Reading: How Kalrez O-rings Seal So effectively So Long?
Inst Tools > Blog > Root Cause Analysis (RCA) > How Kalrez O-rings Seal So effectively So Long?
In this article, you will learn how kalrez O-ring seal solved the compressor leaks which was faced by the author.
Last updated: September 28, 2022 2:51 pm
S Raghava Chari
3 Min Read
The O‑ring backup ring set (ORBRS) change shutdown (SD) reduction from 10 to 1½ days won appreciation; yet the author continued his efforts to stop the continuing 3-monthly discharge head (DH) leaks, consequent 6 on stream days lost total NH3 and 70% lost Urea Production.
Constantly thinking about it, the author recollected Kalrez, Du Pont advertised new super sealing material.
The ad claim of Kalrez’s higher than Viton – the present O-ring material – upper temp limit, super long time-resiliency and inertness to all known chemicals characteristics.
After a detailed study, he was confident of its success; at least it won’t worsen the present situation.
However, the compressor vendor declined Kalrez O‑rings supply. He did not even give the O-ring dimensions, to get it from an O‑ring vendor citing deviation from his standard and proprietary information as the reasons.
Shining a powerful flashlight on the last supply shipping list reverse side, the author jotted down the blacked-out dimensions.
Kalrez O‑Ring from a US O-ring supplier and the usual PTFE backup ring at the DH never leaked!
Extending the new ORBRS quick-change method, bundles pre-TA assembled using bought-out stationary parts and available spare rotors reduce K‑601 each barrel overhaul times to just 36-hours, eliminating turnaround (TA) or shutdown pressures due to the Middle East and call center attracted depleting Rotating Machine Crew strength.
How Kalrez O-rings seal so effectively so long?
Kalrez O-ring seal
Image Courtesy: Kalrez
Below given are the author guessed possible reasons:
  1. Viton, the original O-Ring material temperature rating is lower than that of Kalrez
  2. Maybe the vicinity fire had slightly deformed the DH annulus, the ORBRS sealing area
  3. Maybe Viton deteriorates faster than Kalrez; hence it starts leaking within 3‑months.
  4. Once the 250o C gas leak starts  The rubber also attains the same temp and deteriorates still faster
  5. The very slow deteriorating Kalrez O‑ring does not allow leaks starts maybe up to 4 years the overhaul intervals. Hence, its temperature never exceeds its rating.
The crew puts new elastomers at each 4‑yearly overhauls. Hence, no leaks seen ever.
Author: S. Raghava Chari
  • Control Valve Noise Problems
  • Pump Trip Root Cause Analysis
  • Level Switch Issue and Solution
  • Power Plant Root Cause Analysis
  • Torque Converter Problem Solved
Arc Fault Breaker (AFB) Electrical Problem Solved
Too often done riskily repaired Roof Hot Spots eliminated forever
NH3 Storage Tanks Ammonia Gas Venting Issue – Root Cause Analysis
Passing Control Valves Cause Yearly Losses in Production Plant
Cooling Tower Fans Frequently Failing
Erratic Radar Level Gauges Delays a Refinery Commissioning
Heat Exchanger Tubes Corroded Root Cause Analysis
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
Finned Tube Steam Leaks – Root Cause Analysis
HT Motor Problem appears after Disassembly and Reassembly
Fan Motor Frequent Journal Bearing Failures Posed Plant Outages
Too Low Efficiency Torque Converter Elimination Attempt
Cement kilns, Rotary Drum Driers Simplest Electrical Drive
CO2 Absorber Graphics in DCS
CO2 Absorber Corroded Wall Thickness & Weld Building
11 KV Bus A to Bus B Phase Check Problem
butt weld end Plug Valves Leaks Stopped
PTFE lined 6” 300# butt weld end Plug Valves Leaks Stopped Forever
Repeat Safety Valve Popping
Repeat Safety Valve Popping caused Urea Plant Shutdown
Boiler Feed Water Heater Shell Flange Leaks
Incident Investigation: Motor Operated Valve Lesson
Jacket Added Seawater Pipe Spool
Seawater Pipeline Spools from day-1 leaks threaten Plant Shutdown
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
old Pressure Switches
Pressure Switch Frozen Screwed Cover Extends the Plant Shutdown
valve control system
Solenoid Valves Practical Problems
Ring Counter Objective Questions
Components of PLC
Analog Instruments
Proximity Switch Questions and Sensors
62 Proximity Switch Questions and Answers
Basic Process Control System
SIS System Testing - Safety PLC Control System
SIS System Testing – Safety PLC
