Reading: Voice Activated Industrial Automation Systems
Inst Tools > Blog > Control Systems > Voice Activated Industrial Automation Systems
Voice activated and controlled industrial automation systems are hugely evolving in the IoT market due to their large-scale implementations.
Last updated: October 17, 2023 3:38 pm
Control Systems
In this post, we will see the concept of voice-activated industrial automation systems like PLC and DCS.
Industrial AutomationVoice-controlled Industrial AutomationVoice Activated Systems with PLCConclusion
IoT has made industrial automation simpler and flexible to use. Interconnection of smart manufacturing with automation technology increases the productivity, efficiency, and reliability of the system.
Due to the use of artificial intelligence and machine learning, an advanced feature of this technology named voice control has evolved and is extensively used nowadays; which is possible through IoT.
Just like Google’s Alexa service and other smart home devices nowadays, which work on voice commands; this technology is used in the same way in industrial automation as similar to home automation.
Also Read: Industry 4.0 Explained
Let us consider the main example of this technology in industrial automation. A handicapped worker who finds it difficult to operate the machine through its hands will just speak over the system to start or stop the machine.
Also, not just a handicapped person; a normal worker too would find the system safe to operate without physical intervention; if the nearby environment is hazardous and unsafe.
iTSpeex’s ATHENA is one of the initial voice-activated systems in industrial automation used. It is extensively used for CNC machines like lathes, mills, and grinders. Due to the use of microphones or headsets with speakers, an operator can operate the machine through voice commands.
Basically, one thing should be understood that a PLC does not accept voice commands. It accepts electrical or communication signals by any protocol. So, in this technology, an interface device is used which converts voice commands into electrical or soft communication commands.
A fixed set of input commands will be programmed in the PLC which will accept only a specific set of words and sentences. An operator will say something; the device will convert it into a string command.
This command will be sent via a protocol to the PLC. The PLC will then check whether this string is present in its logic or not. If it compares and finds it in the program, then the PLC will execute it.
This was a basic example of programming by voice control. Generally, different devices work on different protocols. Due to the use of the internet in IoT, an operator will just input the voice command and this command will be transported via the internet to the local PLC.
Conclusion
In simpler terms, compare a voice command to a biometric device. The way this biometric device converts a physical input into a communication language and sends it to PLC; is similar to a voice-controlled device.
Voice-controlled automation is hugely evolving in the IoT market due to its large-scale implementations.
  • Compare Robotics and Automation
  • What is Industrial Computer (IPC)?
  • Communication Protocols in PLC
  • Contactor Connection with PLC
  • Industrial Automation Pumping System
Introduction to Control System
PID Simulator Download
Chemical Reactor Temperature Control System
Overview of Split Range Control
System Cabinet Health Checks – PLC and DCS Industrial Automation
How to Select the Right Type of Controller
Definitions of Electrical Grounding
Alarm and Trip Systems
What is a Control Loop ?
How to Write a Program in Ecostruxure Machine Expert HVAC Software?
Introduction to PlantPAx Distributed Control System
Two Element Drum Level Control System
Difference Between Batch Process and Continuous Process
Design & Construction of Process Plant
Electrical Drives Animation
Loop Diagram
PID Controller Tuning
How to tune a PID Controller ?
Earthing Calculations
Electrical Earthing Calculations
Junction Box Wiring
4-20mA Junction Box versus Fieldbus (FF) Junction Box
How to Train Your Maintenance Team for Industrial Automation Systems
Water Treatment Control System
Waste Water Control System
Serial Communication Interview Questions
Serial Communication Interview Questions and Answers
Lights with Adjustable Timers PLC Programming
Flip-Flop PLC Programming: Lights with Adjustable Timers
Look Listen Feel of Instruments
Look Listen Feel of Instruments – Instrumentation Engineer Maintenance
Three Phase Converter Test Questions
Counters Objective Questions
What is Motor Jogging ?
Instrumentation Symbols Legend
