Reading: Top 100+ SCADA Questions
Inst Tools > Blog > Instrumentation MCQ > Top 100+ SCADA Questions
Get answers to the top 100+ SCADA questions from the industrial automation and control systems.
Last updated: July 25, 2024 10:36 am
Instrumentation MCQ PLC Tutorials
44 Min Read
SCADA QuestionsWhat is a tag in SCADA?What are alarms in SCADA?What are trip signals in SCADA?What are trends in SCADA?What is a Historian in SCADA?What is a SCADA architecture?What is a SCADA master station?What is the function of a SCADA server?What is the role of an engineering workstation in SCADA?What is the role of OPC in SCADA?What is DDE (Dynamic Data Exchange) used in SCADA systems?How are setpoints configured in SCADA systems?What is the significance of a tag database in SCADA?What are the common data types used in SCADA tags?How is real-time data displayed in SCADA systems?What are the different types of SCADA architectures?What are the key components of a SCADA system in Electrical Substations?What is the role of a data concentrator in SCADA?What are the scripting languages commonly used in SCADA software?What are alarm thresholds and limits in SCADA?What are the typical network topologies used in SCADA systems?What is the importance of time synchronization in SCADA systems?What are the typical features of SCADA alarm systems?How are trends and historical data used in SCADA?How is data logging managed in SCADA?How does SCADA software support alarm management?Top Supervisory Control and Data Acquisition QuestionsWhat are the steps for commissioning a new SCADA system?How are alarms prioritized in SCADA systems?What is the role of an operator workstation in SCADA?How does SCADA software handle protocol conversion?What is the difference between SCADA and PLC?What are the common communication protocols used in SCADA systems?How does SCADA software integrate with PLCs?What are digital and analog tags in SCADA?How are custom scripts used in SCADA software?What are the typical use cases for scripting in SCADA?What are the steps for integrating new devices into a SCADA system?How do you perform system diagnostics and troubleshooting in SCADA software?What are the security features commonly implemented in SCADA software?How do you manage user roles and permissions in SCADA software?What is event logging in SCADA systems?What is report generation in SCADA software?How to perform system upgrades in SCADA without disrupting operations?How to configure and manage backup servers in SCADA?What is remote access in SCADA?How does SCADA software handle failover and disaster recovery?How does SCADA software handle version control?How does SCADA software handle configuration changes?What are the steps for performing a SCADA system audit?How do you manage historical data archiving in SCADA?What is network topology in SCADA?What is a batch process in SCADA?SCADA PLC MCQWhat is a communication link in SCADA?What is the function of a SCADA gateway?How do you manage firmware updates in SCADA systems?What is the role of APIs in SCADA software integration?How does SCADA software support remote monitoring and control?What are the common pitfalls in SCADA software configuration and how can they be avoided?What is scaling of a SCADA system?What are the key performance indicators (KPIs) tracked in SCADA systems?What is the importance of alarm rationalization in SCADA?What are the advantages of using open-source SCADA software?What are the best practices for designing SCADA screens?What is the difference between polling and event-driven communication in SCADA?How does SCADA software handle data import and export tasks?What are the methods for data validation and error checking in SCADA?What are the methods for integrating SCADA with MES and ERP systems?How do you perform real-time data filtering in SCADA software?What is an analog input in SCADA?What is a digital input in SCADA?What is an analog output in SCADA?What is a digital output in SCADA?What is Fieldbus in SCADA?What is a sensor in SCADA?What is an actuator in SCADA?What is a control center in SCADA?What is Ethernet in SCADA?What is system uptime in SCADA?SCADA Automation QuestionsWhat are the common challenges in SCADA system integration?What are the key considerations for SCADA system interoperability?What is user authentication and role-based access control in SCADA software?How do you troubleshoot communication issues in SCADA systems?What are the benefits of implementing a redundant SCADA system?How do you handle data synchronization in a distributed SCADA system?What are the key features of modern SCADA systems?What are the typical steps for SCADA system maintenance?How is cybersecurity implemented in SCADA systems?What is the function of redundancy in SCADA systems?What is the significance of latency in SCADA communication?What is the role of a Remote Terminal Unit (RTU) in a SCADA system?How are thresholds and limits configured in SCADA for process control?How do SCADA systems support regulatory compliance?What is the purpose of regular software updates in SCADA systems?How are hardware checks performed in SCADA maintenance?What is the role of system audits in SCADA maintenance?How do you address inconsistent data readings from sensors in SCADA systems?What steps should be taken if a SCADA system experiences frequent alarms?How can you troubleshoot SCADA system crashes?What is a common reason for SCADA system overheating and how can it be resolved?What is the recommended approach if SCADA data shows unexpected spikes?What is the best approach to handle SCADA software bugs?How can you troubleshoot power supply issues in SCADA systems?What steps can be taken if SCADA logs show frequent authentication failures?What can be done if SCADA data is not being logged correctly?What should be done if a SCADA system component frequently fails?What steps should be taken if SCADA fails to receive data from a field device?
