled oil despite the
‘new ideas objectors’ objections, that the oil would color the product urea and build market resistance. They had no answers to the author’s query what happens to the several tens of the feed CO2 compressor liters of lube oil / day that go into the reactor.
The NDSI worked fine and astounded everybody.
However, the author removed the finely working NDSI two months later for evaluation. Condensate fill surprised him.
An operator explained, “Sir, we condensate wash the pipelines before plant start and after plant shutdown (SD). The heavier condensate displaces the lighter oil; hence the condensate fill you see”.
The author complemented him and profusely thanked him. But for his clarification, the seen condensate fill would have bothered the author; it would have even delayed large scale SPI trials. He realized that in this case, urea melt / carbomate dissolves in the condensate till saturation.
The saturated solution does not congeal even at ambient temperature.  The fill conveys the hot process liquid exerted pressure to the PI/PT/PS/PS sensing element.
Hence, condensate fill is the best, as it satisfies the objectors and saves oil costs.
No Diaphragm Seal
Figure 5
SB modified according to fig 6 works fine. to the weldolet elbow facing up. Fill condensate via the elbow till it overflows. Screw in the PI/PT/PS.
Thus all PIs/PTs/PSs, indications, control, alarms and shutdowns lasted failure free forever;
The plant saved around Rs 10 million yearly (1980s figures) instrument import bills, avoided risky plant runs, enhanced plant safety and consequently operator morale, not expressible as money.
Vertical Pipes No Diaphragm Seal
Figure 6
Flanged Seals
Convert flanged seals into No Diaphragm Flanged Seals (NDFS) according to fig 7 to get rid of flanged seals problems. Fill condensate and screw in PI/PT/PS as in other seals.
Fill condensate, bolt the NDFS instrument assembly to vessel nozzle flange as before, and enjoy years of trouble-free services.
Figure 7
(Fig 8): while writing this article the below described PNDS flashed to the author:
Remove the pinholes developed diaphragm from seal body and modify according to fig 8.
Machine SS piston for 0.5 mm clearance with the 0.4µm RMS smooth finished bore and fit PTFE filled rope packing in the piston groove.
Fill viscous oil above piston. Screw in PI/PT/PS/PG to the seal body. Piston seal instrument is ready for use.
Readers can make flanged PNDS also along these lines.
Piston No-Diaphragm Seal Instrument
Figure 8
Piston No-Diaphragm Seals (PNDS) foreseen advantages as follows:
  1. Diaphragm and its consequent problems are absent.  Hence, a really fit and forget device
  2. Minimum easy modification for both body and flange seal of horizontal and vertical pipelines
  3. Especially useful for applications where suitable Seal liquid is not available
Since, the author is no longer in service, he requests seal PI/PT/PS/PG problems overwhelmed readers to try out the piston seal and pass on feedback to him.
The author is sure of its success after identifying and removing ‘bugs’ if any seen.
Author: S. Raghava Chari
  • Actuator Diaphragm Bursts
  • Thermocouple Extension Leads
  • Pitot-tube Replaced with Orifice
  • Mechanical Temperature Indicator
  • Pressure Transmitter Stopped Working
Incident Investigation: Motor Operated Valve Lesson
Carbamate Plunger Pump Packing Problems Eliminated
Too Low-Temperature Readings after a Failed Thermocouple Change
Lessons Learned from Actuator Passing Incidents
Cooling Tower Fans Frequently Failing
Flanged Rotameter Caused Pipe Weld Cracks and Gives Wrong Readings
Repeat Control Valve Plug Stem and Gland Leaks
Heat Exchanger Root Cause Analysis (RCA)
Urea Reactor Top Bolted Plug developed Leaks
Steam Letdown Station Problems and their Solutions
Control Valve Passing Problem after Overhauling Job
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Bolted to Vessel Flange Displacer Level Transmitter
Seal Level Differential Pressure Transmitter Problems
Rupture Disc
Rupture Discs bursts caused too many Urea Plant Shutdowns
Under and Over-Capacity Control Valve
Under and Over-Capacity Control Valve Pose Poor Controllability
Tilting Pad Bearing
repairs of welding cast refractory lined box over the hot spots
Too often done riskily repaired Roof Hot Spots eliminated forever
Lightning Arrester Bursts Problem
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Arc Fault Breaker (AFB) Electrical Problem Solved
Premature Arc Fault Breaker Failures
HT Motor Direction of Rotation (DOR)
HT Motor Direction of Rotation (DOR) Changed
Voltmeter Calibration
Calibration Procedure of Voltmeter and Ammeter
Types of Electrical Loads
Thermal Dispersion Flow Switch Working Principle
Guided Wave Radar Level Transmitter Compensation
Guided Wave Radar Level Sensor Pressure and Temperature Effects
Nonlinear Control Systems
Constructing Phase-Trajectories
PLC Programming for Sequential Batch Mixing System
Pressure Gauges with Zero Adjustment
Pressure Gauges Zero Adjustment
Remote Seals Transmitters Temperature Error
Remote Seal Transmitters Temperature Error
