Reading: Tagging Philosophy for Junction Box, Cable, and Cable Drum
Inst Tools > Blog > Instrumentation Design > Tagging Philosophy for Junction Box, Cable, and Cable Drum
In this article, we are going to discuss the tagging philosophy for junction boxes, cables, and cable drums.
Last updated: October 17, 2023 3:42 pm
Tagging of the junction box, cables, and cable drums is very important during front-end engineering design for the preparation of the JB schedule, cable schedule, cable drum schedule, etc.
Junction Box TaggingUnit NumberJunction Box CodeJunction Box ScheduleCable TaggingField Instrument to Junction BoxJunction Box to Control RoomCable ScheduleInstrument Cable Drum TaggingCable CodeCable Drum Schedule
Junction Box Numbering
The given above is the basic structure of junction Box tagging philosophy
It includes,
  • Unit Number
  • Junction Box Code
  • Sequence Number
Unit Number
Refer to the below article for details regarding the unit number
Instrument Numbering Philosophy
Junction Box Code
Each junction box is associated with an instrumented facility comprising of a series of letters depicting that junction box details based on the type of signals.
Below table indicates some of the junction box types
LETTERTYPE OF SIGNAL
JBAAlarm (BPCS)
JBEAnalogue (BPCS)
JBSControl – Solenoid Outputs (BPCS)
JBFFFieldbus Foundation (BPCS)
JBAXAlarm (SIS)
JBEXAnalogue (SIS)
JBSXControl – Solenoid Outputs (SIS)
JBAFAlarm (F&G)
JBEFAnalogue (F&G)
JBPFPower (F&G)
Also Read: Instrumentation Project Documents
Reference drawings required for the preparation of the JB Schedule are
  • Specifications for instrument junction boxes
  • Specifications for cable glands
  • Instrument cable schedule
  • Junction box tagging philosophy
Cable Tagging
The below discussed the different ways where we used the cable tagging.
Individual cables running between field instruments and junction boxes are normally identified by the instrument tag number itself.
Example:
Field Instrument Unit Number
The below image shows the basic structure of cable tagging for cables from the junction box to the control room.
Basic Structure of Cable Tagging for Cables
It includes,
  • Unit Number
  • Junction Box Code
  • Sequence Number of Cable
  • Cable Suffix
Cable Schedule
Signal Cable Schedule
Reference drawings required for the preparation of the cable schedule are
  • Instrumentation Index
  • Cable Tagging Philosophy
  • Cable and Junction Box Specification
  • Instrumentation Design Basis
Given above is the basic structure of the Instrument cable drum numbering system.
It includes,
  • Zone
  • Cable Drum Number
  • Sub-Contractor Name
  • Cable Code
  • Sequence Number
Cable Code
Cable code indicates all details regarding that cable type. There is always a description associated with each cable code.
Given below is an example of cable type and description
Cable Code
Zone details and subcontractor details are entered as per the project execution details.
Cable Drum Schedule
Cable Drum Schedule
Reference drawings required for the preparation of cable drum schedule are,
  • Specification for Instrument Cables
  • Cable Drum Tagging Philosophy
  • Instrument Cable Schedule
  • Instrument Index
  • Fire & Gas Index
Author: Greeshmesh TP
  • SIL Verification
  • How to Choose UPS?
  • Instrument Junction Box
  • Instruments Tapping Points
  • Instrumentation Design Engineer
Major issues for Sensors Selection
4-20 mA Loop Splitter
Where should we Terminate the Cable Shields ?
Instrument Junction Box Specification
What to Choose RTD or Thermocouple ?
% of Reading vs. % of Full Scale Accuracy
How to Prepare Pressure Gauge Datasheet ?
Electrical Signal and Control Wiring
How to Select Right Thermocouple & Thermowell ?
Why we use NAMUR Output Sensor?
Cable Screen shall not be Grounded at Field Device ?
How Earth Resistance is Measured
List of Instrumentation Project Engineering Documents
Pressure Gauge Maintenance and Troubleshooting
Inter Discipline Check (IDC)
What is Inter Discipline Check (IDC)?
Poppet vs Spool Valves
Why Valve Type Matters ? Poppet vs Spool Valves
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
on off valve actuator
How to Select an Actuator for Valve
Magnetic Flow Meters
Control System Vendor Internal Test Procedures
Vendor View of Supplying Industrial Process Control & Safety Systems
control-valve-actuators
Control Valve Selection Tips
Instrumentation Design Details
Unmanaged Switch
Managed Switch vs Unmanaged Switch
Digital Image Processing Projects - DIP Project Ideas
600+ Digital Image Processing Projects – DIP Project Ideas
Electronic Devices & Circuits Quiz – Set 2
Micro-impulse Level Transmitter Principle
Annubar Flow Meter Principle
Annubar Flow Meter – Principle, Advantages, Disadvantages
testing-thermocouples-and-rtds
Testing thermocouples and RTDs using Multi-function Calibrators
PLC program for Latching and unlatched circuit