SCADA Questions
The below video helps you to understand the first 26 questions with their explanations.
SCADA Questions and Answers
Question 1
A. A data point for monitoring and control
B. A control algorithm with predefined logic
C. A user interface element in SCADA
D. A network protocol in SCADA
Show the Answer
Question 2
A. Automated control functions
B. Historical data logs
C. Alert operators about abnormal conditions
D. Sensor values indication
Show the Answer
Alert operators to abnormal conditions
Question 3
A. Operator login credentials
B. Data transmission rates
C. Control signals for equipment start-up
D. Control signals for equipment shutdown
Show the Answer
Question 4
A. Alarm summaries
B. Graphical representations of data over time
C. System configuration settings
D. User access logs
Show the Answer
Question 5
A. A network communication protocol
B. A database for long-term data storage
C. A database for short-term data storage
D. An operator interface tool
Show the Answer
Question 6
A. The programming language used
B. The structural design of SCADA systems
C. The communication protocol employed
D. The user interface layout
Show the Answer
Question 7
A. A remote sensor device
B. A data encryption module
C. The central control unit in SCADA
D. A network router
Show the Answer
Question 8
A. Configuring network hardware
B. Stores and process the data
C. Providing user authentication
D. Generating power for devices
Show the Answer
Question 9
A. Controlling field devices directly
B. Developing and maintaining SCADA applications
C. Managing network traffic
D. Storing historical data
Show the Answer
Question 10
A. Enabling interoperability between different devices and software
B. Managing process control devices
C. Encrypting SCADA communication
D. Configuring control algorithms
Show the Answer
Question 11
A. Offline data sharing between applications
B. Real-time data sharing between applications
C. Network configuration tool for upgradations
D. It provides the data encryption & remote access
Show the Answer
Question 12
A. By setting network parameters
B. By creating user accounts
C. By designing HMI screens
D. By defining desired values for process variables
Show the Answer
Question 13
A. Database for network settings
B. Storage for user credentials
C. Central repository for managing process variables
D. Interface for hardware devices
Show the Answer
Question 14
A. IP address, subnet mask, gateway
B. Integer, float, boolean, string
C. File, directory, path
D. Command, response, status
Show the Answer
Question 15
A. Through graphical user interfaces
B. Using printed reports
C. Through email notifications
D. By manual entry
Show the Answer
Question 16
A. Single-user, multi-user, web-based, cloud-based
B. Fixed, modular, scalable, portable
C. Centralized, distributed, networked, hybrid
D. Basic, advanced, intermediate, expert
Show the Answer
Question 17
A. Web browsers, mobile apps, desktop clients, IoT devices
B. Algorithms, data models, user roles, permissions
C. Field devices, communication network, master station, HMI
D. User manuals, training programs, certification, support
Show the Answer
Question 18
A. Aggregates and processes data from single field devices
B. Configures network settings and provides periodic backups
C. Aggregates and processes data from multiple field devices
D. Aggregates and processes data from multiple power supply units
Show the Answer
Question 19
A. SQL, PL/SQL, T-SQL, MySQL
B. Fortran, COBOL, Pascal, Ada
C. HTML, CSS, XML, JSON
D. VBScript, JavaScript, Python, Lua
Show the Answer
Question 20
A. User permissions that control system alarms
B. Network alarms for communication protocols
C. Predefined values that trigger alarms for specific process variables
D. Alarm display settings for graphical interfaces
Show the Answer
Question 21
A. Hub, spoke, clustered, distributed
B. Star, ring, bus, mesh
C. Grid, linear, circular, random
D. Client-server, peer-to-peer
Show the Answer
Question 22
A. Provides quick data collection from field devices
B. Ensures accurate event logging and coordination
C. Enables real-time user communication
D. Manages user access rights across different SCADA systems
Show the Answer
Question 23
A. Translation, rotation, scaling, reflection
B. Compression, decompression, streaming, buffering
C. Scheduling, routing, encryption, decryption
D. Prioritization, escalation, acknowledgment, logging
Show the Answer
Question 24
A. For performance analysis and predictive maintenance
B. For network configuration and backup restoration
C. For user access management across all systems
D. For real-time data display in the SCADA
Show the Answer
Question 25
A. Using Historian databases and scheduled backups
B. Through real-time display screens
C. Using external USB drives and Hard disks
D. Without using network gateways
Show the Answer
Question 26
A. By providing tools for configuration, monitoring, and response
B. By compressing data for long-term data storage
C. By routing data through secure channels
D. By encrypting alarm messages
Show the Answer
This SCADA video provides you the detailed explanations for the next 26 questions.
