Reading: Types of Flow Meters
Inst Tools > Blog > Flow Measurement > Types of Flow Meters
Types of flow meters are divided into two groups. One measures quantity (Positive Displacement); the other measures rate of flow (Inferential).
Last updated: October 31, 2023 2:22 pm
Flow Measurement
Types of flow meters are divided into two functional groups
Types of Flow MetersPositive Displacement (Quantity Meters)Inferential (Rate Meters)(a) Orifice Plates(b) Flow Nozzles and Venturi Tubes(c) Pitot Tubes(d) Turbine Meters(e) Swirlmeters, Vortex Shedding Meters, Rotameters, Mass Flow Meters, etc
  1. One measures quantity (Positive Displacement);
  2. the other measures rate of flow (Inferential)
All fluid meters, however, consist of two distinct parts, each of which has different functions to perform.
The first is the primary element, which is in contact with the fluid, resulting in some form of interaction. This interaction may be that of imparting motion to the primary element; the fluid may be accelerated etc.
The second or secondary element translates the interaction between fluid and primary element into a signal that can be converted into volume, weights or rates of flow and indicates or records the results.
For example, a weigher uses weighing tanks as its primary element and a counter for recording the number of fillings and dumpings as its secondary element.
In an orifice meter, the orifice together with the adjacent part of the pipe and the pressure connections, constitute the primary element, while the secondary element consists of a differential pressure device together with some sort of mechanism for translating a pressure difference into a rate of flow and indicating the result, in some cases also recording it graphically and integrating with respect to the time.
This same combination of primary and secondary elements will be observed in almost all other types of meters.
Some of the more common positive displacement meters are:
Read the detailed articles –
  • Weighers
  • Reciprocating Piston
  • Rotating Piston
  • Nutating Disk
  • Sliding and Rotating Vanes
  • Gear
  • Lobed Impeller
the flow meter most commonly used to sell small quantities of gas at relatively low flow rates, the Bellows meter.
The inferential flow meters are listed below.
(a) Orifice Plates
The most commonly used rate or inferential meter is the thin-plate, concentric orifice.
Flow Nozzles and Venturi Tubes are primary rate devices which will handle about 60% more flow than an orifice plate for the same bore under the same conditions, and can therefore handle higher velocity flows. If a differential limit is chosen, then a smaller bore nozzle or Venturi may be used to measure the same flow.
They are more expensive to install and do not lend themselves to as easy size change or inspection as orifice plates.
(c) Pitot Tubes
A Pitot or impact tube makes use of the difference between the static and kinetic pressures at a single point.
A similar device which is in effect a multiple pitot tube, averages the flow profile.
(d) Turbine Meters
A Turbine meter is one in which the primary element is kept in rotation by the linear velocity of the stream in which it is immersed.
The number of revolutions the device makes is proportional to the rate of flow.
These are devices that have similar applications in flow measurement.
  • Swirl Meters
  • Vortex Meters
  • Rotameters
  • Mass Flow Meters
What is a Positive Displacement Flow Meter?
What is a Flow Element? – Types, Comparison of Flow Elements
What is a Coriolis Flow Meter?
How does an Orifice Measures Flow?
Ultrasonic Flow Meters Working Principle
Difference between Different Types of Flow Meters
  • Vinoth Kumar T says:
    August 3, 2019 at 11:53 pm
    Sir
    How to download documents this topics on your app if any options pls suggestions for me
    Thank you
What is a Ultrasonic Flow Meter?
Types of Vortex Flow Meter Sensors
Transit Time Flow Meter – Types, Advantages, Disadvantages
Square-Root in DCS or Flow Transmitter?
What is Gas Meter and Regulating Station?
Oscillating Piston Flow Meters Working Principle
Read Gas Composition from Gas Metering System using RS485 Protocol
What are Multiphase Flow Meters? – Working Principle, Advantages
Impeller Flow Sensor
Impeller Flow Sensor Working Principle and Animation
Thermal Dispersion Flow Switch Working Principle
Coriolis Flow Meter Inaccuracy
Coriolis Flow Meter Uncertainty and Inaccuracy
Heat Tracing Problems
Gas and Liquid Measurement
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
What is a Condensate Pot? How to Install it?
Turbine Flow Meter Installation Procedure
Dependent Current Source
Sensors and Transducers Classification
Solve Pressure Control System Problems
psv-principle-of-operation
Instrumentation Inspection Report
water seal drum lever transmitter
Determine LRV and URV settings for the Level Transmitter
Fisher model 546 I to P transducer
Fisher model 546 I/P transducer
RSLogix5000 PLC Program Backup procedure
Rupture Disc
Rupture Discs bursts caused too many Urea Plant Shutdowns
