Reading: Allen Bradley PLC Subroutines
Inst Tools > Blog > PLC Tutorials > Allen Bradley PLC Subroutines
PLC subroutine example to store recurring sections of program logic that must be executed from several points within your application program.
Last updated: November 2, 2023 5:00 pm
3 Min Read
JSR, SBR, and RET instructions are used to direct the controller to execute a separate subroutine file within the ladder program and return to the instruction following the JSR instruction.
The SBR instruction must be the first instruction on the first rung in the program file that contains the subroutine.
  • Use a subroutine to store recurring sections of program logic that must be executed from several points within your application program
  • A subroutine saves memory because you program it only once.
  • Update critical I/O within subroutines using immediate input and/or output instructions (IIM, IOM), especially if your application calls for nested or relatively long subroutines
  • Otherwise, the controller does not update I/O until it reaches the end of the main program (after executing all subroutines)
  • Outputs controlled within a subroutine remain in their last state until the subroutine is executed again.
When the JSR instruction is executed, the controller jumps to the subroutine instruction (SBR) at the beginning of the target subroutine file and resumes execution at that point. You cannot jump into any part of a subroutine except the first instruction in that file.
The target subroutine is identified by the file number that you entered in the JSR instruction. The SBR instruction serves as a label or identifier for a program file as a regular subroutine file. The instruction must be programmed as the first instruction of the first rung of a subroutine.
The RET instruction marks the end of subroutine execution or the end of the subroutine file. The rung containing the RET instruction may be conditional if this rung precedes the end of the subroutine.
In this way, the controller omits the balance of a subroutine only if its rung condition is true.
  • Essential Documents in a PLC System
  • Process Control System Questions
  • Conveyor Ladder Logic Program
  • PLC Energize or De-energize
  • PLC Selective Execution
Basic Conveyor System for Product Handling in Omron PLC
Free Industrial Control System (ICS) Cyber Security Training Course
Safety Considerations in PLC System Design
1oo2 Evaluation Safety Instruction in Safety PLC
Create User-Defined Data Types and Function Blocks in Studio 5000
  • Shahid ali says:
    September 13, 2018 at 9:13 am
    I know about dcs and scada function of instruments.what is the function of dcs
Difference between Motion Controller and PLC
How to Create Project in Wonderware Intouch?
PLC Functional Block Diagram for Logic Gates
Instrumentation System Architecture
How to Create Templates in FactoryTalk View Studio?
STAR DELTA Programming using PLC Controller
What is Hot Standby in PLC?
Siemens Simatic HMI
How to Design an Effective HMI? – Human Machine Interface
Download a Ladder logic program to GE PLC
Types of PLC
Types of PLC
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
PLC Sizes and Applications
InTouch SCADA Password Protection
InTouch SCADA Login Password Security
PLC Ladder Logic for Lube Oil Pump Motor
Flow Switch Working
Flow Switch : What is it? – Applications
Basic Electronics Questions and Answers
Nameplate Markings
Explosive Atmospheres & Hazardous Classification
Applications of CNC Machining
Important Applications of Rapid Prototype CNC Machining Services
Types of Motor Enclosures
Instrumentation Books Free Download
Basic Logic Gate Symbols
Engineering Logic Diagrams
Calibration MCQ - Terminology and Glossary Questions
Calibration MCQ – Terminology and Glossary Questions
