Reading: Industrial Automation Engineers Interview Questions
Inst Tools > Blog > Instrumentation Interview Questions > Industrial Automation Engineers Interview Questions
Last updated: March 5, 2021 10:41 am
Instrumentation Interview Questions PLC Tutorials
5 Comments
16 Min Read
We prepared an article for industrial Automation Engineers Interview Questions and Answers.
Industrial Automation Engineers Interview Questions1. What is Automation?2. What are the different components used in automation?3. What are the different control systems used in Automation?4. Explain PID based control system.5. Difference between PLC & Relay ?6. Difference between PLC and DCS ?DCS:PLC:7. What is PC based control system ?8. What is Encoder ?9. Which are the leading PLC providers ?10. Which are the leading DCS providers ?11. Which are the leading SCADA software providers ?12. What types of sensors are used for measuring different parameters?13. What is transmitter?14. Why 4-20 mA preferred over 0-10 V signal ?15. Why 4-20 mA preferred over 0-20 mA signal ?16. Difference between 2 wire, 3 wire and 4 wire transmitter.17. What is a “Smart” Transmitter ?18. What is Field bus ?19. What is Actuator ?20. Explain Working of RTDs21. Temperature measurement range supported by RTDs?22. Explain Working of Thermocouple23. What is Cold Junction compensation?24. Temperature measurement range supported by thermocouple ?25. Can we split one T/C signal to two separate instruments?26. What are the flow measuring instruments used in Flow measurement ?27. Explain working of differential pressure measurement ?28. What are the components of differential flow sensor ?29. What type of pressure sensors used in pressure measurement?30. Explain working of differential pressure transmitters.31. What is Control Valves ?32. What type of control valves used in the industry ?33. What are the specifications of the control valve ?34. What are the components of control valve ?35. What is flow coefficient ?
Automation is delegation of human control functions to technical equipment for increasing productivity, better quality, reduced cost & increased in safety working conditions.
The components of automation system include
  • Sensors for sensing the input parameters (RTD, Thermocouple, Pressure, Flow, Level; etc)
  • Transmitters for transmitting the raw signal in electrical form
  • Control system which includes PLC, DCS & PID controllers
  • Output devices / actuators like drives, control valves.
  • PID Controller based control system
  • PLC based control system
  • DCS based Control system
  • PC Based automation system
PID (Proportional Integral Derivative) is the algorithm widely used in closed loop control.
The PID controller takes care of closed loop control in plant. A number of PID controller with single or multiple loop can be taken on network.
PID Controllers are widely for independent loops. Although some logic can be implemented but not much of sequential logic can be implemented in PIDs.
  • PLC can be programmed whereas a relay cannot.
  • PLC works for analog I/Os such as PID loops etc. whereas a relay cannot
  • PLC is much more advanced as compared to relay.
  • Modifications in relay base circuit is difficult compared to PLCs
DCS:
The system uses multiple processors, has a central database and the functionality is distributed. That is the controller sub system performs the control functions, the history node connects the data, the IMS node gives reports, the operator station gives a good HMI, the engineering station allows engineering changes to be made.
PLC:
The system has processor & I/O’s and some functional units like basic modules, communication modules and so on. Uses a SCADA for visualization. Generally the SCADA does not use a central database.
DCS is often used in the big plants where the redundancy level needed is more and the analog input used are high.
In PC based control system, the CPU of computer acts as processor, the PCI based cards are used for connecting Input and Output. The RAM acts as memory. Hard disk is used as storage device.
Currently this systems are very useful when the large data is to be proceed with very high speed. In many cases for greater accuracy we can use the real-time operating system.
A feedback device which converts mechanical motion into electronic signals. Usually an encoder is a rotary device that outputs digital pulses which correspond to incremental angular motion.
The encoder consists of a glass or metal wheel with alternating clear and opaque stripes that are detected by optical sensors to produce the digital outputs.
The leading PLC providers include
  • Rockwell Automation : Allen Bradley (Micrologix, SLC, PLC, Control Logix)
  • Siemens ( S7 200, S7 300 , S7 400)
  • Grouppe Schneider : Modicon ( Nano, Micro, Premium, Quantum)
  • GE Fanuc : Versa, Series 90-30, 90-70
  • Messung : Nextgen
The leading DCS providers include
  • Yokogawa : Centum VP, CS 3000 , CS 5000 (Earlier Centum Excel, Micro Excel)
  • Honeywell : TDC 3000
  • Fisher – Rosemant – Delta V
  • ABB – Freelance 2000
  • Moore – APACS
  • Fox boro – I/A series
The leading SCADA software / MMI providers include
  • Wonderware : InTouch
  • Intellution iFix (Earlier FixDMACS)
  • Siemens : WinCC
  • Allen Bradley : RS View ( Earlier Control View)
  • KPIT : Astra
  • Temperature sensors – RTD, Thermocouple, Thermister
  • Pressure Sensor – Borden Tube, Bellows, Strain gauge
  • Flow sensor – Pitot tube, Orifice, Ultrasonic+
  • Level, Conductivity, Density, Ph
A transmitter is an electronic device that is generally mounted in the field in close proximity to a sensor. The sensor (also known as a transducer) measures a physical variable such as temperature or pressure and outputs a very low level electronic signal.
