Reading: AI, AO, DI, DO Questions (PLC I/O Types)
Inst Tools > Blog > Control Systems MCQ > AI, AO, DI, DO Questions (PLC I/O Types)
Understand the PLC I/O types with our top questions on AI, AO, DI, and DO for learning automation and control technologies
Last updated: August 31, 2024 8:13 pm
Control Systems MCQ Instrumentation MCQ PLC Tutorials
9 Min Read
AI, AO, DI, DO QuestionsA thermocouple connected to a PLC is an example of which type of signal?What type of I/O device is a push button when used in a PLC system?A variable frequency drive (VFD) receiving signals from a PLC is classified as? (from PLC point of view)Which type of signal is provided by a limit switch to a PLC?Identify the type of device a solenoid valve is when controlled by a PLC.What type of signal does a flow transmitter provide to a PLC?Which type of I/O is a proximity sensor in a PLC system?A PLC controlling an actuator to move a lever is an example of which type of output?What type of signal does a humidity sensor provide to a PLC?Which type of I/O device is an LED indicator controlled by a PLC?What type of I/O device is a load cell when used in a PLC system?A strobe light controlled by a PLC is an example of which type of output?Which type of signal does a pressure transducer provide to a PLC?Identify the type of device a relay switch is when connected to a PLC.What type of I/O device is a photoelectric sensor in a PLC system?A PLC controlling a heating element is an example of which type of output?Which type of signal does a tachometer provide to a PLC?What type of I/O device is a safety light curtain in a PLC system?A PLC controlling a motor speed through a VFD is an example of which type of output?Which type of I/O device is a magnetic reed switch used for position detection?A thermistor used in a PLC system is an example of which type of signal?What type of I/O device is an emergency stop button in a PLC system?A pressure gauge/sensor providing signals to a PLC is classified as which type of input?Which type of I/O device is an actuator controlled by a PLC?What type of signal does a potentiometer provide to a PLC?A pilot light controlled by a PLC is an example of which type of output?Identify the type of device a contactor is when controlled by a PLC.What type of I/O device is a flow meter in a PLC system?Which type of I/O device is a buzzer controlled by a PLC?Identify the type of device an analog voltmeter is when connected to a PLC.What type of I/O device is a strain gauge when used in a PLC system?A flashing beacon controlled by a PLC is an example of which type of output?Which type of signal does an RTD sensor provide to a PLC?Identify the type of device a photoelectric sensor is when connected to a PLC.What type of signal does a digital counter provide to a PLC?A pneumatic actuator controlled by a PLC is an example of which type of output?Which type of signal does an ultrasonic sensor provide to a PLC?Which type of I/O device is a pressure sensor in a PLC system?
The following video provides detailed explanations for the PLC IO questions.
PLC I/O Types: AI, AO, DI, and DO Questions
Question 1
A. AI
B. AO
C. DI
D. DO
Show the Answer
AI
Question 2
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 3
A. AO
B. AI
C. DI
D. DO
Show the Answer
AO
Question 4
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 5
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 6
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 7
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 8
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 9
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 10
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 11
A. AI
B. AO
C. DI
D. DO
Show the Answer
AI
Question 12
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 13
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 14
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 15
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 16
A. AO
B. AI
C. DI
D. DO
Show the Answer
AO
Question 17
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 18
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 19
A. AO
B. AI
C. DI
D. DO
Show the Answer
AO
Question 20
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 21
A. AI
B. AO
C. DI
D. DO
Show the Answer
AI
Question 22
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 23
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 24
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 25
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 26
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 27
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 28
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 29
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 30
A. AO
B. AI
C. DI
D. DO
Show the Answer
AO
Question 31
A. AI
B. AO
C. DI
D. DO
Show the Answer
AI
Question 32
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 33
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 34
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 35
A. DI
B. AI
C. AO
D. DO
Show the Answer
DI
Question 36
A. DO
B. AI
C. AO
D. DI
Show the Answer
DO
Question 37
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
Question 38
A. AI
B. DI
C. AO
D. DO
Show the Answer
AI
  • Wiring Diagrams of PLC Systems
  • PLC Digital Signals Wiring Techniques
  • Micro PLC Hardware Configuration
  • Flexible PLC Input Output Modules
  • What are AI, AO, DI, and DO?
Control Systems Multiple Choice Questions
Allen Bradley PLC to PLC Communication in Studio 5000
How to use FIFO Block in TIA Portal? – Siemens PLC Programming
Car Parking System using PLC Programming
How to Choose a Suitable HMI for Your Application?
What is PID Controller?
ON Delay Timer using PLC
Oil and Water Separation Process using PLC Programming
Unknown Do’s Need to Know as a PLC Programmer
PLC Program for Water filling and Discharging Process
STL Programming – SET, RESET, ASSIGN
Pause the Timer PLC Ladder Logic
Common Valve Abbreviations
Common Valve Abbreviations in US Engineering Drawings
Basic Control Systems Questions
14 Basic Control Systems Questions for Interview Preparation
How to Use Symbol Factory Software for Graphic Design in HMI or SCADA
How to Use Symbol Factory Software for Graphic Design in HMI or SCADA?
HMI Screen Design for Hazardous Applications
Ethernet IP Commissioning Tool software
How to Configure IP Address in Rockwell PLC?
Siemens PLC Device and Network
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
Human Machine Interface
What is Human Machine Interface (HMI) ?
PLC railway crossing program
Automatic Railway Crossing Gate Control PLC Program
PLC Program using Bitwise Instructions
Allen Bradley Bitwise Logical Operations
Parallel RLC Circuit
Resonance, Resonant Frequency, Series and Parallel Resonance
SIS Testing and Repair Deferral
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Capacitor and Symbols
Capacitance
cascade temperature controller
How to Analyze a Cascade Control Loop?
Top 100 PLC Projects List
