Reading: PLC Program for Daily Production Record
Inst Tools > Blog > PLC Tutorials > PLC Program for Daily Production Record
PLC Program for Daily Production Record. Learn the problem description with a detailed explanation of the ladder logic.
Last updated: November 3, 2023 10:16 am
Daily Production RecordProblem DiagramPLC SolutionList of Inputs/OutputsLadder Diagram for Daily Production RecordPLC Program DescriptionRuntime Test Cases
Problem Description
In many industries, It is required to count the number of products that are made in one day and it is very necessary for selling the products or tracking the production quantity on a daily basis.
In the olden days, human operators were allotted for counting the final products but because of some human errors, precise counting is not possible. Therefore we cannot get proper counting of all products and are unable to track the production quantity effectively.
Mostly these types of problems occur in food and beverage industries, box packaging industries, bottle filling applications etc. So we can use a simple PLC based logic to track the daily production and to record it electronically.
Problem Diagram
PLC Solution
Here we will solve the problem of counting of final products by using sensors and PLC programming. First sensor sense the product and counts the quantity and the value will be shown on the digital display (as shown in above figure).
For easy explanation, we will consider one simple example of empty box counting system. In this system empty boxes are travelling form first process to second process (say one place to another).
Sensor is used for counting the empty boxes. So when sensor will detect empty box then display will start , say starts count from  1 and this is done by simple logic.
Every 24 hours / after one day, we can reset the counter value by using RESET button. Here we will consider two batches of production for easy explanation.
And also we have considered two batches completion indications for operator for each batch which will display on the Local Panel. By PLC logic we will implement the desired logic.
So when any batch will be completed then indication lamp will be ON as per PLC program.
Once production target will be completed, display counter can be reset by using RESET button.
Inputs List
  • Box detector Sensor: I0.0
  • Reset: I0.1
  • Main SWITCH: I0.2
Outputs List
  • Target completed: Q0.0
  • Batch 1 completed: Q0.1
  • Batch 2 completed: Q0.2
Ladder Logic for Daily Production Record
In this application, we have used Siemens S7-1200 PLC and TIA Portal Software for programming.
Network 1:
In Network 1 we used Main SWITCH (I0.2) to start the system/batch and we used NO contact of box detector sensor (I0.0) in series. Here we considered one UP counter so when box detector sensor (I0.0) detects  the box then counter will starts counting.
Here also we have taken target completed output (Q0.0) for target completion indication for the operator indication on the panel. By pressing RESET button (I0.1) operator can RESET the old production record.
Counter operation is used to count the products, in which RESET (I0.1) used for reset the production record. And Preset value (PV) is 20 products. Counter value (CV) is MW2 indicates the actual number of products detected by sensor & this value will be used in the following rungs to track the batch status.
Network 2:
In Network 2 we used batch1 logic from counter block output CV. Here we used comparator for counting 10 boxes for batch 1 and when it will be completed then batch 1 completed lamp (Q0.1) will ON. In this add equal to equal comparator in which input is (MW2) and for 10 products.
Network 3:
In network 3 we used batch 1 logic from counter block output CV. Here we used comparator for counting 20 boxes for batch 2 and when it will be completed then batch 2 competed lamp (Q0.2) will ON
And this way we can decide that how many products and batches are produced.
Runtime Test Cases
PLC Production
Note: The above PLC Logic provided for basic idea about application of PLC in industrial production record. The Logic is limited and not complete application.
Author: Bhavesh
  • SR Flip Flop using PLC
  • PLC Program using Logic GATE
  • Asynchronous Motor Control PLC
  • PLC I/O addressing
  • Alarms in Process Control
Allen Bradley RSLogix 500 PLC Programming
Modbus Communication between PLC and Energy Meter
Step-by-Step Guide to Choose Right Fuse for a Panel
How to Choose the Right Industrial Automation Solution?
Allen Bradley SLC 500 PLC Programming
Classroom Bell System – PLC Programming Practice Examples
Comparison Instructions in PLC Programming
Product Sticker Machine with Weighing PLC Program
Two Hand Control Logic using PLC
How to Convert an Electrical Diagram into PLC Program?
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Based Product Sorting Machine System – Lift Control
PLC Project Examples for EcoStruxure Machine Expert
Parameters of SRT_DINT instruction
Tia Portal – OB20 Time Delay Interrupt Organization Block
PLC Program Backup in Siemens Tia Portal
How to Take Program Backup from Physical PLC? – Siemens PLC
Communication Protocols in PLC
Various Communication Protocols in PLC
Difference Between PLC and CNC Machine
Architecture of Allen Bradley PLC
Structured Text Selector Machine Logic
Write a PLC Program for Selector Machine using Structured Text
HMI configuration for Delta VFD
Modbus Communication between Delta PLC with VFD
A Large Gate Valve Failed Motorized Operation
A Large Gate Valve’s Failed Motorized Operation
butt weld end Plug Valves Leaks Stopped
PTFE lined 6” 300# butt weld end Plug Valves Leaks Stopped Forever
Belt Conveyor Weighing System
Belt Conveyor Weighing System – Weigh Bridge – Speed Sensor
Top 100 Zigbee Projects for Engineering Students
Instrumentation Engineer Interview Questions
Interview Questions on PID Controllers
Door Lock with Delay PLC Exercise Problems
Power Systems MCQ Series 8
Analog Electronics Objective Questions – Set 9
