Reading: Wiring in a PLC Control Panel
Inst Tools > Blog > PLC Tutorials > Wiring in a PLC Control Panel
In this article, you will learn the wiring in a PLC control panel and the basic electrical design of a PLC system cabinet.
Last updated: August 11, 2023 10:36 am
2 Comments
8 Min Read
Wiring in PLCMain Breaker SwitchBusbarCircuit BreakersSMPSDigital InputsDigital OutputsAnalog Inputs and OutputsTerminal Boards
Wiring in a PLC control panel is a hectic job and requires a good understanding of PLC standards as well as electrical standards.
Basically, before PLC was being started to be used in the market, wiring was the only method to provide control of a system.
Wiring interlocks need a good understanding of the logic to be implemented as well as the electrical standards that need to be implemented to fulfill it. So, it is said the one who is a master in designing and understanding electrical wiring logic and interlock can easily write a PLC logic too.
In this post, we will see how to design a PLC system cabinet. In simpler terms, consider that you are wiring an electrical PLC panel.
Wiring in PLC
Refer to the below image. We will consider a simple panel here, with all the basic electrical components.
The PLC panel consists of the main breaker switch, bus bar, circuit breakers, relays, contactors, PLC, fuses, SMPS, terminal boards, utility sockets, and earthing points.
Wiring in PLC System
Main Breaker Switch
Let us start with the main breaker switch. This is the point where the main power supply (3 phases) is connected (R, Y, B, N). It is this point that supplies power to all the components.
Install the breaker in such a way that the wireman gets a free hand to do the wiring; because any lag in it can damage the whole system.
Busbar
In the next step, connect the output of the main breaker switch to the busbar. The bus bar provides proper electrical distribution.
So, if there are many components in the panel which requires a single-phase supply or three-phase supply, then the bus bar is the most efficient step to do it.
Distribute all the points from here to the ones which require single phase or three phase supply. This will help you in easy and efficient power management.
You cannot just loop the three-phase wires to different components, as it is a wrong practice and can damage the wiring or the whole electrical panel in totality.
PLC Programming Tutorial for Beginners - Siemens PLC Training Course
Circuit Breakers
Now, suppose there are three circuit breakers in the panel. Connect the three phase wires from the bus bar to each of the circuit breaker inputs.
Individual circuit breakers will power individual contactors connected to their output. This will give proper output control to the contactors.
Because contactors have a control circuit that is controlled by the PLC; thus giving individual three-phase control too will give proper electrical control over the final output.
SMPS
Now, from the bus bar, connect one point to the SMPS. This will power it up and give DC output to the cabinet.
If the current rating of SMPS is higher, then you can use a distribution terminal board too for DC supply. This will properly segregate the DC supply to all the components requiring it. From this, power the PLC.
Now, after this, we will see how to wire the PLC IOs.
Difference between PLC and Computers
Digital Inputs
Firstly, take digital inputs. According to sink or source wiring, connect either 24V or 0V to the PLC common.
So, for example, if the common is 24V, connect 0V to all the respective PLC field inputs in the terminal board.
As one board has two pins, one will be used to provide 0V and the other will be connected to PLC digital input.
For safety, many use fuse terminal boards. This provides additional safety to the field devices.
Digital Outputs
Then, coming to digital outputs, the same sink and source theory applies to it.
So, for example, if the common is 24V, connect 0V and PLC digital outputs to all the relays (relay has two pins, so one pin will be 0V and the other pin will be PLC digital output).
According to the output you want at relay output (DC or AC), connect the wiring accordingly.
For example, if the relay output required is 230V AC, connect the line wire to the common and connect the NO wire to the contactor’s line input. Connect the neutral wire to the contactor’s neutral input and thus, the circuit is complete.
Now, whenever the relay turns on, that particular contactor will turn on and if its MCB is on, then the three-phase supply will be passed on to the final output.
Now, analog input and analog outputs will be directly routed through terminal boards with respect to PLC.
If possible, use fused terminal boards for additional safety.
Terminal Boards
Coming back to the contactors, the output is connected to terminal boards where you can connect your final output.
Note down some general points while designing a PLC panel:
  1. Have a good understanding of electrical ratings and standards, before choosing a component; for example, a contactor.
  2. Many times, fuses are connected after the mains breaker switch to protect the panel from any damage caused by the incoming three-phase supply. Also, transformers are used in many panels to step down a voltage according to the requirements.
  3. Fuses are also installed after SMPS for protecting PLC or other sensitive field devices.
  4. If three phase devices are used with earth points, ensure to provide separate earthing (power and instrument) in the panel. Do not mix them up.
  5. In this example, I have not shown terminal boards for PLC digital outputs; but even they are used normally in many applications. Because there can be valves in the system which require 24V DC, and such outputs require terminal wiring in the boards.
Many types of designs are possible in a PLC cabinet. You should know the basic requirements and have a fair idea of electrical wiring and PLC wiring, which will help in designing the panel properly.
PLC SCADA Full Course in 7 Hours - InTouch | Wonderware Online Training
  • UPS Working Principle
  • Electrical Wiring Diagram
  • 4-20 mA Transmitter Wiring
  • Why 24 Volts DC Power Supply?
  • Interposing Relay Panel Wiring
Scale and Normalize Instructions in PLC
Siemens PLC Tia Portal – OB100 Start-up Organization Block
PLC Programming using Level Switches
Function of Racks in PLC – Types of SIEMENS S7-400 PLC Racks
Function Block (FB) for Motor Control Logic
2 Comments
  • ANTHONY BOL BOL says:
    July 19, 2022 at 6:36 am
    I comment to learning different Electrical $ystem.
  • Stanley kipchirchir says:
    January 16, 2023 at 9:22 pm
    Am comment to learn and gain more knowledge partaining plc wiring
PLC Program for Mixing Tank
Different Types of Schneider PLC
Moving Data between PLCs – Siemens Basics – TSEND TRCV
Studio 5000: Define Program or Operator Control in Functional Block Diagram
PLC vs PAC – Understanding the Key Differences and Similarities
PLC Program for Entry and Exit Control of Car Parking
Forcing and Modifying PLC Logic
Gate Array Logic using PLC
PLC Program to Simulate Gate Array Logic
PLC Valve Control Example
Create a Function (FC) for a Valve Logic in Siemens PLC
How to Design a Motor Faceplate in Graphics - SCADA Tutorials
PLC Engineers Interview Questions
PLC SCADA Engineers Interview Questions and Answers
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
EasyBuilder Pro Weintek HMI Software
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
PLC Program for Temperature Control using Thermostat
Ladder Diagram Example using Memory Bits and Set Coils
Steam Letdown Station Problems
Steam Letdown Station Problems and their Solutions
Master Control Reset (MCR) ladder logic
How to use Master Control Reset (MCR) Instruction in PLC
Electric Motor Winding Temperature Sensors
light-emitting-diode-theory
Light Emitting Diode Operation
LIFO Instruction in Allen Bradley PLC Programming
LIFO Instruction in PLC
Single layer PCB
Step-by-Step Guide: How PCBs are Manufactured from Start to Finish
Digital Electronics Objective Questions – Set 9
PLC Program for Controlling Conveyors ON Sequence and OFF Sequence
PLC Program – Controls Conveyors ON and OFF Sequence