Top Supervisory Control and Data Acquisition (SCADA) Questions
Question 27
A. Networking, IP addressing, domain setup, firewall configuration
B. Firmware updating, power cycling, remote access setup, email alert configuration
C. Planning, installation, configuration, testing, validation
D. Data entry, user creation, password setting, encryption
Show the Answer
Question 28
A. By user-defined labels
B. Based on severity and impact on operations
C. By alphabetical order
D. By network location
Show the Answer
Question 29
A. Monitoring and controlling industrial processes
B. Developing SCADA applications
C. Only Monitor industrial processes
D. Only controls industrial processes
Show the Answer
Question 30
A. By employing user scripts
B. Using hardware firewalls
C. Through manual configuration
D. Using converters or gateways
Show the Answer
Question 31
A. SCADA is hardware, PLC is software
B. SCADA operates devices, PLC only monitors
C. SCADA is for monitoring, PLC is for control
D. SCADA uses cloud storage, PLC uses local storage
Show the Answer
Question 32
A. IPv4, IPv6, TCP, UDP, PLC
B. SQL, NoSQL, XML, JSON
C. FTP, HTTP, SMTP, POP3
D. Modbus, DNP3, IEC 60870, OPC
Show the Answer
Question 33
A. Through physical connections only
B. FTP, HTTP, SMTP, POP3
C. Only by sharing IP addresses
D. Through communication protocols and drivers
Show the Answer
Question 34
A. Digital tags represent binary states, analog tags represent continuous values
B. Digital tags manage network settings, analog tags handle user data
C. Digital tags are for security, analog tags for performance
D. Analog tags represent binary states, digital tags represent continuous values
Show the Answer
Question 35
A. To manage network traffic and block cyber attacks
B. To design user interfaces with custom graphical design
C. For manual tasks and enhance system security
D. To automate tasks and enhance system functionality
Show the Answer
Question 36
A. Hardware design, firmware updates, user training
B. Network setup, IP allocation, DNS management
C. Alarm handling, data processing, report generation
D. Inventory tracking, payroll processing, CRM integration
Show the Answer
Question 37
A. User training, network redesign, data migration, software degrade
B. Just connect the device to the PLC and it will automatically program the logic
C. Power cycling, software reboot, database backup, firewall setup
D. Device configuration, protocol setup, driver installation, testing
Show the Answer
Question 38
A. Through operator surveys and feedback
B. Using external data storage devices
C. By using the offline data to analyze the problems
D. Using diagnostic tools, logs, and real-time monitoring
Show the Answer
Question 39
A. User authentication, encryption, firewall, access control
B. User profiles, data archiving, report generation
C. Data compression, file synchronization, auto-updates
D. Real-time data streaming, load balancing, caching
Show the Answer
Question 40
A. By enabling guest access for all users in SCADA
B. Through manual logging of SCADA user activities
C. By defining roles, assigning permissions, and regular audits
D. By setting default passwords for all SCADA users
Show the Answer
Question 41
A. Recording system activities and changes for analysis
B. Generating visual trends and reports for all alarms
C. Scheduling system maintenance tasks in SCADA
D. Recording sensors data all the time in SCADA system
Show the Answer
Question 42
A. Performing real-time data analysis and system migrations
B. Creating detailed reports based on collected data
C. Encrypting data for security purposes and decrypting the same
D. Creating detailed reports based on user inputs
Show the Answer
Question 43
A. Scheduling upgrades during low activity periods, using redundant systems
B. By ignoring pending alarms, trips, and forced signals
C. Through complete system shutdown
D. By manually entering new data into the SCADA server
Show the Answer
Question 44
A. Setting up redundant systems, regular backups, and testing recovery
B. By using offline gateway communication channels
C. Only by setting up the PLC and SCADA systems via wireless communication
D. By installing antivirus software and upgrading the firewall
Show the Answer
Question 45
A. SCADA works only on local computer and do not provide any remote support
B. The ability to monitor and control SCADA systems from offsite locations using secure communication channels
C. The practice of storing data remotely on field devices without network connectivity
