Reading: Identify Characteristics of Level Measurement Technologies
Inst Tools > Blog > Level Measurement > Identify Characteristics of Level Measurement Technologies
Identify characteristics of various level measurement technologies such as sightglass, float, hydrostatic, DP, dip tube, displacer, ultrasonic, radar, magnetostrictive, weight, capacitive, nuclear.
Last updated: February 5, 2021 9:11 pm
Level Measurement
9 Min Read
Identify characteristics of various level-measurement technologies.
SightglassAnswersFloatAnswersHydrostatic (DP with direct contact)AnswersHydrostatic bubbler (dip tube)AnswersDisplacerAnswersUltrasonicAnswersNon-contact radarAnswersGuided-wave radarAnswersMagnetostrictiveAnswersWeight (load cells on vessel)AnswersCapacitiveAnswersNuclearAnswers
An important tip is to commit to memory the operating principle of each instrument type, and then reason from that basis what each type’s characteristics will be:
Sightglass
Find the below mentioned the questions.
  1. Can it be used to measure the level of both liquid and solid materials?
  2. Can it be used to measure liquid-liquid interfaces?
  3. Does its calibration depend on some fluid property such as density?
  4. What are the Special advantages?
  5. What are the Special disadvantages?
Answers
  1. Liquids only
  2. Yes, but only if both ports submerged
  3. No
  4. Simple and inexpensive
  5. Manual indication only – no output signal
Float
Answers
  1. Liquids yes, solids only if retracted by automated winch
  2. Yes, if float density is set properly
  3. No
  4. Relatively simple and inexpensive
  5. Requires guides and other apparatus to stabilize in a tall vessel; doesn’t work well in turbulent processes
Answers
  1. Liquids only
  2. Yes, if both ports submerged
  3. Yes, density!
  4. Fairly simple and reliable
  5. DP sensor must withstand process fluid corrosion
Answers
  1. Liquids only
  3. Yes, density!
Displacer
Answers
  1. Liquids only
  2. Yes, if displacer is fully submerged
  3. Yes, density!
  4. Simple and reliable
  5. Susceptible to vibration; displacer may become stuck inside of the cage if the process fouls
Ultrasonic
Answers
  1. Yes
  2. No
  3. Yes, the speed of sound through the transmission media
  4. No contact with process fluid required
  5. Requires sharp change in density to function (e.g. layers of foam may interfere with measurement); irregular shapes inside of vessel may cause scattering and/or false echoes
Non-contact radar
Answers
  1. Yes
  2. No
  3. Yes, the speed of light through the transmission media
  5. Requires sharp change in permittivity to function (e.g. certain substances such as wood chips may be difficult to detect); irregular shapes inside of vessel may cause scattering and/or false echoes; permittivity of substance(s) above the measured level will affect its accuracy and may change with the density of that substance
Guided-wave radar
Answers
  1. Yes
  2. Yes
  4. Waveguide helps ensure a strong echo signal
  5. Waveguide must withstand corrosion and other stress from the process fluid; requires significant transitions in permittivity to detect surface and interface levels; irregular shapes inside of vessel may cause scattering and/or false echoes; permittivity of substance(s) above the measured level will affect its accuracy and may change with the density of that substance
Magnetostrictive
Answers
  1. No
  3. No
  4. Highly accurate measurement of float position (sub-millimeter resolution capability!)
  5. Susceptible to fouling of float on waveguide rod
Answers
  1. Yes
  2. No, unless total height of liquid is fixed (e.g. using an overflow pipe)
  3. Yes, if level (height) measurement is desired; No, if mass measurement is desired
  4. No contact with process fluid required; yields a linear measurement regardless of vessel geometry
  5. All mechanical stress must be eliminated from vessel
Capacitive
Answers
  1. Yes
  2. Yes, so long as probe is fully submerged
  3. Yes, permittivity of the process liquid for the non-conducting style
  4. Inexpensive
  5. Prone to calibration errors due to stray capacitance; irregular shapes inside of vessel may cause nonlinear response
Nuclear
Answers
  1. Yes
  2. Yes, if density or other radiation attenuating/scattering properties are sufficiently different between the two liquids
  3. Yes, density!
  5. Expensive to license and operate; calibration errors may result with fouling of vessel walls
Share your answers & explanation with us through the below comments section.
  • Radar LT Loop Diagram
  • Stilling Well in Interface
  • How to Choose a Control Valve?
  • Process Control Instrumentation
  • Temperature Sensor Failure
Magnetostrictive Level Transmitter Calibration Procedure
Magnetic Level Gauge Float Design
Manual Level Measurement
Micro-impulse Level Transmitter Principle
Paddle Wheel Level Switch Principle
Bubbler Level Sensor
Closed tank DP Level Transmitter with wet leg elevation zero remote mount Calibration
Non Contacting Radar Level Transmitter Animation
Level Troll working principle
Pressure Transmitters Leg Compensation Technique
Radar Level Measurement
Differential Pressure Measurement
Displacer Level Transmitter Intrenal Diagram
Displacer Level Transmitter Working Principle
Capillary Remote Seal Leave Measurement
Siemens Pressure Transmitter with Remote Seals Calculations
Radar and Ultrasonic Level Transmitter Problems Troubleshooting
Radar and Ultrasonic Level Transmitter Practical Problems Troubleshooting
Magnetically coupled float indicates liquid level
What are Mechanical Level Indicators? – Classification & Principle
Level Gauge Theory
Types of Level Gauges
Capacitive Level Switch Principle
Thyristor Protection Objective Questions and Answers
belt conveyors principle
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
Electric Circuits Objective Questions – Set 3
Float & Dial Level Gauge Principle
Basics of Loop Checks
Contacting Radar Tank Gauges
Radar Tank Gauging
Loss in Weight Liquid PLC System
Dosing Pump PLC Logic
Best 100 PLC Projects for Final Year Engineering Students
