Reading: Architecture of Allen Bradley PLC
Inst Tools > Blog > PLC Tutorials > Architecture of Allen Bradley PLC
Learn about the architecture of Allen Bradley programmable logic controller (PLC) and different networks like ControlNet, DeviceNet, Ethernet, and Fieldbus.
Last updated: September 28, 2022 2:38 pm
R Jagan Mohan Rao
A control Logix provides an open high-performance control platform for multiple types of control that can perform sequential, process, drive, or motion control in any combination with this single platform.
Architecture of Allen Bradley PLCControlLogix ControllerDeviceNetEthernet Network
ControlLogix is a flexible platform that allows multiple processors, networks, and I/O to be mixed without restrictions.
As the requirement of the application grows, one can use Net Links architecture for control of information across Ethernet, DeviceNet, and Foundation fieldbus.
It stores configuration data for every I/O module, it can be a local or a remote input/output. Control Logix controller executes the ladder motion commands. A servo module connects to a servo drive by an RS Logix 5000 program.
A ControlNet controller can also communicate across the backplane with communication interface modules to monitor and control I/O on ControlNet, DeviceNet, Universal Remote I/O networks and to monitor foundation field bus data.
ControlLogix controller
Separate communication modules are available for interfacing the backplane with Ethernet, ControlNet, Universal Remote I/O networks, and RS232 networks. Configuring a gateway to bridge and route control and information data between networks.
A controller communicates with control modules in local I/Os as well as remote I/O across ControlNet, DeviceNet, and Universal Control I/O. One or multiple controllers can be placed on a single controlLogix chassis.
It is capable of addressing a large number of inputs/outputs. 1,28,000 Digital inputs maximum and 4000 analog maximum.
ControlNet Communication module is available in the same chassis or a control gateway. The Control network is an open, high-speed network used for transferring the data. It provides real-time control, messaging services to peer communication.
ControlNet communications module bridges ControlNet links to route messages on the other networks such as Ethernet, ControlNet.
  • Supports peer to peer messaging
  • Supports programming and device configuration.
ControlNet can be connected with, I/O modules, controllers, personal computers, operator interfacing devices.
DeviceNet
DeviceNet is an open, low-level connection link that has a connection between simple, process measurement devices like sensors and actuators.
DeviceNet
The DeviceNet provides:
  • Interoperability
  • Cost-effective wiring than traditional I/O wiring because devices need not be connected directly to programmable controllers.
  • It supports device-level diagnostics.
  • Connects to multiple vendor’s devices.
Ethernet Network
Ethernet is a local area network designed for the high-speed exchange of information between computers and related devices.
Ethernet provides enterprise-wise systems access to plant floor data. It can transfer large data files.
Allen Bradley Ethernet Network
Universal Remote I/O Network:
It supports many Allen Bradley and third-party devices.
Serial Network:
The serial port supports the DP1 protocol to communicate with other devices on the serial links.
Fieldbus Network:
FF network is a standalone based network designed to handle process automation applications. Fieldbus networks can connect low-level devices directly to plant floor controllers. FF interconnects controllers with actuators, sensors.
Fieldbus Network
Reference: Allen Bradley
  • What is Fieldbus?
  • Automation Protocols
  • What is HART Protocol?
  • OSI Layers of Communication
  • SCADA Communication
  • Basic Industrial Networks
Lamp Control using PLC Logic Condition
Basic Concepts of the Safety Relay
PLC Functional Block Diagram for Logic Gates
How to use Master Control Reset (MCR) Instruction in PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
  • Syed Roshan Zameer says:
    July 24, 2020 at 8:30 am
    I want to learn this subject.
Siemens PLC Tia Portal – OB100 Start-up Organization Block
PLC Memory Organization – Data Files and Program Files
Move Instruction in Tia Portal
How to Read an Electrical Wiring Diagram?
Communication between InTouch Scada and Allen Bradley PLC
How to Create Faceplate in FactoryTalk View Studio?
CX-Programmer Products Sorting & Counting – Omron PLC
PLC Programming Example on LED Control
PLC Water Project
Smart Spray System using Wecon PLC
SCADA Systems
SCADA Systems
Case Statement in SCL Language
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
Parts of PLC
Parts of PLC
Instrumentation During the Detail Design Phase
Boolean Algebra to PLC Logic
From Boolean Algebra to PLC Logic
traffic light plc program
Flowmeter Characteristics
Flow Meter Characteristics
Power Electronics Projects
Top 100 Power Electronics Projects for Engineering Students
Control Sytem Open Loop and Closed Loop
Introduction to Control System
Why is 24 Volts Commonly used in PLC Systems?
Shielded Cables
The Idea Behind Shielded Cables
Reactive Power Sources and Sinks in Power System
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
