Reading: Control Panel Instruments Problem Threatened Plant Shutdown
Inst Tools > Blog > Root Cause Analysis (RCA) > Control Panel Instruments Problem Threatened Plant Shutdown
Instrumentation root cause analysis of wrecked electrical control panel instruments problem threatens indefinite plant shutdown.
Last updated: September 28, 2022 2:56 pm
S Raghava Chari
8 Min Read
Instrumentation engineering root cause analysis (RCA) of wrecked electrical control panel instruments that threaten indefinite plant shutdown.
Control Panel Instruments ProblemPanel instruments RestorationPanel Pneumatic Receivers RestorationPanel Electronic Instruments RestorationDamaged Air Signal Tubes RestorationTrip Panels RestorationElectronics Instruments RestorationFaced Constraints overcomePanel Painting and Control Room face-lifting
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Transmitters
Author:S. Raghava Chari
The pipe elbow burst problem discussed under Mechanical Problems wrecked the NH3 plant control panel instruments also entirely.
The general manager (GM) requested the author Instrument Engineer then to restore the instrumentation by hook or crook to under-platy the situation gravity and for morale-boosting.
Restoration details follow:
The below-listed constraints made the task Difficult, Unattainable, and Despairing Problem (DDUDP).
  1. Potassium carbonate solution drenched and crusted all panel instruments
  2. No spares and manpower help from the panel and instruments supply and erection contractor
  3. Extensively damaged panel rear signal tube bundles
  4. And many more minor items
Yet the author and his team trusting in God and other teams’ whole-hearted cooperation started the job after a vigorous prayer and completed it.
Description follows:
Panel Pneumatic Receivers Restoration proceeded thus:
  1. Crew took out the ‘chassis’ from ten random panel pneumatic receivers and one from undamaged urea plant panel receiver.
  2. All the 2-6 mm small bores interconnecting tubes were found melted. The crew pulled a set out of the urea plant good receiver chassis
  3. A purchase assistant and an instrument mechanic scouted the market and returned with tubes as closely matching the samples – first not feasible problem solved
  4. During this time plant crew detergent washed  the ten soiled chassis and casings in a tub, water washed these in another and dried them in the 70oC set armature drying oven for 3 hours – trial found .
  5. Fortunately, the washed chassis and all components though discolored seemed functional
  6. The crew connected the components using the bought-out tubes.
  7. Lo & Behold! The receiver – chassis and casing assembly – calibrated fine.
  8. Fortunately, panel rear casing plugged controllers did not suffer much damage. Wet cloth wipe was enough to clean them
The assurance that all pneumatic receivers and controllers are restorable boosted the morale so high that they took other jobs too enthusiastically.
An instrument tech and an electrician took out all the panel electronic instruments – temperature recorders and selector switches – and sent them to a firm who helped us with electronic instrument problems.
While the pneumatic and electronic instruments restorations were progressing, the author formed an Instrument Technician and an operator, an Electrician, and an operator team.
The operator closed all field transmitters and valve positioners’ air supplies. He opened e.g. PT 101 air supply.
The instrument technician in the control room would immerse the damaged tube ends in a beaker of water one by one, identified, and tagged as PT 101 the tube that bubbles.
The operator – Electrician team identified and tagged the from the receiver PRESSURE 101 damaged tube end likewise. This laborious process was necessary, as the site assembled tube bundle had no individual tubes identifying number.
They araldite coated the identified tube ends and inserted in a tight-fitting PVC tube for reliable and pull out free joints. Then they confirmed PT 101 connects to PRESSURE 101.
The twine-tied the jointed tubes and wrapped 25 mm wide tightly gripping electrical insulation tape to prevent mechanical damages. Thus, the damaged air signal tubes bundles were ready in 8‑days.
Two nos. two electricians team crew removed the terminals wires connections preserving their original geometry, from the home wired contactor trip panels, took those out, water washed, oven-dried, discarded the existing contactors, positioned new bought out contactors, and connected the wires.
The trip panels were ready in two days.