D. The implementation of physical security measures at remote facilities
Show the Answer
Question 46
A. By shutting down all systems temporarily
B. Using manual recovery processes
C. Automatic switchover using redundant systems
D. Through data compression and storage
Show the Answer
Question 47
A. Through real-time data analysis and software migrations
B. By reinstalling the software periodically
C. Using manual documentation and reports generation
D. By tracking changes, maintaining backups, and auditing updates
Show the Answer
Question 48
A. By ignoring changes until they cause issues
B. Through change management processes and approval workflows
C. Using external consultants only
D. By allowing any user to make changes
Show the Answer
Question 49
A. Reviewing logs, verifying settings, testing backups, assessing security
B. Upgrading hardware, installing software, training users, generating reports
C. Disabling alarms, resetting user passwords, recalibrating sensors
D. Conducting surveys, holding meetings, drafting proposals, seeking approvals
Show the Answer
Question 50
A. Through manual deletion of old data
B. By storing data on local devices
C. By using databases and setting data retention policies
D. Using real-time data streams only
Show the Answer
Question 51
A. The protocol for data transfer between sensors
B. The type of sensors used in the system
C. The design of the control algorithms for valves & sensors
D. The layout of interconnected devices in the network
Show the Answer
Question 52
A. A real-time adjustment mechanism in process industries
B. Processing in set intervals with specific start and end points
C. A continuous, non-stop industrial operation
D. Processing in set intervals without specific start and end points
Show the Answer
SCADA PLC MCQ
This PLC SCADA video MCQ gives the explanations for the next 26 SCADA questions.
https://www.youtube.com/watch?v=yoMwpFMfTFo&list=PLI78ZBihrkE3r0spCEdNIGmbaEfKPqUSa&index=39
Question 53
A. A pathway for data exchange between SCADA components
B. A storage location for control programs in PLC
C. A protocol for software updates and backup restore
D. A user interface between sensor and motors
Show the Answer
Question 54
A. Managing user authentication and access control within the SCADA system
B. Providing real-time data analytics and generating detailed reports
C. Facilitates communication between different networks and protocols
D. Facilitates communication between different sensors and actuators
Show the Answer
Question 55
A. By updating the software only when issues arise
B. By disabling all security features temporarily
C. By allowing users to download updates independently
D. By planning updates, validating compatibility, and testing thoroughly
Show the Answer
Question 56
A. APIs automatically identify the failed field devices and performs troubleshooting
B. APIs are used to establish communication with all types of sensors
C. Managing hardware configurations and optimizing network performance
D. Enabling seamless data exchange between different systems
Show the Answer
Question 57
A. By requiring operators to be physically present at the control center at all times
B. SCADA works only on local computer and do not provide any remote support
C. Through web interfaces, mobile applications, and secure communication protocols
D. By limiting system access to local network connections only
Show the Answer
Question 58
A. Frequent hardware updates, extensive user training, regular backups
B. Ignoring real-time data, avoiding automation, disabling alarms
C. Inadequate security measures, improper user roles, poor documentation
D. Overuse of manual processes, lack of data encryption, limited network access
Show the Answer
Question 59
A. Increasing the number of user licenses online without shutdown
B. The process of expanding the system’s alarms and trips
C. Decreasing the number of user licenses online without shutdown
D. The process of expanding the system’s capacity and capabilities
Show the Answer
Question 60
A. Number of I/Os, Number of CPUs, Number of sensors
B. Power consumption, office supplies usage, employee attendance
C. System uptime, response time, alarm frequency, data accuracy
D. Number of user logins, file downloads, email sent, web traffic
Show the Answer
Question 61
A. To reduce alarm fatigue and improve response effectiveness
B. To increase the number of alarms for thorough monitoring
C. To prioritize routine maintenance alarms
D. To eliminate the need for operator intervention
Show the Answer
Question 62
