Reading: Repeat Failures of Letdown Valves
Inst Tools > Blog > Root Cause Analysis (RCA) > Repeat Failures of Letdown Valves
Instrumentation engineering root cause analysis (RCA) of letdown valves repeat failures in industrial plant.
Last updated: September 28, 2022 3:02 pm
S Raghava Chari
Repeat Failures of Letdown ValvesFinal SolutionRCA solution Benefits
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Control Valves
Author:S. Raghava Chari
As foreseen, within a week failed PCV 205 S shut down the plant chaotically.
Crew bolted the as soon as possible (ASAP) readied and carbon-steel flanges screwed valve PCV 205 to the pipeline and production resumed in 6 hours. The wisely screwed-in CS flanges reduced the downtime by 2 hours.
As before crew readied spare valve PCV 205S too ASAP and vigorously considered plug to stem strengthening.
Also Read: First Time Letdown Valve Problem
Final Solution
The SS 329 plug broke into two while welding to the stem. Hence, the author decided to use No Joint Inner Valve (NJIV) braving the below given two constraints and the valve maker not approving it.
  1. The manufacturer neither supplied the NJIV nor approved making it out of SS 329 citing reasons of standards permit only resilient SS 316 stem screwed to erosion resistant hard SS 329 plug and 329’s non-weldability.
  2. Still the author got SS NJIV turned overcoming the below given constraints:
  3. Suitable size SS 329 bar stock non-availability
  4. Excessive materials and efforts waste by turning the Max 40 mm dia NJIV out of the only 124 mm dia x 1.5 m long carbomate pump discarded plunger.
  5. He got a 800 mm long piece cut, tacked it vertically to a large plate. A crew of 2 working for two hours and another taking over hacksawed it into 4 quadrants in 12 hours. The shop turned out the two NJIVs one each for PCV 205 and PCV 205 S. They saved remaining two for other uses.
  6. Instrument crew readied PCV 205 with the NJIV. It went on the line at a soonest shutdown opportunity. It failed never! The author believes no joint and the generous fillet radius he provided where the dia reduces from 38 to 25.4 mm are the reasons for the IVs success.
Crew readied PCV 205 S with NJIV. However, it has become a non-moving spare!
A lasting and least-cost solution for a DDUDP.
The valve PCV 205 inspected at 3‑years intervals is excellent.
Author: S. Raghava Chari
  • Valve Positioners Failed
  • Errors and Faults in Siemens PLC
  • Electrical Engineering Problems
  • Pressure Taps Block Valves Leaks
  • Unstable & Drifting Values of Transmitter
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
Pump 3-monthly Seal Leaks threaten entire Plant Shut down Indefinitely
Mechanical Temperature Indicators (MTI) Problem
Panel and Field Pneumatic Controller’ Bumpless Transfer Issues
HT Motor Direction of Rotation (DOR) Changed
Supplied Screen Vibrators Perennial Problems
Learnings from the BP Refinery Explosion at Texas City
Critical High KiloWatt Motor Winding Burnout Threats
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Butterfly Valve Failure Caused Serious vicinity Heavy Fire
Turbo-Compressor Problem – Root Cause Analysis
A Pipe Elbow Sudden Burst Fatalities and Wrecked Panel Instrumentation
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
Wrongly terminated Thermocouple (TC) wires
Too Low-Temperature Readings after a Failed Thermocouple Change
Compressor Did Not Trip
RCA – Compressor Did Not Trip on Suction Pressure Low Low
Phosphate Dozing System
Phosphate Dozing System Problems
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Plunger Pump
Within Few Weeks Failing Acid Dozing Pumps
Welding Machine Fail in Dusty and Corrosive Areas
Reformer Fan Bearing Change Times cut by 90%
ON and OFF a Group of Outputs by One Push button PLC Logic
RDOL starter
What are DOL and RDOL starters? Advantages, Disadvantages
AI AO DI DO Signals
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Automation in Logistics Industry
HART Protocol
HART Communication Tutorial Part 1
Bimetallic strip thermostat
Mechanical Temperature Measuring Sensors
Pressure gauge is subjected to five different pressures
How a Bourdon Tube Pressure Gauge might be Adjusted for Linearity?
Control Valve Tips and Tricks