The electronics expert delivered the electronic temperature recorders, indicators, and selector switches in 8 days. He declined to share his special know-how!
Faced Constraints and overcoming details follow:
  1. Hot K2CO3 distorted receiver panel doors: The instruments manufacturing licensee declared only his principal could supply the plastic doors and delivery time 6 M. As the reasonably clean room housed panel instruments can stand it, the author postponed the job
  2. Receiver Pens: The licensee said the same for pens too. The author got these made by the electrical section cable jointer nick named pen maker (PM) thus:
Make red pen bucket duplicating a store held spare; the PM folded 0.3 mm thick brass sheet as a rectangular bucket as the original and soldered the seams.
He recovered the tubes only from the bought-out syringes discarding the rest, bent like the original, and soldered to the bucket.
In addition, soldered cut portions from discarded steel measuring tapes as pen holders for inserting into receiver arm socket. The red pen is ready.
Likewise, he made green and blue pens also. Required quantities all types of pens were ready in two days
  1. A very cooperative painter from the painting contractor detergent solution mopped the instruments taken out portions followed by water mop and dried the portions using a hair dryer, easy emery cleaned and sprayed two paint coats. Similarly, he painted the panel rear too
  2. Another contactor rough emery cleaned the brick walls and distemper painted
  3. Another contractor installed steel panes in place of the glass panes. He pre-fitted from automobile windshields cut shatter‑proof 150×150 viewing windows on the steel panels.
The plant took these face-lift steps to prevent past gruesome incident reminders and assuring maximum possible safety.
The DDUDP instrumentation restoration was ready in a record 10-days. The plant started with a puja and prasad distribution smoothly.
The share-holding US partner sent the former US citizen General Manager to make sure of necessary plant changes to prevent the accident recurrence. He remarked, “Chari, you and your team have re-built a truck run-over egg; hats off to you and your team.”
Author: S. Raghava Chari
  • Actuator Diaphragm Bursts
  • Control Valves Leak Tightness
  • Over-Capacity Control Valve
  • Control Valve Gland Leaks
  • Transmitter Pressure Correction
Compressor Cracked Shaft Spacers
Fired Boiler Induced Draft Fan (IDF) Failures Upset all Plants Operations
Learnings from the BP Refinery Explosion at Texas City
Automation Panel Electronic Cards Failure investigation
Failed Letdown Valve Shuts down a Urea Plant Several Hours
Seal Level Differential Pressure Transmitter Problems
None Could Repair Slightly Damaged Magnetic Flow Meter Flow Tube
Thermocouple Extension Lead Problem
Replace Failed Motors Quickly and Easily
Gas Cooler Re-tubing Done Successfully (Root Cause Analysis)
Control Valves Leak Tightness Restoration Pose Difficulties
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Serious Constraints Prevent using an Available Turbine Flow Meter
Bently Nevada Proximity Probe
Root Cause Analysis for Vibration Probe Not Responding
Solenoid Valve Failure in Plant Start-Up
Rupture Disc
Rupture Discs bursts caused too many Urea Plant Shutdowns
Mechanical Engineering Plant Problems Solved
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
Arc Fault Breaker (AFB) Electrical Problem Solved
Premature Arc Fault Breaker Failures
Glass Bottle Level Gauge
Antifriction Bearings Caused Machine Changeovers Posed Outages
old Pressure Switches
Pressure Switch Frozen Screwed Cover Extends the Plant Shutdown
Turbine Flow Meter (TFM) Field Calibration
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Digital Electronics Objective Questions – Set 7
Advanced Skills Required for a PLC Programmer to Get a Job
PLC Program to Drain Same Products from Two Tanks
How Twisted Wire Cables Eliminates Noise Voltage
Inductive Coupling Effects
Compare DCS, PLC, RTU
Difference between DCS, PLC, and RTU ?
Power Plant Interview Questions & Answers
Solenoid
Difference between AC and DC Solenoid Valves
Moving Magnet type Velocity Transducer
Moving Magnet Type Velocity Transducer
