Reading: What are User Defined Function Blocks in PLC?
Inst Tools > Blog > PLC Tutorials > What are User Defined Function Blocks in PLC?
Function blocks are objects which are user defined in a PLC program to simplify the process of programming.
Last updated: October 17, 2023 1:19 pm
In this post, we will understand the use of user defined function blocks in a PLC (programmable logic controller).
Function BlocksSystem Function BlocksUser-defined Function BlocksPLC Function Block Programming Example
Function blocks are objects which are defined in a PLC program to simplify the process of programming. Basically, it is a means of reducing the programming length and complexity written by the programmer.
Consider a simple example of a timer. A timer is a logic which sets it’s output after a certain time.
Now, if a PLC programmer was required to write timer logic by himself, it would be a long and cumbersome process for him.
And, if there were many such timers required to be used in the logic, then you could imagine the length of the program code.
It would become difficult for him to troubleshoot if any issue occurs; and even difficult if some other programmer tries to study it.
This is made easier by a function block. A function block comprises of a logic written inside in it; with inputs and outputs linked to it.
So, you can use multiple instances of this function block by simply linking its inputs and outputs with different variables.
Refer to the below image. It shows two instances or uses of the timer in the program.
The first one is named alarm_t1 and the second one is named alarm_t2.
Timer in PLC Function Block
The first-timer is turned on by a different condition and the second timer is turned on by a different condition.
This shows that you can use multiple timers in the program with different trigger conditions and different set intervals.
You just have to name the timers properly; such that anyone should not clash with others.
So, consider this same thing without a function block. If it was not used, then you would have to write the logic of the timer manually; which would indirectly increase the complexities.
Function Blocks
Function blocks make the job much easier, as you do not have to write the logic every time if it is the same.
You just have to link the inputs and outputs as discussed before.
They are categorized into two types.
  1. system and
  2. user-defined.
System blocks are that function blocks that are developed by the manufacturer and preloaded in the software.
A simple example can be a timer, which we discussed before.
Now, let us look ahead to our main topic. Suppose if you are writing logic to start five motors after a set interval of time. All of them are required to turn off after a set interval of time.
Now, you can use a timer here. But what about the remaining logic? If you see, it is the same; with only the number of motors varying.
Now it is five motors; tomorrow a need can be raised for six. You cannot afford to write the whole logic manually every time, as it will waste time and also resources in the PLC software.
So, PLCs have a provision for user-defined function blocks. It gives programmer the facility to create a function block by himself, and assign the inputs and outputs accordingly.
This is extremely useful in conditions where the logic repeats several times and only the inputs and outputs change.
Hour meter PLC function block
Hourmeter is a function block defined by a user which has a logic written inside by him, for counting the running hours of a pump. ROFP_P_101A_HRS is the first block and ROFP_P_101B_HRS is the second function block.
The function block has its user-defined inputs and outputs; where you just have to link the conditions according to your requirements. This makes the work very easy and time-saving; as you will not have to write the logic of running hours individually for every pump.
One more advantage is that you can use any data type inside the function block. As you can use its multiple instances, it reduces the load of the programmer and saves time indirectly.
  • SCADA System with OPC UA
  • PLC Digital Output Types
  • Actuator Sensor Interface
  • PLC Communication Protocols
  • PLC to PLC Communication
Types of Limit Switches – Principle, Advantages, Disadvantages
#20 PLC Best Practices – Identify Critical Alerts
Most Asked Questions on SCADA with Answers
Commissioning Checklists for Industrial Automation Systems
Function of Racks in PLC – Types of SIEMENS S7-400 PLC Racks
Difference Between PLC and SCADA
What is the Firmware Version of a PLC? – Siemens PLC Hardware
PLC Programming for Sequential Batch Mixing System
How to use FIFO Block in TIA Portal? – Siemens PLC Programming
DCS versus PLC Architecture
PLC Timer Instructions
Free PLC Training Software Download
Repeat Until Statement in SCL Language
PLC PID tuning parameters
PLC Scan Time
PLC Scan Time
PLC Programming Example on LED Control
Sample Schematic Template for Systems Architecture Diagram
Basic PLC Alarm Programming Example
What is the consumed tag in Studio 5000 software?
Produced Tags and Consumed Tags in Studio 5000
Electric Drives and Traction Objective Questions and Answers
Electric Drives and Traction Interview Questions
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
Calibration Sheet
Calibration : Up-tests and Down-tests
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
Conveyor Control with Main Motor and Backup Motor
Time Response Analysis
Standard Test Signals Objective Questions
Electric Solenoid Actuators Principle
What is a Electric Solenoid Actuator ?
trip solenoid installed on a control valve appears
SIS Final Control Elements