The basic function of the transmitter is to provide the correct electrical power to turn on (or excite) the sensor then to read the low level sensor signal, amplify it to a higher level electrical signal and send that signal a long distance to a control or read-out device.
Since low-level electrical signals do not transmit long distances with great accuracy, installing a transmitter generally gives a tremendous improvement in the accuracy of the information delivered to a larger control system. Typically the output form the transmitter is 4-20 mA or 0-10 V
The 0-10 V signal has tendency to drop because of line resistance. If the distance between sensor and input card is more the signal will not properly represent the field value.
The 4-20 mA will travel a long distance without dropping signal value.
With 0- 20 mA you can not distinguish between minimum field value and connection break. With 4-20 mA, internal circuit can distinguish between connection break of minimum value.
Normally when the value is minimum the transmitter will give you 4 mA while in case of connection breakage it will give 0 mA.
In 2 wire transmitter the power and signal are transmitted through same cable.
In 3 wire transmitter the data signal and power are with respect to common ground.
In 4 wire transmitter two wires for power supply and two for signals. Only current transmitters can be used as 2 wire transmitters.
A “Smart” transmitter is a transmitter that uses a microprocessor as the heart of the electronics.
In addition, a “Smart” transmitter will output some type of remote digital communications allowing you to read and set-up the device from a remote position.
Fieldbus is a general term for a digital only, high speed communications protocol. The key attribute to Fieldbus communications is higher speed communications with the possibility of addressing multiple transmitters all on the same field wiring.
The Foundation Fieldbus is a specific digital protocol that is often shortened to just be called Fieldbus. Other digital only communications such as Profibus are also Fieldbus protocols
In a closed-loop control system, the part of the final control element that translates the control signal into action by the control device.
An actuator is a component of a machine that is responsible for moving or controlling a mechanism or system.
An actuator requires a control signal and a source of energy. The control signal is relatively low energy and may be electric voltage or current, pneumatic or hydraulic pressure, or even human power.
Resistance Temperature Device works on the principles that the resistance of the material changes as its temperature changes.
Temperature is determined by measuring resistance and then using the RTD Resistance vs Temp characteristic to detect temperature.
Typical elements used for RTD are Nickel, Copper and Platinum. Platinum is widely used in RTDs because of accuracy.
PT 100 means at 0 deg temp 100 ohms resistance. A typical RTD consists of a fine platinum wire wrapped around a mandrel and covered with a protective coating (glass or ceramic).
The RTD work on temperature range between–250 to 850 deg C.
Thermocouple consists of two strips or wires made up of different metals and joined at one end. The temperature at that juncture induces an electromotive force (emf) between the other ends.
As the temperature goes up the emf also increases. Through standard charts and tables the corresponding temperature can be found out.
The relationship between the thermocouple output and the temperature is quite non linear.
Different metallurgies produce different outputs. The different metallurgies and different lineararities result in different thermocouple designations such as “J”, “K,”, “N”, “L”, etc.
The industry accepted standard for the temperature at open end is 0 deg C.
Therefore most tables and chart make the assumption that the temp at open end is 0 deg C. In industry the open ends are always at actual room temperature and not 0 deg C.
The emf adjustment because of difference between the actual temp and 0 deg C is referred as Cold Junction Correction (CJ Correction)
The thermocouple work on broad temperature range ie –270 to 2300.
No. The T/C signal is a very low-level millivolt signal, and should only be connected to one device.
Splitting to two devices may result in bad readings or loss of signal.
The solution is to use a “dual” T/C probe, or convert one T/C output to a 4-20 mA signal by using a transmitter or signal conditioner; then the new signal can be sent to more than one instrument
  • Differential pressure meters
  • Positive displacement
  • Velocity meters
Suitable restriction placed in flow stream causes a differential pressure across it.
As flow depends upon differential pressure (Head) & area, so any of them or both can be varied for varying flow.
