Reading: Solenoid Valves Terminology
Inst Tools > Blog > Control Valves > Solenoid Valves Terminology
Last updated: April 13, 2019 2:25 pm
Control Valves Solenoid Valve
2 Comments
3 Min Read
A solenoid valve is a combination of two functional units:
SOLENOID VALVE TERMINOLOGYCoilCoreCore springCore tubeCoverDiaphragmDisc, valve discManual operatorManual operator springOrificesPlug-nutRetainer clipRockerSeating or valve seatSolenoid enclosureValve body
  1. A solenoid operator essentially consisting of a coil, core, core tube, shading coil and spring(s).
  2. A valve body containing orifices in which a disc, diaphragm or piston etc. is positioned according to the type of technology used.
The valve is opened or closed by movement of the magnetic core which is drawn into a solenoid when the coil is energized.
Coil
Electrical part of the valve consisting of a spool wound with insulated copper wire creating a magnetic flux when energised. The coil is held in place on the tube with a retaining clip.
Core
Soft-magnetic plug-nut moved by magnetic forces (flux generated by the coil).
Core spring
Spring which keeps the core in fixed position when the coil is de-energised.
Core tube
Stainless steel tube closed at one end, in- stalled to improve the magnetic flux of the solenoid coil upon energisation
Cover
Cover mounted on the valve body and incorporating a number of orifices.
Diaphragm
Seal-tight diaphragm isolating the fluid from the control system.
Disc, valve disc
Sealing material on the core or disc-holder which shuts off the seat orifice.
Manual operator
Manual operation of the lever to open or close the orifices.
Drawback spring ensuring return of the pulse control device to its initial position
Orifices
Orifices for fluid transit.
Plug-nut
Stationary core pressed in the closed end of the core tube, installed to improve the magnetic flux of the solenoid coil upon energisation.
Retainer clip
Clip anchoring the coil to the yoke.
Rocker
Moving part serving to open and close the orifices for the passage of fluid.
Specially formed border of the main valve.
Solenoid enclosure
Metal housing around the coil for electrical and mechanical protection, as well as protection against ingress of water or dust.
Valve body
Main part of the valve with all ports and main seats
Articles You May Like :
4-way Solenoid Valve
4 Way Valve Animation
Globe Valve Body Design
Solenoid Valve Troubles
What is Ball Valve ?
Ball Valve Material Selection
Solenoid Valves Types & Functions
Solenoid Valve Problems and Solutions
Basic Steps and Procedure for the Repair of Control Valve
Basics of Butterfly Valves
Pneumatic Piping Design and Specification
2 Comments
  • Wrubel says:
    August 7, 2015 at 11:35 pm
    I’m glad I came across this post. Emailed it to myself to learn afterwards from my desktop. Will try for connecting with you on Facebook then too.
  • hossein says:
    December 3, 2016 at 7:41 am
    hi reddy, thanks very much, great.
Difference between BDV and PSV
PID Controller Action : Directing Acting & Reverse Acting
How to Choose a Control Valve?
Solenoid Valve Troubleshooting Tips
Basics of Valves
Pneumatic Directional Control Valves
Constant Flow Valve Principle
Control Valves Mechanical Friction Problems
How to Remove Control Valve Stem Packing Procedure
The Replacement Procedure for Control Valve Stem Packing
valve trim
Valve Actuator Bench Set
Solenoid Valve Failure in Plant Start-Up
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Online Testing of Solenoid Valve
Design and Accessories Required for Online Testing of Solenoid Valve
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
Chocked flow
Control Valve Cavitation and Flashing
JT Valve Working Principle
What is a Pilot Valve?
What is a Pilot Valve? When do we use a Pilot Valve?
Reset Logic for pump Run Hours
PLC Program to Count Running Hours of any Equipment
Commissioning Checklist for Industrial Automation System
Commissioning Checklists for Industrial Automation Systems
Difference Between Passive and Active Fire Protection
Active and Passive Fire Protection
PLC Logic to identify empty bottles in Packing
Automatic Empty Bottle detection using PLC Logic
Pressure Measurement Objective Questions
Choke Valve Hydro Test Setup
Choke Valve Hydro Testing Procedure
Solenoid-controlled Valve Problem
