Reading: PLC Logic for Automatic Bending Machine for Exhaust Pipe
Inst Tools > Blog > PLC Tutorials > PLC Logic for Automatic Bending Machine for Exhaust Pipe
Last updated: March 4, 2021 4:21 pm
3 Min Read
Automatic bending machine
This is PLC Program for automatic bending machine for exhaust pipe.
Automatic bending machineProblem DescriptionProblem DiagramSolutionList of Inputs/OutputsLadder diagram for Automatic Bending MachineProgram Description
Problem Description
The bending of exhaust pipes is to be controlled using PLC. The bending procedure must not start unless both the pipe and connector fitting are present. If a part is defective or not present this is indicated by an indicator light.
Write PLC program for this application using ladder diagram language.
Problem Diagram
Automatic bending machine for exhaust pipe
Solution
  • A proximity switch is used to detect weather a pipe is present or not. Then pipe will be clamped in position via the solenoid valve.
  • And if the connector fitting is also present, bending process will be ON after 2 second.
  • If pipe is not detected for 5 second, error lamp will glow and it can be acknowledged by pressing acknowledge button.
List of Inputs
  • I0.0 :- Start PB
  • I0.1 :- Stop PB
  • I0.2 :- Pipe detected
  • I0.3 :- Connector detected
List of Outputs
  • Q0.0 :- Cycle ON
  • Q0.1 :- Clamping ON
  • Q0.2 :- Error lamp
Program Description
In this program we have used Siemens S7-300 PLC and TIA Portal Software for programming.
Network 1 :-
Main cycle can be started by pressing start PB (I0.0).And can be stop by pressing stop PB (I0.1).
Network 2 :-
When exhaust pipe and connector are detected, after 2sec clamping process (Q0.1) will be ON.
Network 3 :-
If cycle is not ON or pipe is not detected, clamping Q0.1) will be OFF.
Network 4 :-
If pipe is not detected for 5 sec, error lamp (Q0.2) will be ON.
Network 5 :-
Error lamp (Q0.2) can be acknowledged by pressing acknowledges PB (I0.3).
Note :- Above application may be different from actual application. We can also make this application by using other PLC also. This example is only for explanation purpose. This is the bending machine for exhaust pipes in industries; we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author : Bhavesh
PLC Selective Execution of Application
DCS versus PLC Architecture
PLC Sequential Motor Control
Tank Heating Control using Heater
PLC Separate Different Size Objects
PLC Question Bank
PLC Code to Start & Stop Motor and Pump as per Logic
PLC Program for Automatic Bottle Rejection System
PLC Power Supply and Operating Voltages
MCQ on PLC (Programmable Logic Controller)
Structured Text PLC Example for Motor Interlocking and Control
Industrial Networking and Wireless Interview Questions
PLC Analog Input Card Resolution Effects on Accuracy
How to Run Multiple Motors with a Single VFD?
PLC Math instructions
What is PCS 7?
How to Filter Digital and Analog Inputs in a PLC
How to Filter Digital and Analog Inputs in a PLC?
Ladder Diagram circuit
PLC Practice Questions
Allen-Bradley SLC 500
History of Programmable Logic Controllers (PLC)
What is a function call in TIA Portal
Difference Between FC and FB in Tia Portal
STL Programming - SET, RESET, ASSIGN
STL Programming – SET, RESET, ASSIGN
Basics of Sinking and Sourcing
Architecture of Allen Bradley PLC
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
How to Upload PLC Program in Siemens PLC if Upload Icon is Disabled
Upload Option Disabled in Siemens PLC
Crowbar fault protection circuit
Single Line Diagram (SLD) Example
Electrical Drawings
Color detection PLC logic
Conveyor Sorting System with Color Detection PLC Logic
Simple Three Digital Electronic Project Ideas
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
Process Variable Damping Graph
Process Variable Damping of Transmitter
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
