Reading: Fired Boiler Induced Draft Fan (IDF) Failures Upset all Plants Operations
Inst Tools > Blog > Root Cause Analysis (RCA) > Fired Boiler Induced Draft Fan (IDF) Failures Upset all Plants Operations
Root Cause Analysis (RCA): Fired boiler-induced draft fan (IDF) failures upset all plants operations.
Last updated: September 28, 2022 3:19 pm
S Raghava Chari
6 Min Read
Fired Boiler Induced Draft Fan (IDF) FailuresRoot Cause Analysis SolutionRCA solution Benefits
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:Miscellaneous Rotating Machine Problems
Author:S. Raghava Chari
The fired boiler induced draft fan (IDF) failures posed 10-yearlong problems are:
  1. The Non-Drive End antifriction bearing failed frequently.
  2. Even with full open guide vanes furnace pressure is above atmospheric and flames shoot out
Problem 1 Root Cause Analysis Queries (Q) and Answers (A) are:
Q: Why too low AFB lives?
A: The Antifriction bearings (AFB) situates in the hot flue gas path (below figure); maybe excessive temp fails the AFB.
Q: Why excessive AFB temp; surely the makers would have taken care for it to work in the high temp environs
A: Our guessed reasons are
  • The bearing housing cooling water lines corrode away quickly, hence water cooling is mostly absent
  • The shop is unable to balance the fabricated rotor well; consequent excessive vibrations shorten the AFB lives
Problem 1 Root Cause Analyzed Solution:
Mulling this information 2-days, the author developed the below-given solutions:
  1. Insulate the pipe shrouding the shaft and bearing housing with 20 mm thick K-wool – a recently developed low thermal conductivity super insulating material – and SS clade to last long (above figure).
  2. Cool the AFB with air tapped off the nearby surplus capacity FD fan’ The 2” SS air pipe entering the duct to branch off into  1” branches A and B; branch A fed large cool air quantities to cool the shaft passing through the shroud to reduce hot shaft transmitted heat to the AFB and Branch B fed air to cool the AFB house. Both air shall escape into the duct and reach the environs with the flue gases
Run ¼” SS pipe from AFB grease port extending 150‑mm out of duct wall to pump grease and another for the exiting old grease. Monthly pump in new grease till all old grease is out. Leave the exit grease pipe partially open to let the hot grease out when the fan runs.
Problem 2 RCA queries and answers:
Q: Why poor furnace pressure control?
A: We don’t know Sir”.
The author guessed possible errors in the shop-made fan labeled vendor part No. F 1250. The measured dia was 1210 mm only. Possibly the shop duplicating it from an old rotor committed the error.
The author found a local vendor – he fabricates the rotor for the fan manufacturer – furnished correct size and balanced to standards rotors on his ‘hard suspension’ balancing machines exhausted rated flue gas quantities. Now the furnace pressure is near 0 mm WC with 75% guide vanes open.
Both problems vanished
RCA solution Benefits are:
  1. Controlled to zero furnace pressures eliminated flame come outs out of viewing windows and potential operators’ injuries – an essential safety requirement
  2. due to Reliable and lasting hot end AFB cooling, consequent long AFB lives, 100%, IDF availabilities, smooth uninterrupted boiler runs offered steam production resulted in smooth and uninterrupted NH3 and Urea Plant runs and 10% increased production.
  3. Gone are the standby motor driven ID fan failing either due to its own poor reliability or power failure while restoring the failed steam driven ID fan threats are gone
  4. Gone are the often done extremely difficult blinding the fan duct for personnel entry, back-breaking hazardous atmosphere several shifts long failed fan restoration tasks
  5. Gone are the shop made poor rotors due to locating a reliable vendor capable of supplying dimensionally accurate and well-balanced rotors
  6. No ID fan work between turnarounds delighted operators and millwrights immensely and boosted their morale though they lost enormous overtime wages
  7. 20% saved maintenance costs
Author: S. Raghava Chari
  • Dozing System Problems
  • Pump Low throughput Eliminated
  • Fan Motor Journal Bearing Failures
  • Turbine to Gearbox Alignment Drifts
  • Storage Tanks Ammonia Gas Venting Issue
Turbo-Compressor Problem – Root Cause Analysis
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
Hunting of Control Valves
RCA – Compressor Did Not Trip on Suction Pressure Low Low
Pressure Switch Frozen Screwed Cover Extends the Plant Shutdown
Seal Pressure Instruments Root Cause Analysis
Pump 3-monthly Seal Leaks threaten entire Plant Shut down Indefinitely
Miscellaneous Electrical Tasks – Repaired Reformer Tubes Weld Stress Relief
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
Less than 40% available Plant Air Compressors made available 100% for Operations
Control Valves Leak Tightness Restoration Pose Difficulties
HT motors Corrosion Problem
Solving Critical Control Valve Hunting
Solving Control Valve Hunting: Instrument Troubleshooting
Control Valve Whisper Trim Cage
Problem with Choked Control Valve with Whisper Trim Cage
Rupture Disc
Rupture Discs bursts caused too many Urea Plant Shutdowns
Antifriction bearings (AFB) Problems
Antifriction bearings (AFB) Problems and Delays Plant Restarts
Multistage Flash Drums Erratic Level Readings
Plant Air Storage Tank
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
HT Motor Direction of Rotation (DOR)
HT Motor Direction of Rotation (DOR) Changed
Top 300 Arduino Projects for Engineering Students
Instrument Process Datasheet
Why is an Instrument Process Datasheet Required?
How to Select the Right Encoder for Your Machine
How to Select the Right Encoder for Your Machine?
Cooling Tower Fans Frequently Failing
Power Systems MCQ Series 1
Thermal Mass Flowmeter Principle
Thermal Mass Flow Meter – Principle, Advantages, Applications
LAYERS OF PROTECTION ANALYSIS
Layers of Protection Analysis (LOPA) Interview Questions
toroidal conductivity probe principle
Conductivity Analyzer Common Problems and Troubleshooting Tips
