Reading: 111 Industrial Automation Acronyms Questions and Answers
Inst Tools > Blog > Instrumentation MCQ > 111 Industrial Automation Acronyms Questions and Answers
Learn the meanings of 111 industrial automation acronyms with our detailed questions and answers guide in the automation industry.
Last updated: August 27, 2024 12:52 pm
Instrumentation MCQ
28 Min Read
Industrial Automation AcronymsWhat is the full form of DDC?What is the full form of BPCS?What is the full form of PAC?What is the full form of PLC?What is the full form of HMI?What is the full form of SCADA?What is the full form of VFD?What is the full form of DCS?What is the full form of PID?What is the full form of RTU?What is the full form of I/O?What is the full form of SSR?What is the full form of RJ45?What is the full form of POT?What is the full form of SPDT?What is the full form of PROFIBUS?What is the full form of PROFINET?What is the full form of OPC?What is the full form of MES?What is the full form of CNC?What is the full form of P&ID?What is the full form of BMS?What is the full form of MEMS?What is the full form of IIoT?What is the full form of RTD?What is the full form of PWM?What is the full form of FAT?What is the full form of SAT?What is the full form of EPC?What is the full form of FMEA?What is the full form of SIS?What is the full form of MOSFET?What is the full form of HART?What is the full form of LAN?What is the full form of WAN?What is the full form of USB?What is the full form of RS?What is the full form of ASCII?What is the full form of OLE?What is the full form of DAQ?Industrial Automation Full FormsWhat is the full form of MODBUS?What is the full form of TCP/IP?What is the full form of IEC?What is the full form of ISO?What is the full form of IGBT?What is the full form of SMS?What is the full form of XML?What is the full form of JSON?What is the full form of RFID?What is the full form of SCR?What is the full form of WLAN?What is the full form of RF?What is the full form of LED?What is the full form of LCD?What is the full form of CRT?What is the full form of EEPROM?What is the full form of RAM?What is the full form of ROM?What is the full form of CPU?What is the full form of GPU?What is the full form of FPGA?What is the full form of EMC?What is the full form of EMI?What is the full form of RFI?What is the full form of MTBF?What is the full form of MTTR?What is the full form of OEE?What is the full form of PPE?What is the full form of OSHA?What is the full form of ANSI?What is the full form of CSA?What is the full form of UL?What is the full form of CE?What is the full form of EIA?What is the full form of TIA?What is the full form of NEMA?What is the full form of IP?What is the full form of DIN?What is the full form of JIS?What is the full form of ATEX?Industrial Automation AbbreviationsWhat is the full form of ISA?What is the full form of GAMP?What is the full form of HVAC?What is the full form of FDA?What is the full form of SPD?What is the full form of VSD?What is the full form of SIL?What is the full form of NFC?What is the full form of LVDT?What is the full form of MTU?What is the full form of ICS?What is the full form of MQTT?What is the full form of HTTPS?What is the full form of DMM?What is the full form of UPS?What is the full form of PCB?What is the full form of EX?What is the full form of EOL?What is the full form of HAZOP?What is the full form of SMPS?What is the full form of FET?What is the full form of CAN?What is the full form of SQL?What is the full form of DOL?What is the full form of MCB?What is the full form of MCC?What is the full form of SAP?What is the full form of DCOM?What is the full form of I2C?What is the full form of SPI?What is the full form of UART?
The video below provides the industrial automation acronyms for the first 40 questions.
