Reading: Flanged Rotameter Caused Pipe Weld Cracks and Gives Wrong Readings
Inst Tools > Blog > Root Cause Analysis (RCA) > Flanged Rotameter Caused Pipe Weld Cracks and Gives Wrong Readings
Heavy 4” 300# flanged rotameter not only gives wrong readings but also caused pipe weld cracks in the process plant.
Last updated: September 28, 2022 2:55 pm
S Raghava Chari
6 Min Read
Flanged Rotameter ProblemsAuthor RCA SolutionRCA solution benefitsAlternative for the Rotameter Flow Meter
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Sensors
Author:S. Raghava Chari
Rotameter Information: Fig 1 shows a 4” flanged rotameter. The rotameter inlet bore tapers to a larger dia at the exit. Table 1 lists its data:
Table 1; Typical 4” Rotameter Data
h (mm)MBR (mm)Q (m3/H)C – Q/h (ratio)
500.0010028275.65
475.0099.0026715.62
356.2594.2619525.48
237.5089.612795.38
118.7584.756155.18
0.00800.000.00
h-Graduation distance from zero flow; MBR-Meter body bore dia; Flow rate Q;
Table 1 shows that the rotameter scale is nearly linear. The plunger pump delivered flow stream velocity varies instant to instant and hence the float assumes a position representing the instantaneous flow rates average depending upon the float’s mass and the flow stream viscosity.
Hence, rotameters read pulsating flows a lot more accurately than square root scale receivers connected to Differential Pressure Transmitters (DPTs) across orifice plates, because, the DPT measured
hav = (h1+h2+h3+ … hn)/n
where
h1, h2, and h3, are the instantaneous differential pressures across the orifice plate.  The receiver’s square root scale square root scale reads the above shown √aaverage.
But the receiver must actually read √hc = (√h1+√h2+√h3+ … √hn)/n. These two averages may differ as much as 50% depending upon the type of machine delivering the pulsating flows and the orifice upstream pipelines’ and vessels’ volumes sum.
Electronic DPTs calibrated to output √h signals are also free from this error.
Problem:  The carbomate pump suction pipe bolted body clamped pneumatic transmitter 4” 300# flanged SS rotameter though capable of reading the pump delivered flow roughly accurately, always read very wrong. The reasons are:
The Plunger pump delivered flow pulsations generally shake the connected piping way high; the rotameter upstream, downstream and the bypass 4”x300# heavy plug valves aggravated the pipeline’s vibrations much more.
Flange Rotameter
Hence, the pipelines’ added welds for the rotameter and its bypass installation cracked and shutdown the plant often at enormous production loss
  1. The shaking pipes shook transmitter’s delicate flapper made the flow transmitter outputs and hence the receiver readings totally meaningless
  2. Often the instrument parts broke and involved excessive instrument crew efforts in a ‘no-use’ flow measurement of very poor availability
  3. Inability to hold the rotameter exactly vertical added to these problems
  4. Perennial Jacket steam leaks posed steam loss and housekeeping problems
Author RCA Solution
The author highlighted the worthless rotameter system posed plant shutdowns. Operations too tired of the plant shutdowns, which loaded them heavily besides lost production, reluctantly agreed the rotameter and bypass valves temporary removal, on the author agreeing to find better flow metering methods, Eventually, they forgot the flow measurement that served no purpose!
RCA solution benefits are:
  1. The simple rule is ‘no welds’ no shakes caused welds cracks; hence the rotameter and its bypass elimination eliminated the perpetually recurring pipelines welds cracks caused lengthy plant shutdowns
Thanks to far higher on stream hours, far higher production and far reduced workload, the operation crew eventually did not ask for  the no-use rotameter
Long after the rotameter removal, the author thought of an alternative for the rotameter: each of the carbomate pumps has Fig 2 RPM indicator: the Pulse to I converter powered a speed probe views the pump shaft key and sends electrical pulses/sec signal proportional to the pump RPM to the pulse to I convertor.
Pump RPM Controller
An I-P converter renders the pulse to the I convertor’s 4-20 mA output into 3-15 psi signals for the panel mounted ‘Speed Recording Controllers (SRC)’ which pull/push the hydraulic torque convertors’ internal vanes angle adjusting rod to vary the pump RPM.
The author could have easily added pump delivered m3/H graduations to the SRCs’ pump RPM scales in a different color as the plunger pumps’ delivered flow
Q = 3*N*S*0.25πd^2*l where
SymbolDescription
QPump delivered flow m3/min
3Each pump’s Number of plungers
NPump RPM
dPlunger dia m
lStroke Length m
The operation engineers forgot the flow measurement and the more pressing other work pressured the author too!
Author: S. Raghava Chari
  • Level Transmitters Zero Drifts
  • Target Flow Transmitters Failed
  • Pitot-tube Replaced with Orifice
  • Mechanical Temperature Indicator
  • Seal Pressure Instruments Problems
11 KV Bus A to Bus B Phase Check Problem
Supplied Screen Vibrators Perennial Problems
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
Boiler Feed Water Heater Shell Flange Leaks
Readers Questions on Flow Transmitter
Stuck Segment Orifice Dimensions Calculations
A Pipe Elbow Sudden Burst Fatalities and Wrecked Panel Instrumentation
Solving Control Valve Hunting: Instrument Troubleshooting
Antifriction bearings (AFB) Problems and Delays Plant Restarts
RCA Related to Trip Throttle Valve (TTV)
Unstable & Drifting Values of Differential Pressure Transmitter Problem
Carbamate Plunger Pump Packing Problems Eliminated
An Indian Plants all turbines’ low Vacuum & Saudi Plant turbo-compressor only
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Transformers Coolers Weld Joints Oil
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Replace Failed Motors Quickly and Easily
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
Target Flow Transmitter Problem
Target Flow Transmitters Failed the Very Midnight
Purpose of Isolation valve
Repeat Failures of Letdown Valves
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
noise-abatement trim
Control Valve Noise Problems
Instrument Turndown Ratio
Simatic 300 Station Configuration
Cars Garage Counter From the Same Door PLC Logic
Augmented Reality and Virtual Reality in Industrial Automation
Inductive proximity switches
How to Connect Proximity Switch (Source Type) to Make LED ON ?
Quiz on Manual Motor Starters
100 Electromagnetic Motor Starters Multiple Choice Questions
PID Block in RSLogix 500
