  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: PLC Selective Execution of the Application – Example Program
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > PLC Selective Execution of the Application – Example Program
Implement the PLC program selective execution of the application using a ladder programming language.
Last updated: November 3, 2023 2:07 pm
3 Min Read
This is a PLC Program for the selective execution of the application.
Selective Execution of an ApplicationProblem DiagramProblem SolutionList of Inputs/OutputsInputs ListOutputs ListLadder Diagram for Selective Execution of the ApplicationProgram DescriptionNetwork 1Network 2Network 3Result
Problem Description
There are pigments of three colors. We need to fill different pigments into the jar by selecting the selector switches.
Implement the PLC program using a ladder programming language.
Problem Diagram
PLC Program for Selective Execution of the Application
Problem Solution
In this system, we will consider S7-300 PLC and TIA portal software for programming.
Here we need to fill different pigments in the jar as per requirement. So consider 3 types of different color pigments (Yellow, blue, and green.).
Two valves are used for controlling the pigments. (As we know mixing of yellow and blue is green color so there is no need of separate valve for green color.)
When both yellow and blue color are filled at the same time, it will become green color. Selector switch is used for color selection in the system and ON/OFF switch is used for system STOP.
Inputs List
  • ON/OFF :-  I2.0
  • START PB :- I0.0
  • STOP PB :- I0.1
  • Yellow pigment selection :- I0.2
  • Blue pigment selection :- I0.3
  • Green pigment selection :- I0.4
Outputs List
  • Cycle ON :- Q0.0
  • Yellow control valve :- Q0.1
  • Blue control valve :- Q0.2
PLC Selective
PLC Selective Execution Example
Program Description
Network 1
When ON/OFF switch (I2.0) is ON and START PB is pressed, Cycle ON (Q0.0) lamp will be ON.
Network 2
If cycle is ON and yellow color pigment is selected (I0.2), yellow color control valve (Q0.1) will be ON.
Network 3
If cycle is ON and blue color pigment is selected (I0.3), blue color control valve (Q0.2) will be ON. If green color pigment is selected (I0.4), both the valves will be ON and pigment will become green color.
Result
PLC Selective Example
Author: Bhavesh
  • PLC Control Valve Scaling
  • Split Range Control Application using PLC
  • Opposite Acting Control Valves using PLC
  • Siemens S7 1200 PLC configuration in TIA Portal
  • PLC Program for Paint Spraying
Recommended Articles
Quiz: Identifying I/O Examples in PLC Systems
Allen Bradley PLC ControlLogix Hardware
Difference Between CompactLogix and ControlLogix
Sequential Operation of Output Bits using Two Push buttons
How to Use the Shift and Rotate Instructions in PLC?
PLC Program for Boolean Expression
208kSubscribersSubscribe
Recent Comments
Related Articles
Counter Count Down Bit
Down Counter PLC Program
Tags in Functional Block Diagram in Studio 5000
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
Machine Indicator Lights PLC Programming Solution
Door Locking System - PLC Applications Examples
PLC Training Course
#17 PLC Best Practices – Log PLC Uptime and Trend it on HMI
T-Junction Traffic Control System
T-Junction Traffic Control System – PLC Programming
Parts of PLC
Parts of PLC
PLC program to control a water pump
PLC Program to Control a Water Pump
More Articles
Total Resistance in a Parallel Circuit
Resistance in Parallel Circuits
Pressure Switch Construction
Basics of Pressure switches
ATEX Certification Codes
Understanding Hazardous Area Classification
What is Open Telemetry?
What is Open Telemetry? – Principles and Benefits
Things to Take Care of When Designing SCADA System
UV Visible Spectrometers Questions and Answers
What is the consumed tag in Studio 5000 software?
Produced Tags and Consumed Tags in Studio 5000
Measure Frequency using Multimeter
How to measure frequency using Multimeter