Question 1
A. Direct Data Communication
B. Digital Data Control
C. Direct Digital Control
D. Distributed Digital Control
Show the Answer
Question 2
A. Base Process Control System
B. Binary Process Control System
C. Basic Process Control System
D. Batch Process Control System
Show the Answer
Question 3
A. Programmable Automation Controller
B. Process Automation Controller
C. Programmable Analog Controller
D. Precision Automation Controller
Show the Answer
Question 4
A. Process Logic Controller
B. Programmable Loop Controller
C. Programmable Linear Controller
D. Programmable Logic Controller
Show the Answer
Question 5
A. Human-Machine Integration
B. Human-Machine Interface
C. Hybrid Machine Interface
D. Hardware Machine Interface
Show the Answer
Question 6
A. Supervisory Communication and Data Analysis
B. System Communication and Data Acquisition
C. System Control and Data Acquisition
D. Supervisory Control and Data Acquisition
Show the Answer
Question 7
A. Variable Frequency Drive
B. Variable Flow Drive
C. Voltage Frequency Drive
D. Variable Flux Drive
Show the Answer
Question 8
A. Decentralized Control System
B. Digital Control System
C. Dynamic Control System
D. Distributed Control System
Show the Answer
Question 9
A. Proportional-Integral-Device
B. Proportional-Integrated-Differentiator
C. Process-Integral-Differential
D. Proportional-Integral-Derivative
Show the Answer
Question 10
A. Real-Time Utility
B. Real-Time Unit
C. Remote Transmission Unit
D. Remote Terminal Unit
Show the Answer
Question 11
A. Internal/Output
B. Input/Output
C. Integrated/Output
D. Input/Operation
Show the Answer
Input/Output
Question 12
A. Single State Relay
B. Semi-State Relay
C. Static State Relay
D. Solid State Relay
Show the Answer
Solid State Relay
Question 13
A. Router Jack 45
B. Relay Jack 45
C. Registered Joint 45
D. Registered Jack 45
Show the Answer
Registered Jack 45
Question 14
A. Potentiometer
B. Position Transducer
C. Power Transformer
D. Potential Meter
Show the Answer
Potentiometer
Question 15
A. Switch Pole Dual Throw
B. Signal Pole Double Throw
C. Single Phase Double Throw
D. Single Pole Double Throw
Show the Answer
Question 16
A. Process Fiber Bus
B. Protocol Field Bus
C. Programmable Field Bus
D. Process Field Bus
Show the Answer
Process Field Bus
Question 17
A. Process Field Net
B. Protocol Field Network
C. Professional Internet
D. Programmable Network
Show the Answer
Process Field Net
Question 18
A. Open Process Communication
B. Object Process Control
C. OLE for Process Control
D. Operational Protocol Control
Show the Answer
Question 19
A. Manufacturing Enterprise Solution
B. Management Execution System
C. Material Execution System
D. Manufacturing Execution System
Show the Answer
Question 20
A. Central Numeric Controller
B. Computer Numerical Control
C. Computer Network Control
D. Controlled Numeric Code
Show the Answer
Question 21
A. Piping and Instrumentation Diagram
B. Pipe and Integration Diagram
C. Process and Integration Diagram
D. Process and Instrumentation Data
Show the Answer
Question 22
A. Base Management System
B. Business Management System
C. Building Maintenance Service
D. Building Management System
Show the Answer
Question 23
A. Micro Electronic Mechanical Systems
B. Miniature Electromechanical Systems
C. Micro-Electro-Mechanical Systems
D. Micro Electromechanical Sensors
Show the Answer
Question 24
A. Integrated Internet of Things
B. Industrial Integration of Technology
C. Industrial Internet of Things
D. Intelligent Internet of Things
Show the Answer
Question 25
A. Reactive Temperature Device
B. Resistance Temperature Detector
C. Real-Time Detector
D. Remote Temperature Device
Show the Answer
Question 26
A. Pulse Wave Modulator
B. Pulse Width Modulation
C. Power Wave Modulation
D. Phase Width Modulation
Show the Answer
Question 27
A. Factory Acceptance Test
B. Field Acceptance Test
C. Final Acceptance Test
D. Functional Acceptance Test
Show the Answer
Question 28
A. System Acceptance Test
B. Standard Acceptance Test
C. Site Acceptance Test
D. Software Acceptance Test
Show the Answer
Question 29
A. Engineering, Production, and Commissioning
B. Engineering, Procurement, and Construction
C. Equipment, Production, and Control
D. Engineering, Planning, and Commissioning
Show the Answer
Question 30
A. Failure Mechanism Evaluation Analysis
B. Fault Monitoring and Error Analysis
C. Failure Mode and Effects Analysis
D. Functional Mode Efficiency Analysis
Show the Answer
Question 31
A. Security Information System
B. Safety Interlock System
C. Safety Instrumented System
D. System Integration Service
Show the Answer
Question 32
A. Metal-Oxide-Semiconductor Functional Electronic Transmitter
B. Metal-Oxide-Semiconductor Field-Effect Transistor
C. Modular-Oxide-Semiconductor Field-Effect Transducer
D. Metallic-Oxide-Semiconductor Fused Element Transistor
Show the Answer
Question 33
A. Highway Addressable Remote Transducer
B. Hybrid Automation Relay Technology
C. High Assurance Relay Transmitter
D. High Accuracy Remote Terminal
Show the Answer
Question 34
A. Logical Access Network
B. Low-latency Area Network
C. Linked Access Network
D. Local Area Network
Show the Answer
Local Area Network
Question 35
A. Wireless Access Network
B. Wide Area Network
C. Wideband Area Network
D. World Access Network
Show the Answer
Wide Area Network
Question 36
A. Unified Serial Bus
B. Universal System Bus
C. Unified System Bus
D. Universal Serial Bus
Show the Answer
Question 37
A. Recommended Standard
B. Registered Specification
C. Relay Standard
D. Regulatory Standard
Show the Answer
Question 38
A. Automated Standard Code for International Information
B. American Standard Code for Information Interchange
C. Automated System for Code Information Integration
D. Advanced Standard Communication Interface
Show the Answer
Question 39
A. Object Library Extension
B. Object Linking and Embedding
C. Open Linking Environment
D. Operational Linking Extension
Show the Answer
Question 40
A. Data Acquisition
B. Digital Acquisition
C. Device Acquisition
D. Data Analysis Query
Show the Answer
Data Acquisition
This industrial automation video provides you the next 40 questions with detailed explanations.
