Reading: Basic Working Principle of Vortex Flowmeter
Inst Tools > Blog > Animation > Basic Working Principle of Vortex Flowmeter
The principle of the Vortex Flowmeter is when a bluff body is placed in a pipeline then vortices are generated which is proportional to the flow rate.
Last updated: October 31, 2023 11:40 am
Animation Flow Measurement How It Works
2 Comments
1 Min Read
A vortex flow meter works based on the principle of ‘Karman vortex street’ demonstrated in the below figure.
This principle essentially means that when an obstruction is placed in the path of a flow, it can produce a series of vortices alternating from each side of the obstruction.
The frequency of alternating of these vortices is proportional to the flow rate being obstructed.
Vortex Flowmeter
The vortex-type flow meter uses a small rod called a ‘shredder bar’ or ‘bluff bar’ to shred vortices and these vortices produced are directly proportional to the flow rate. These vortices can be measured using a pressure sensor and it calculates a proportional flow rate.
In some applications, different types of sensors may be used in place of pressure sensors.
  • Calibration of Vortex Flow Meter
  • Swirl Flow Meters Principle
  • Transit Time Flow Meter
  • Nutating Disc Flow Meter
  • Open Channel Flow Meters
Coriolis Mass Flow Sensor Theory
Vortex Flow meter Animation
Solenoid Valves Types, Principle & Animation
Coriolis Flowmeter Advantages and Limitations
Calculate Flow Transmitter Output Current
2 Comments
  • Roel Gamitin says:
    December 11, 2015 at 3:10 pm
    Nice application
  • lily1987 says:
    October 23, 2019 at 8:59 am
    great animation to demostrate us how vortex shedding flow meter is working.
Basics of Switches & its applications
Control Valve Working Animation
What is ON/OFF Valve ?
What is a Torbar? – Averaging Pitot Tubes
Types of Vortex Flow Meter Sensors
Flow Nozzle Principle, Advantages, Disadvantages, Applications
How to do Turbine Flow Meter Verification?
DP type Flow Transmitter Calibration
DP type Flow Transmitter Preventive Maintenance and Calibration
Weigh feeders Principle
What is a Weigh Feeder?
Modbus in Industrial Networks
Reciprocating Piston Meters
Overview of Positive Displacement Flow Meters
multi-variable transmitter
Mass Flow Meters
Pressure and Temperature Compensation for Flow Transmitter
Magnetic Flowmeter vs. Turbine Flowmeter
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
HT motors Corrosion Problem
Ratio control
What is Ratio Control ?
Kiln
Kiln Inlet Gas Analyzer
DP-Level-Transmitter-Diaphragm-with-capillary-tube-type
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Pressure Unit Conversion Practical Example
Yokogawa DCS
Yokogawa DCS and SIS System Architecture
Difference between Induction motor and Synchronous motor
Difference Between Open Circuit and Close Circuit