A. Limited functionality, lack of updates, no support, high cost
B. Cost savings, flexibility, community support, transparency
C. Guaranteed security, proprietary support, high licensing fees, vendor lock-in
D. High entry barriers, restricted access, exclusive features, low adoption
Show the Answer
Question 63
A. Keeping interfaces simple, using clear graphics, prioritizing critical data
B. Emphasizing bright colors, adding unnecessary animations, ignoring user feedback
C. Using interfaces without any animations, using clear graphics, prioritizing critical data
D. Using complex graphics, maximizing data density, minimizing user input
Show the Answer
Question 64
A. Polling is used for alarms, event-driven for data logging
B. Polling continuously checks for data, event-driven responds to specific changes
C. Polling is faster, event-driven is more reliable
D. Event-driven continuously checks for data, polling responds to specific changes
Show the Answer
Question 65
A. Relying exclusively on specialized, proprietary middleware solutions
B. Through built-in tools, standard formats, and configurable options
C. By encrypting data continuously and uses only fieldbus protocols
D. Requiring extensive manual data transcription by operators
Show the Answer
Question 66
A. Ignoring minor data inconsistencies, focusing solely on critical data points, and limiting the use of automated systems
B. Relying on external consultants to periodically audit the data, performing extensive data replication, and using deprecated communication protocols
C. Implementing predefined validation rules, conducting real-time data monitoring, and utilizing automated alert systems
D. Manually reviewing data entries at regular intervals, applying complex encryption algorithms, and using proprietary data formats
Show the Answer
Question 67
A. Relying solely on manual data transfers between systems
B. Using APIs, middleware, and standard communication protocols like OPC
C. Using non-standard communication formats unique to each vendor
D. Implementing proprietary hardware solutions without software support
Show the Answer
Question 68
A. Using outdated software tools that lack real-time capabilities
B. By manually reviewing and sorting data streams periodically
C. By configuring dynamic data filters, setting appropriate data thresholds, and implementing advanced signal processing algorithms
D. Relying on external softwares to filter data off-site
Show the Answer
Question 69
A. An analog command from the operator
B. A signal that is fixed over a range
C. A binary signal indicating a discrete state
D. A signal that varies continuously over a range
Show the Answer
Question 70
A. A signal that is fixed over a range
B. A type of communication protocol used between transmitters & PLC
C. A binary signal indicating an on/off state
D. A binary signal that varies continuously over a range
Show the Answer
Question 71
A. A binary signal to turn devices on or off
B. A configuration setting for network parameters
C. A type of communication protocol used between valves & PLC
D. A continuous signal used to control a process variable
Show the Answer
Question 72
A. A binary signal that controls devices like level sensor, flow sensor
B. A binary signal that controls discrete devices like relays and motors
C. A type of communication protocol used between sensors & PLC
D. A continuous signal for adjusting process parameters
Show the Answer
Question 73
A. A communication protocol
B. A type of sensor
C. A power supply unit
D. A data storage system
Show the Answer
Question 74
A. A device to measure physical properties
B. A power supply unit
C. A communication protocol
D. A data storage unit
Show the Answer
Question 75
A. A software application
B. A device to move or control a mechanism
C. A network switch
D. A data collection unit
Show the Answer
Question 76
A. A power distribution unit
B. An electrical control unit for motors
C. A field sensor network
D. A centralized monitoring station
Show the Answer
Question 77
A. A low-speed communication protocol for networking devices
B. A high-speed communication protocol for networking devices
C. It is a power cable to provide required power supply to the SCADA
D. A wireless sensor network between PLC and SCADA
Show the Answer
Question 78
A. The duration of a data transmission
B. The speed of data processing
C. The percentage of time the system is operational
D. The frequency of system updates
Show the Answer
This SCADA automation video provides you the explanations and answers for the remaining questions.