Question 41
A. Modular Bus System
B. Modulated Data Bus
C. Modern Data Bus
D. Modicon Communication Bus
Show the Answer
Question 42
A. Terminal Control Protocol/Internal Protocol
B. Transfer Control Protocol/Internet Package
C. Transmission Communication Protocol/Internet Protocol
D. Transmission Control Protocol/Internet Protocol
Show the Answer
Question 43
A. International Electronics Council
B. Industrial Electrotechnical Committee
C. International Electrotechnical Commission
D. Integrated Electronic Committee
Show the Answer
Question 44
A. International Safety Organization
B. International Standard Operations
C. International Organization for Standardization
D. International Standards Organization
Show the Answer
Question 45
A. Integrated Gate Bipolar Transistor
B. Insulated Gate Bipolar Transistor
C. Inverted Gate Bipolar Transistor
D. Intelligent Gate Bipolar Transistor
Show the Answer
Question 46
A. Secure Messaging System
B. Simple Message System
C. Standard Messaging Service
D. Short Message Service
Show the Answer
Question 47
A. Extensible Markup Language
B. Extra Markup Language
C. External Markup Language
D. Extended Markup Language
Show the Answer
Question 48
A. JavaScript Operational Notation
B. Java Serialized Object Notation
C. JavaScript Object Notation
D. Java Standard Object Notation
Show the Answer
Question 49
A. Radio Frequency Identification
B. Random Frequency Identification
C. Remote Frequency Identification
D. Registered Frequency Identification
Show the Answer
Question 50
A. Silicon Conduction Regulator
B. Semiconductor Controlled Relay
C. Silicon Controlled Rectifier
D. Sequential Control Regulator
Show the Answer
Question 51
A. Wide Local Area Network
B. Wireless Linked Area Network
C. Wideband Local Access Network
D. Wireless Local Area Network
Show the Answer
Question 52
A. Rapid Frequency
B. Radio Frequency
C. Resonant Frequency
D. Radiant Frequency
Show the Answer
Radio Frequency
Question 53
A. Light Emission Display
B. Light Emitting Diode
C. Light Enhancement Device
D. Low Energy Diode
Show the Answer
Question 54
A. Liquid Crystal Display
B. Linear Crystal Display
C. Liquid Cathode Display
D. Light Crystal Display
Show the Answer
Question 55
A. Cathode Radiant Tube
B. Cathode Ray Tube
C. Cathode Radiation Tube
D. Cathode Ray Transmitter
Show the Answer
Cathode Ray Tube
Question 56
A. Electrically Enabled Programmable Read-Only Memory
B. Electronically Erased Programmable Read-Only Memory
C. Electrically Erasable Programmable Read-Only Memory
D. Electrically Embedded Programmable Read-Only Memory
Show the Answer
Question 57
A. Readily Available Memory
B. Rapid Access Memory
C. Read-Only Access Memory
D. Random Access Memory
Show the Answer
Question 58
A. Readable Output Memory
B. Read-Only Memory
C. Random Output Memory
D. Rapid Operation Memory
Show the Answer
Read-Only Memory
Question 59
A. Core Processing Unit
B. Central Programming Unit
C. Central Processing Unit
D. Computer Processing Unit
Show the Answer
Question 60
A. Graphics Peripheral Unit
B. General Processing Unit
C. Graphic Performance Unit
D. Graphics Processing Unit
Show the Answer
Question 61
A. Field Programmable Gate Array
B. Fixed Programmable Gate Array
C. Flexible Programmable Gate Array
D. Fast Programmable Gate Array
Show the Answer
Question 62
A. Electronic Mechanical Compatibility
B. Electromagnetic Compatibility
C. Electromechanical Compatibility
D. Electromagnetic Circuit
Show the Answer
Question 63
A. Electromagnetic Interference
B. Electromechanical Interference
C. Electromagnetic Integration
D. Electrical Magnetic Interference
Show the Answer
Question 64
A. Remote Frequency Interference
B. Radiant Frequency Interference
C. Radiant Field Interference
D. Radio Frequency Interference
Show the Answer
Question 65
A. Maximum Time Before Failure
B. Mean Time Between Failures
C. Median Time Before Failure
D. Mean Time Before Fault
Show the Answer
Question 66
A. Maximum Time to Repair
B. Median Time to Repair
C. Minimum Time to Repair
D. Mean Time to Repair
Show the Answer
Mean Time to Repair
Question 67
A. Operational Effectiveness Evaluation
B. Operational Equipment Efficiency
C. Overall Equipment Effectiveness
D. Overall Efficiency Evaluation
Show the Answer
Question 68
