Reading: Erratic H2 Flow Rotameter
Inst Tools > Blog > Root Cause Analysis (RCA) > Erratic H2 Flow Rotameter
Erratic H2 flow rotameter readings prevented newly charged catalyst reduction and delayed Reformed Gas Production.
Last updated: September 28, 2022 2:55 pm
S Raghava Chari
2 Min Read
Instrumentation engineering root cause analysis of erratic reading of H2 flow rotameter.
Flow Rotameter ProblemInstrument Crew’s difficultiesPipe fitters’ woesAuthor Solution
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Sensors
Author:S. Raghava Chari
The instrument crew complained about the pipe fitter’s inability to make the ¾ pipe exactly vertical. Hence, stuck rotameter float and unreliable readings
Pipe fitters’ woes
They too expressed the near impossibility of the slender ¾” pipeline ‘rotameter plumb’. Even if they achieve it, it does not stay that way!
Author Solution
He told the Instrument crew to do the following:
  1. Workshop to make a 2” pipe stand to mount the rotameter using instrument engineer given sketch
  2. Miscellaneous contractor to grout it vertically to the cement floor under instrument engineer supervision
  3. Instrument crew to bolt the rotameter on the stand vertical and lock the fasteners with lock nuts
  4. Pipe fitters to connect the pipe flanges to the rotameter strain free i.e. just by hand position the pipes to match the rota meter flanges
Problems vanished and reformer started smoothly.
Author: S. Raghava Chari
  • Level Transmitters Zero Drifts
  • Target Flow Transmitters Failed
  • Pitot-tube Replaced with Orifice
  • Mechanical Temperature Indicator
  • Seal Pressure Instruments Problems
Too Low-Temperature Readings after a Failed Thermocouple Change
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Hunting of Control Valves
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
HT Motor Direction of Rotation (DOR) Changed
Stuck Segment Orifice Dimensions Calculations
[RCA] Pump Low throughput Eliminated
Pressure Correction Pneumatic Instrumentation
Problems with Demister Pads – Root Cause Analysis (RCA)
Root Cause Analysis of Differential Pressure Level Transmitter
Compressor IP Case Discharge Temperature Gradually Increases
Control Valves – Repeat Actuator Diaphragm Bursts
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Thermowell Shank to Flange Repeat Weld Leaks
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Jacket Added Seawater Pipe Spool
Seawater Pipeline Spools from day-1 leaks threaten Plant Shutdown
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
Packing Compressing Die Set
Carbamate Plunger Pump Packing Problems Eliminated
Rotary Granulator Drive
Rotary Granulator Drive Root Cause Analysis (RCA)
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
RF and RTJ Flange Installed Gasket
Flange Joint Errors shutdowns root cause analyzed and eliminated
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Forward reverse motor control diagram with timer
Timer during Motor Direction Change PLC Program
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
Magnetic Float Level Sensor Principle
Magnetic Float Level Transmitter Working Principle
Power Electronics Diode Circuits Quiz
Ethernet IP Commissioning Tool software
How to Configure IP Address in Rockwell PLC?
Magnetic Tape Recorder Principle
What is Magnetic Tape Recorder ?
PLC Logic to identify empty bottles in Packing
Automatic Empty Bottle detection using PLC Logic
PLC Valve Control Example
Create a Function (FC) for a Valve Logic in Siemens PLC
