Reading: What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Inst Tools > Blog > PLC Tutorials > What are AI, AO, DI, and DO? – Definition, Examples, Purpose
AI, AO, DI, and DO refer to the types of input and output signals handled by control and monitoring devices such as PLC, DCS, DAQ.
Last updated: July 9, 2023 4:54 pm
PLC Tutorials Control Systems
9 Min Read
AI, AO, DI, and DO are acronyms used in automation, control systems, and instrumentation. They refer to the types of input and output signals handled by control and monitoring devices such as programmable logic controllers (PLC), distributed control systems (DCS), and data acquisition systems (DAQ).
What is an Analog Input (AI)?What is an Analog Output (AO)?What is Digital Input (DI)?What is Digital Output (DO)?Examples of AI, AO, DI, DOExamples of Analog Input SignalsExamples of Analog Output SignalsExample of Digital Input SignalsExamples of Digital Output SignalsPurposeThe Purpose of Analog Input (AI)The Purpose of Analog Output (AO)The purpose of Digital Input (DI)The Purpose of Digital Output (DO)Comparison between AI, AO, DI, DO
An analog input (AI) is a signal that can have a continuous range of values. These signals are used to read the status of sensors that provide a variable reading, such as temperature sensors (thermocouples, RTDs), pressure sensors, or flow meters.
An analog output signal (AO) can also have a continuous range of values and is used to control devices that can be set to variable positions or conditions, such as variable speed drives, or control valves. An analog output could be used, for instance, to set the speed of a motor or the position of a control valve.
A digital input (DI) is a type of signal that can only have discrete values, typically binary, like 0 (representing off, low, false) and 1 (representing on, high, true). It is used to read the status of binary sensors like limit switches, proximity switches, or photoelectric sensors in a control system.
A digital output (DO) is a signal that can also have discrete binary values and is used to control devices such as actuators, solenoids, or LEDs. For instance, a digital output could be used to turn a motor on or off.
These signals are common in industries where automation is applied, such as in manufacturing, process control, and industrial automation. They refer to the basic types of signals used to interact with and control the processes and equipment in these industries.
AI AO DI DO Signals
Here are some practical examples of Digital Input (DI), Digital Output (DO), Analog Input (AI), and Analog Output (AO) in automation and control systems:
  • Temperature Sensor (Thermocouple, RTD): These devices can give a variable output voltage or current signal that is proportional to the temperature they are measuring.
  • Flow Meter: Provides a variable voltage or current signal proportional to the flow rate of a fluid.
  • Pressure Sensor: This sensor generates an analog output signal that varies in proportion to the pressure it is measuring.
  • Variable Speed Drive: A variable voltage or current signal can be used to control the speed of a motor.
  • Control Valve: An analog output can be used to set the position of a control valve, controlling the flow rate of a fluid.
  • Heater Element: In some cases, an analog output could be used to control the power to a heating element, adjusting the heat output based on the control signal.
  • Limit Switch: This can send a digital input signal to a PLC when a machine part reaches a specific limit.
  • Proximity Sensor: Used to detect the presence or absence of an object without physical contact. When the object is within a certain range, the sensor sends a “1” signal, otherwise, it sends a “0”.
  • Push Button: A manually actuated device that sends a binary signal (on/off) to a control system.
  • Actuator/Solenoid Valve: A digital output can be used to open or close a valve (1 for open, 0 for closed).
  • Motor Start/Stop: A digital output can send a signal to start or stop a motor.
  • Indicator Lights: A digital output can be used to control an indicator light on a control panel (1 for on, 0 for off).
These are just a few examples. The specific types of inputs and outputs used will depend on the nature of the system and the requirements of the application.
Purpose
The purpose of Digital Inputs (DI), Digital Outputs (DO), Analog Inputs (AI), and Analog Outputs (AO) is to enable communication and control between a controller (like a PLC, DCS, or microcontroller) and devices in a system or process. They serve as the fundamental interface between the physical world and the digital control system.
Analog inputs are used to monitor continuously variable conditions. Sensors that monitor conditions such as temperature, pressure, or flow rate provide an analog voltage or current that represents the measured condition. These analog signals are then read by the controller to monitor the state of the system or process.
Analog outputs are used to control devices that operate over a range of conditions rather than simply on or off. These could control the speed of a motor, the position of a control valve, or the power to a heating element, for example. The analog output provides a variable voltage or current that commands the device to a particular state within its operating range.
Digital inputs are used to receive digital signals from various field devices, usually for the purpose of monitoring. Devices such as push buttons, limit switches, and proximity sensors provide digital input signals to indicate the status of equipment or a process (for instance, if a machine part has reached its limit or if an object is present or not).
Digital outputs are used to send digital signals to devices to control their operation. A digital output could control the operation of a motor, open/close a valve, or light up an indicator light, for example. The digital output would typically command the device to be either on or off.
The below table shows the comparison of AI (Analog Input), AO (Analog Output), DI (Digital Input), and DO (Digital Output).
TypeDescriptionExamplesUsage
AIReceives and interprets a continuous range of values from the physical world, typically from sensors.Temperature sensor, pressure sensor, level sensor.Used for process variables that vary continuously.
AOSends a continuous range of values to control devices.Variable speed drive (VSD), control valve, damper.Used to control equipment that can operate at various levels.
DIReceives binary (on/off) signals from the physical world.Limit switch, push button, proximity switch.Used for devices that have only two states: on or off.
DOSends binary (on/off) signals to control devices.Solenoid valve, motor starter, indicator light.Used to control devices that can be either turned on or off.
  • Find the Best PLC for Your Project
  • HMI Screens on a Mobile or Tablet
  • Top Automation Vendors in World
  • Tia Portal Interrupt Organization Block
  • Types of Sensors Used in Automobiles
How to Export Data from DeltaV System to Excel
Waste-Burning System OMRON PLC Program Example
Which Connection is Best for PLC? – Sinking or Sourcing
PLC FBD Program for Bottle’s Capping with Rotating Mechanism
DCS Troubleshooting Control Valve Loop
PID Controller Loop Tuning Questions and Answers – Part 1
Siemens PLC Mathematics Instructions
Glass Cutting and Polishing Machine: PLC Automation Solution
Ratio Controller Example
Communication between InTouch Scada and Allen Bradley PLC
PLC Timer Instructions
OB10 Time of Day Interrupt
Tia Portal – OB10 Time of Day Interrupt Organization Block
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
PLC Program for Controlling Conveyors ON Sequence and OFF Sequence
PLC Program – Controls Conveyors ON and OFF Sequence
Split Range Control Block Diagram
Split Range Control Application using PLC Ladder Logic
Relay Wiring
Allen Bradley PLC Example with Sub routines
How to use Sub Routines with Allen Bradley PLC
Analog Instruments
PLC Program to Drain Same Products from Two Tanks
PID parameters
PID in Siemens TIA Portal
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Four Wire RTD Principle
How a 4 Wire RTD Works ?
PLC Program for Boolean Expression
Learning Programming
How to Begin Learning Programming and Succeed?
Top 20 Service Business Opportunities in the Instrumentation Industry
Top 20 Instrumentation Service Business Opportunities in the Industry
Best Online Courses to Learn Electrical Engineering
A span error with wrong slope
Determine the Instrument Calibration Error