A. Personal Performance Equipment
B. Public Performance Equipment
C. Public Protection Equipment
D. Personal Protective Equipment
Show the Answer
Question 69
A. Occupational Safety and Health Agency
B. Organizational Safety and Health Administration
C. Occupational Safety and Health Administration
D. Occupational Standards and Health Administration
Show the Answer
Question 70
A. American National Standards International
B. American National Safety Institute
C. American National Standards Integration
D. American National Standards Institute
Show the Answer
Question 71
A. Canadian Standards Association
B. Canadian Standardized Association
C. Canadian Safety Association
D. Canadian Standards Alliance
Show the Answer
Question 72
A. Universal Laboratories
B. Underwriters Laboratories
C. United Laboratories
D. Uniform Laboratories
Show the Answer
Question 73
A. Compliance European
B. Certified European
C. Conformité Européenne
D. Conformance European
Show the Answer
Question 74
A. Electrical Industries Alliance
B. Electrical Integration Association
C. Electronic Industries Alliance
D. Electronic Information Association
Show the Answer
Question 75
A. Technology Information Association
B. Technical Integration Association
C. Telecommunications Industry Association
D. Telecommunication Integration Alliance
Show the Answer
Question 76
A. National Electronic Manufacturers Association
B. National Electrical Maintenance Association
C. National Electrical Manufacturers Association
D. National Electromechanical Association
Show the Answer
Question 77
A. Insulation Protection
B. Industrial Protection
C. Ingress Protection
D. Internet Protocol
Show the Answer
Ingress Protection
Question 78
A. Dynamic Integration Norms
B. Digital Integration Network
C. Deutsches Institut für Normung
D. Data Interface Network
Show the Answer
Question 79
A. Japanese Integration Standards
B. Japanese Industrial Standards
C. Joint Industry Standards
D. Japan International Standards
Show the Answer
Question 80
A. Automated Explosion
B. Atmosphères Explosibles
C. Atmospheric Explosion
D. Atmospheric Testing Explosive
Show the Answer
This below video provides you the explanations for the remaining questions.
Question 81
A. Industrial Standards Association
B. Industrial Society of America
C. International Society of Automation
D. International Standards Association
Show the Answer
Question 82
A. Good Automated Machine Practice
B. General Automated Manufacturing Procedure
C. Good Automated Manufacturing Practice
D. Global Automated Manufacturing Process
Show the Answer
Question 83
A. High Velocity Air Conditioning
B. Heating, Ventilation, and Air Conditioning
C. Heating, Vacuum, and Air Conditioning
D. Heating, Ventilation, and Atmosphere Control
Show the Answer
Question 84
A. Food and Dietary Association
B. Food and Drug Administration
C. Federal Dietary Administration
D. Federal Drug Administration
Show the Answer
Question 85
A. System Protection Device
B. Safety Protection Device
C. Standard Protection Device
D. Surge Protection Device
Show the Answer
Question 86
A. Voltage Supply Drive
B. Variable Supply Drive
C. Voltage Speed Drive
D. Variable Speed Drive
Show the Answer
Question 87
A. Safety Integration Level
B. System Integrity Level
C. Safety Integrity Level
D. Security Integrity Level
Show the Answer
Question 88
A. Near Field Communication
B. Network Field Communication
C. Network Frequency Communication
D. Near Frequency Communication
Show the Answer
Question 89
A. Linear Variable Differential Transformer
B. Long Variable Differential Transformer
C. Linear Voltage Differential Transducer
D. Linear Variable Displacement Transducer
Show the Answer
Question 90
A. Main Transmission Unit
B. Multi-Terminal Unit
C. Modular Terminal Unit
D. Master Terminal Unit
Show the Answer
Question 91
A. Intelligent Control System
B. Industrial Communication System
C. Industrial Control System
D. Integrated Control System
Show the Answer
Question 92
A. Multi-Queue Telemetry Transport
B. Message Queuing Telemetry Transport
C. Message Queue Telemetry Transfer
D. Multi-Queue Transmission Transport
Show the Answer
Question 93
A. Hyperlink Transfer Protocol Secure
B. Hypertext Transmission Protocol Secure
C. Hypertext Transfer Protocol Secure