For creating differential pressure : Orifice plate, Venturi Tube, Flow Nozzle , pitot tube
For measuring pressure : U-Tube Manometers, Ring–Balance Manometer, D.P. Cell
  • Manometers
  • Bourdon tubes
  • Bellow elements
  • Diaphragm elements
  • DP transmitters
Process pressure is transmitted through isolating diaphragms and oil fill fluid to a sensing diaphragm. The sensing diaphragm is a stretched spring element that deflects in response to differential pressure across it.
The displacement of the sensing diaphragm, a maximum deflection of0.004 inch (0.10 mm), is proportional to the applied pressure.
Capacitor plates on both sides of the sensing diaphragm detect the position of the diaphragm.
The transmitter electronics convert the differential capacitance between the sensing diaphragm and the capacitor plates into a two- wire, 4-20 mA dc signal and a digital output signal.
The control valve, commonly named the final control element of control contains a pneumatic device that converts the control signal from the controller in action, regulating the flow.
A control valve is a valve used to control fluid flow by varying the size of the flow passage as directed by a signal from a controller.
This enables the direct control of flow rate and the consequential control of process quantities such as pressure, temperature, and liquid level.
  • ON – OFF SERVICES :- Gate, Ball, Diaphragm, Plug, Butterfly valves.
  • THROTTLING SERVICES :- Globe, Butterfly, Diaphragm, Pinch valves.
  • NON – REVERSE FLOW :- Check valves.
Following specifications are used for control valve
  • Flow medium and operating temperature
  • Flow rate kg/hr or Nm3/hr Max/Min/Normal
  • Inlet and Outlet pressure : kg/cm2 Max/Min/Normal
  • Max. allowable diff. Pressure : kg/cm2
  • Density of medium : kg/m3
  • Viscosity
  • Cv : Valve Flow Coefficient
  • Actuator, Body, Trim, Diaphragm, Diaphragm plate, Actuator stem
  • Actuator spring, Seat, Travel Indicator, Valve stem, Gaskets, Yoke, Hand wheel
It is the flow of water (G=1, T= 6 to 34 deg. C) through the valve at full lift in U.S gallon per minute with a pressure drop across the valve of 1 psi.
Control Systems MCQ
Flow Measurement MCQ
Digital Control Systems MCQ
Pressure Measurement MCQ
Temperature Measurement MCQ
PLC Program for Automatic Bottle Rejection System
What is NOR Flash Memory in PLC?
Main differences between Sinking and Sourcing Circuits
Questions on Thermocouple and Pyrometer
Produced Tags and Consumed Tags in Studio 5000
Playground Swing Logic Exercise Program in PLC
5 Comments
  • Akshay P.Sorathiya says:
    January 26, 2017 at 4:13 pm
    Really very very good knowledge shared, appreciate it ……
    It’s much importanant n useful…
    You done a great job ..
    Thank you ??
  • Mohammed says:
    January 26, 2017 at 9:45 pm
    Thanks very much …so interesting
  • MVR SURYACHANDRA says:
    January 26, 2017 at 11:59 pm
    Dear Sir,
    I have few queries related to Vibration.Could u pls find below and acknowledge those:
    1) Vibration probe was set at -10 V DC at Steam turbine, why -10 V & also negative DC voltage?
    2) -10V is the gap voltage between Probe tip & rotating surface. Could u pls send any formula for vibration calculation?
    3) If we remove the probe outside, how much vibration we will get?
    4 how much vibration for below or above -10V DC, how to calculate?
  • S Bharadwaj Reddy says:
    March 5, 2019 at 4:17 pm
    Check this article. Negative Voltage for Vibration Probes ?
  • Ekari Chiwaya says:
    February 17, 2023 at 1:28 am
    This is a good refresher
PLC Timer Instructions
#11 PLC Best Practices – Instrument for Plausibility Checks
PLC Based Industrial Conveyor Ladder Logic
RSLogix5000 PLC Program Backup procedure
What is Trace Function in Tia Portal?
PLC Program for Food Processing Industry
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
PLC Ladder Diagram program
Contacts and Coils in PLC Ladder Logic
4-20mA Current Loop Components
Why Use a Current Loop?
Difference Between Microcontroller and PLC
Cybersecurity in PLC
Switch NO or NC Contact
Normally-open and Normally-closed Switch Contacts
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
PLC Program Backup in Siemens Tia Portal
How to Take Program Backup from Physical PLC? – Siemens PLC
Electric Open Circuit
Series Open Circuit Faults
Electrical and Instrument Engineers Job Profile
Instrumentation and Electrical Teams Interactions (Detail Design Engineering)
Split Range in Foundation Fieldbus
Foundation Fieldbus Split Range Valves
Electrical Voltage and current Signals
Bio Sensors Objective Questions
Difference between Electron and Proton
bimetallic thermometer working principle
Different Types of Thermometers
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