https://www.youtube.com/watch?v=fnDns7Pnzcc&list=PLI78ZBihrkE3r0spCEdNIGmbaEfKPqUSa&index=40
Question 79
A. Lack of user interfaces, absence of protocols, and low data accuracy
B. Compatibility issues, data security, and scalability
C. High licensing costs, slow internet speed, and user training
D. Limited hardware options, no community support, and high maintenance
Show the Answer
Question 80
A. Single vendor solutions, closed networks, and static configurations
B. Proprietary software, high costs, and minimal training
C. Standard protocols, flexible architecture, and compatibility testing
D. Low data rates, manual processes, and limited automation
Show the Answer
Question 81
A. Limiting system access to only remote locations
B. Ensuring only authorized users can access and perform specific actions
C. Allowing all users to perform any action using remote control and monitoring
D. Ensuring only unauthorized users can access and perform specific actions
Show the Answer
Question 82
A. Rebooting all connected devices including the PLC
B. Installing additional hardware and software tools
C. Checking network configurations, testing connections, and reviewing logs
D. Disabling all security protocols permanently
Show the Answer
Question 83
A. Reduced installation costs, simplified architecture, and fewer user roles
B. Lower data accuracy, slower processing speed, and limited scalability
C. Greater complexity, higher maintenance requirements, and lower security
D. Increased reliability, fault tolerance, and uninterrupted operation
Show the Answer
Question 84
A. Using time-stamping, NTP, and regular data audits
B. Using non-standard protocols and custom scripts
C. Using historian servers and data backup servers
D. Through batch processing of data once a month
Show the Answer
Question 85
A. Remote access, real-time monitoring, advanced analytics, and cybersecurity
B. High maintenance costs, complex interfaces, and low data accuracy, and, cybersecurity
C. Single-user operation, local data storage, and basic alarm systems with large data storage
D. Limited user access, manual reporting, fixed architecture, and no remote capabilities
Show the Answer
Question 86
A. Regular updates, backups, hardware checks, and system audits
B. Outsourcing all operations, avoiding updates, and manual record-keeping
C. Check alarms, disabling logs, and using outdated protocols
D. Increasing user licenses, reducing security measures, and manual data entry
Show the Answer
Question 87
A. By implementing unstandardized security protocols unique to each device
B. By relying solely on physical security measures and limited network access
C. Using firewalls, encryption, intrusion detection systems, and regular security updates
D. Through frequent software reinstallations and system reboots
Show the Answer
Question 88
A. Increasing system complexity without benefit
B. Ensuring continuous operation in case of component failure
C. Simplifying system architecture
D. Reducing the number of available devices
Show the Answer
Question 89
A. Reduces the number of user interfaces needed
B. Increases the number of user interfaces needed
C. Affects the memory capacity and CPU speed
D. Affects the speed and reliability of data transmission
Show the Answer
Question 90
A. Managing network configurations and optimizing communication protocols
B. Collecting data from field devices and transmitting it to the SCADA master station
C. Only Collects data from SCADA and transmits it to the PLC
D. Providing a user interface for direct operator interaction with the SCADA system
Show the Answer
Question 91
A. By setting predefined values based on process requirements
B. Through manual adjustments without any predefined criteria
C. Using default manufacturer settings without modification
D. By random selection
Show the Answer
Question 92
A. By limiting data collection to essential parameters only
B. By maintaining accurate records, generating compliance reports, and providing audit trails
C. Through manual record-keeping and updating the systems database
D. By ignoring regulations and using the real-time data analysis
Show the Answer
Question 93
A. To reset all system settings
B. To fix bugs, enhance security, and improve functionality
C. To decrease system performance
D. To remove user access controls
Show the Answer
Question 94
A. By only monitoring software performance
B. Through annual system shutdowns
C. By inspecting physical components and verifying their operation
D. By disabling hardware alarms
Show the Answer
Question 95
A. Reducing the need for backups
B. Increasing the complexity of the system
C. Limiting user access to critical functions
D. Ensuring compliance, identifying issues, and improving system performance
