Reading: Root Cause Analysis of Differential Pressure Level Transmitter
Inst Tools > Blog > Level Measurement > Root Cause Analysis of Differential Pressure Level Transmitter
Root cause analysis for a differential pressure level transmitter that was installed to measure the level of a tank filled with water.
Last updated: September 19, 2023 3:11 pm
Level Measurement Root Cause Analysis (RCA)
6 Min Read
Today in this article we will discuss the root cause analysis for a differential pressure level transmitter that was installed to measure the level of a tank filled with water.
Differential Pressure Level Transmitter Problem StatementRoot Cause Analysis of Level TransmitterObservationsWhat went wrong?
The DP type level transmitter started showing less value after the preventive maintenance job.
A dry leg DP type level transmitter was installed in a tank that stores water. One leg of the transmitter i.e. high-pressure side is connected to the tank bottom while the other leg i.e. low-pressure side is connected to the top of the tank.
The LP side is dry leg type. The connection is from the top of the tank because the tank receives the water and then supplies the water as per the process need.
Due to this, the tank undergoes pressure change and hence LP side of the transmitter is connected to the top of the tank for reference pressure purposes.
Preventive maintenance was taken for the DP type level transmitter. The level reading before the job was 92 %. The level transmitter was working perfectly. During the preventive maintenance job, the level transmitter was isolated.
The response of the level transmitter was checked. Then after the flushing job, the level transmitter was taken in line. After the preventive maintenance job, the level transmitter was showing 70 % level only. While in the level gauge, the level was 93 %.
So, on a doubt basis of the level gauge, the level gauge was taken for the maintenance job. But still, after completion of the maintenance job on the level gauge, the level was the same i.e. 93 %. But still level transmitter was showing 70 %. After the maintenance job on the level transmitter, the level transmitter was showing a 93 % level.
So what can be the probable reason for water coming out of the LP side of the level transmitter after the Preventive maintenance job?
Probable Problem 1: Actual level was 70 % and after the preventive maintenance job, the level transmitter started showing an ok value.
While confirming the reading with the level gauge, the level was found 93 %. Also, the level gauge was checked and found ok. So this possibility was ruled out.
Probable Problem 2: The level transmitter became faulty
During the preventive maintenance job, the level transmitter’s response was checked. The response of the level transmitter was ok.
Probable Problem 3: Problem in the root valve opening
Both the root valves were found open during checking after the problem was encountered. Both the root valves were found open.
Probable Problem 4: Issue in manifold
Manifold checked after the problem was encountered. Both the isolation valves, vent valves, and equalization valve were found in ok condition.
Probable Problem 5: Leakage in the impulse tubing of the level transmitter
Leakage was checked after the problem was encountered. No leakage was found.
Observations
Observations after taking level transmitter for maintenance job again:
  1. The actual level was the same.
  2. Level transmitter’s response checked. Found ok.
  3. Level transmitter’s both root valves checked. Found ok.
  4. Level transmitter’s manifold valve’s condition checked. Found ok.
  5. The level transmitter’s tube was checked for any leakages. Found no leakage.
  6. While opening the LP side vent plug, found water coming out of the LP leg. LP side flushed and taken inline. Level transmitter started showing 93%.
What went wrong?
As per the technician who did the job, the following activities were done. During the level transmitter preventive maintenance job, the level transmitter was isolated from the root valves.
Then the level transmitter’s response was checked using the pressure calibrator. The response was found ok. Both HP leg and LP leg were flushed and then the transmitter was taken inline.
But while filling the preventive maintenance checklist, the technician observed that he missed zero checking procedures. So he opened the equalization valve and then closed the isolation valves from the manifold.
So in this process, the water from the HP side went to the LP side. After checking zero which was found ok. Then transmitter was taken inline. Now due to the water on the LP side, the level transmitter started showing low values.
  • Level Indicators Working Principle
  • Transparent & Reflex Level Gauge
  • Calculate Current 4-20 mA
  • Level Gauge Design
  • Types of Level Gauges
Ultrasonic Level Transmitter Working Principle
Level Measurement with Dry leg and Installed Below Tapping Point
Carbamate Plunger Pump Packing Problems Eliminated
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
Compressor Anti-Surge Control near-miss incident
Rotary Level Switch Working principle Animation
  • Tejas says:
    February 4, 2023 at 12:26 pm
    We are always facing this issue with DP type level transmitter. We flushed the high level inclined ss line so we get level proper. is there any other solution.
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
Compressor Cracked Shaft Spacers
Non-Contacting Radar Level Transmitter Working Principle
Hydrostatic Tank Gauging (HTG)
what is a Bubbler System?
Problem with Choked Control Valve with Whisper Trim Cage
Pulverizer Electrical Problem Solved
Which Instrument is at Fault in this System?
Closed-tank-DP-Level-Transmitter-with-cleaning-leg-Calibration
Thermocouple Extension Lead Problem
Ultrasonic Level Switch Principle
Interface Level Measurement Selection Guide
Ultrasonic-Level-Transmitter-Animation
Non‐contact RADAR Level Transmitter Pulse
Non Contact RADAR Level Transmitter Principle, Limitations, Design, Installation and Calibration
4 way solenoid valve root cause
Safety Liquid Ammonia Disconnect threatens NH3 Vapor Spill
Electrical Engineering Problems - Root Cause Analysis
30 Electrical Engineering Problems – Root Cause Analysis
What is Chromatography
What is Chromatography ?
Differential Pressure Transmitter Manifold
Field Instrument Calibration Errors
Flip Flops Objective Questions – Part 3
Instrumentation Cyber Security
Instrumentation Cyber Security Glossary
Custody Transfer Meter Checks
Checklist for Custody Transfer Meters: Mass Flowmeter
Transformer Protection using fire water spray system
Fire Water Spray Systems Principle
phototransistor symbols
Phototransistor Working Principle
Types of Fire Detectors