D. Hyperlink Transmission Protocol Secure
Show the Answer
Question 94
A. Direct Measurement Meter
B. Digital Multimeter
C. Direct Multimeter
D. Digital Measurement Module
Show the Answer
Digital Multimeter
Question 95
A. Universal Power Source
B. Unitary Power Supply
C. Uninterruptible Power Supply
D. Uninterrupted Power System
Show the Answer
Question 96
A. Printed Circuit Board
B. Programmable Control Board
C. Primary Circuit Board
D. Power Control Board
Show the Answer
Question 97
A. External Protection
B. Extra Protection
C. Extreme Protection
D. Explosion-Proof
Show the Answer
Explosion-Proof
Question 98
A. Electronic Output Line
B. Equipment Output Line
C. Edge of Line
D. End of Line
Show the Answer
End of Line
Question 99
A. Hazard and Operability Study
B. Hazard Analysis Operation
C. Hazardous Operations Plan
D. Hazard Observation Protocol
Show the Answer
Question 100
A. Steady Mode Power Supply
B. Switched-Mode Power Supply
C. Static Mode Power Supply
D. Secure Mode Power Supply
Show the Answer
Question 101
A. Flexible Electronic Transistor
B. Field Emission Transistor
C. Field Effect Transistor
D. Fast Emitting Transistor
Show the Answer
Question 102
A. Computer Area Network
B. Controller Area Network
C. Centralized Access Network
D. Communication Area Network
Show the Answer
Question 103
A. Simple Query Language
B. Systematic Query Language
C. Structured Query Language
D. Standard Query Language
Show the Answer
Question 104
A. Digital Output Line
B. Direct Operational Line
C. Dynamic Output Line
D. Direct On-Line Starter
Show the Answer
Question 105
A. Modular Circuit Breaker
B. Main Control Breaker
C. Miniature Circuit Breaker
D. Micro Circuit Breaker
Show the Answer
Question 106
A. Motor Control Center
B. Modular Control Center
C. Motor Coordination Center
D. Main Control Cabinet
Show the Answer
Question 107
A. Systems, Applications, and Products in Data Processing
B. Systematic Applications in Programming
C. Standardized Applications and Processes
D. Secure Applications in Programming
Show the Answer
Question 108
A. Distributed Component Object Model
B. Data Communication Object Model
C. Dynamic Component Object Model
D. Digital Component Object Model
Show the Answer
Question 109
A. Integrated Interface Controller
B. Inter-Integrated Circuit
C. Internal-Integrated Circuit
D. Interfacing Integrated Circuit
Show the Answer
Question 110
A. Standard Peripheral Interface
B. Serial Peripheral Interface
C. System Peripheral Interface
D. Synchronous Peripheral Interface
Show the Answer
Question 111
A. Universal Automatic Receiver-Transmitter
B. Unified Asynchronous Receiver-Transmitter
C. Universal Asynchronous Receiver-Transmitter
D. Unidirectional Asynchronous Receiver-Transmitter
Show the Answer
  • Electrical Engineers Objective Questions and Answers
  • Industrial Electronics Objective Questions and Answers
  • Digital Circuits Objective Questions and Answers
  • Electrical Measurement Objective Questions and Answers
  • Electronic Circuits Objective Questions and Answers
Process Control & Instrumentation Objective Questions – Set 2
Beam Balance Systems Objective Questions
DCS Quiz
Online Analyzers Questions & Answers
Temperature Balance System Objective Questions
Bio Sensors Objective Questions
Sensors and Transducers Test
Ultrasonic Sensors Objective Questions
Electrical and Instrumentation Test
Fluidic Systems Objective Questions
Biomedical Instrumentation Objective Questions
Resistive Transducers Objective Questions
Analog Demodulators Objective Questions
Measurements & Instrumentation Quiz – Set 5
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Semiconductor Sensors Objective Questions
AI AO DI DO Questions
Measurement of Resistance Objective Questions
Process Control & Instrumentation Objective Questions – Set 4
Multiple Choice Questions on Sensors & Transducers
MCQ on Measurement and Instrumentation
BCD Adder Objective Questions
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
Electrical Terminology
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
Electro Chemical Transducers Objective Questions
Reliability Centered Maintenance (RCM)
What is Reliability Centered Maintenance? (RCM)
Basic Process Control Loop
Introduction to Industrial Instrumentation