Show the Answer
Question 96
A. Always consider the last good value instead of checking the issue
B. Ignoring anomalies and assuming average values
C. Calibrating sensors, checking for interference, and ensuring proper installation
D. Replacing sensors without diagnostics
Show the Answer
Question 97
A. Ignoring alarm messages and continuing operations
B. Increasing the number of sensors to generate more data
C. Disabling all alarms temporarily
D. Reviewing alarm thresholds, rationalizing alarms, and investigating root causes
Show the Answer
Question 98
A. Reducing the number of user sessions
B. Reviewing system logs, checking hardware health, and updating software
C. Ignoring error messages and restarting the system
D. Immediately install the operating system with fresh software
Show the Answer
Question 99
A. Poor ventilation; resolved by improving cooling and airflow
B. Excessive data logging; resolved by reducing data storage
C. Frequent user access; resolved by limiting user logins
D. High humidity; resolved by dehumidifying the area
Show the Answer
Question 100
A. Update the SCADA software immediately with latest version
B. Analyzing trends, checking sensor calibration, and investigating process changes
C. Replacing all sensors immediately and update the configuration
D. Ignoring the spikes as anomalies
Show the Answer
Question 101
A. Downgrading to an older version and use old software backups
B. Reporting bugs to the vendor, applying patches, and updating the software
C. Ignoring minor bugs and take immediate action on major bugs
D. Limiting software usage and reducing the system load
Show the Answer
Question 102
A. Ignoring power fluctuations as they do not have any affect
B. Replacing all hardware components and update the software
C. Checking power sources, ensuring proper grounding, and verifying UPS functionality
D. Immediately replace the power supply units with higher-rating modules
Show the Answer
Question 103
A. Allowing unlimited login attempts
B. Disabling authentication features
C. Ignoring failed attempts as they don’t have any affect
D. Investigating user accounts, and reviewing access controls
Show the Answer
Question 104
A. Ignoring missing logs and optimize the software
B. Verifying logging configurations, checking storage capacity, and ensuring database integrity
C. Reducing the frequency of data collection and decreasing the memory capacity
D. Disabling data logging features and delete the old trend backups
Show the Answer
Question 105
A. Conducting a root cause analysis, replace faulty components, and reviewing system design
B. Ignoring the failures and always replace the faulty component for optimal system performance
C. Limiting the use of the component and downgrade the system logic
D. Disabling error reporting and increase the power supply module rating
Show the Answer
Question 106
A. Rebooting the entire SCADA system and check the status
B. Ignoring the missing data and configure a new field device in place of it
C. Checking communication links, verifying device power, and ensuring correct configurations
D. Replace the field device immediately to restore the process parameter value
Show the Answer
  • Difference Between PLC and SCADA
  • Learn about SCADA and HMI Systems
  • InTouch SCADA Tutorial Course
  • SCADA Engineer Job Responsibilities
  • Types of SCADA System Architecture
Application of Feedback Objective Questions
Quiz on Sensor Transducer
Finding the Best PLC for Your Project – Tips and Tricks
Types of CPU Communication Ports in Siemens PLC
Basic Arithmetic Programming in Mitsubishi PLC
How to Use Encode and Decode Instructions in PLC ?
Data Transmission Objective Questions
PLC Programming Example on Timers Function Block
What is a PLC Retrofitting Project? – Importance, Procedure
PLC Instruction List for Motor Reverse and Forward Direction
Oil and Water Separation Process using PLC Programming
Classic Control Circuits
Ladder Logic for Stair-Case wiring using Toggle Switches
Analog Recorders Objective Questions
Measurements & Instrumentation Quiz – Set 9
Nuclear Power Plant Multiple Choice Questions
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
Configuration of Siemens Scada and PLC
Configuration of Input and Output Tags in Siemens Scada and PLC
Siemens PLC Programming OBs in Siemens TIA Portal
FC Function in Siemens PLC
Instrumentation Role during Steam Blowing
thermocouple voltages
Manually Interpreting Thermocouple Voltages
Importance of Neutral Wire
how-to-select-a-fuse
How to Select a Fuse ?
Electro Chemical Transducers Objective Questions
SMART Transmitters Block Diagram
Smart Transmitters LRV & URV
basic-electronics-questions-answers
Basic Electronics Questions & Answers
C-Type Bourdon Tube
Types of Bourdon Tube
