Reading: Unbalanced 3 Phase Loads
Inst Tools > Blog > Electrical Theory > Unbalanced 3 Phase Loads
Last updated: August 2, 2018 8:17 pm
Electrical Theory
2 Min Read
An important property of a three-phase balanced system is that the phasor sum of the three line or phase voltages is zero, and the phasor sum of the three line or phase currents is zero. When the three load impedances are not equal to one another, the phasor sums and the neutral current (In) are not zero, and the load is, therefore, unbalanced. The imbalance occurs when an open or short circuit appears at the load.
If a three-phase system has an unbalanced load and an unbalanced power source, the methods of fixing the system are complex. Therefore, we will only consider an unbalanced load with a balanced power source.
Example:
A 3φ balanced system, as shown in Figure 16a, contains a wye load. The line-to- line voltage is 240V, and the resistance is 40 Ω in each branch.
Figure 16 : 3φ Unbalanced Load
Find line current and neutral current for the following load conditions.
  1. balanced load
  2. open circuit phase A (Figure 16b)
  3. short circuit in phase A (Figure 16c)
Solution : balanced load
Unbalanced 3 Phase Loads Current Equation
IL = 138.7/40
IL = 3.5 amps
IN = 0
Solution : Answer for open circuit phase A
2. Current flow in lines B and C becomes the resultant of the loads in B and C connected in series.
Unbalanced 3 Phase Loads Current Equation - 1
IB = 240/40+40
IB = 3 amps
so, IC = 3 amps
IN = IB + IC = 6 amps
3. Answer for short circuit in phase A
Unbalanced 3 Phase Loads Current Equation - 2
IB = 240/40
IB = 6 amps
so IC = 6 amps
The current in Phase A is equal to the neutral line current, IA = IN
Therefore, IN is the phasor sum of IB = IC
IN = √3 IB
IN = 1.73 x 6
IN = 10.4 amps
In a fault condition, the neutral connection in a wye-connected load will carry more current than the phase under a balanced load. Unbalanced three-phase circuits are indicated by abnormally high currents in one or more of the phases. This may cause damage to equipment if the imbalance is allowed to continue.
Units of Electrical Measurement
Current Division
DC Generator Theory
Series – Parallel Circuit Analysis
Resistivity
D’Arsonval Meter Movement
Calculate Power in Parallel RC Circuit
Kirchhoff’s Laws
Electrical Symbols
Calculate Power in Series RC Circuit
Capacitive Time Constant
AC Generation
Resistance in Parallel Circuits
DC Motor Connections
Squirrel-Cage Induction Rotor
Induction Motor
Electrical Component Symbols
Electrical Diagrams and Schematics
Armature Current in a DC Motor
DC Motor Torque
3φ AC Power Connections
Three Phase Systems
Ammeter with Shunt
Ammeter
Inductor Principle
Inductance and Inductive Reactance
Electrodynamometer Movement Principle
Electro-Dynamo Meter Movement
Three Phase AC Generators
Magnetic Flow Meter Corrosion Effects
potentiometric level measurement principle
process chemical analyzer calibration
Automated Calibration
Instrument System Architecture and Process Control Design
System Architecture and Process Control Systems Philosophy
PID Setup
PID in Studio 5000
interview-questions-and-answers-on-natural-gas
Oil and Gas Interview Questions Answers
Modbus Function code 02 – Read Contact(s)
Modbus Function Command Formats
300 Power Electronics Projects - Top Electrical Major Project Titles
300 Power Electronics Projects – Top Electrical Major Project Titles
