Reading: Transmitters 4-20mA Current Failure Alarm Limits
Inst Tools > Blog > Basics > Transmitters 4-20mA Current Failure Alarm Limits
Last updated: March 4, 2021 4:02 pm
Basics Control Systems PLC Tutorials Standards
5 Comments
4-20 mA instrumentation and controls usually support a signal range slightly below 4 mA and above 20 mA.
Transmitters 4-20mA Current Failure Alarm LimitsSmart Valve Positioners
For transmitters, current values below 4 mA and above 20 mA are used to signal a fault such as a thermocouple burnout, Signal cable broken, Cable Low/High Resistance, Transmitter Failure or other sensor failure.
The transmitter can be configured for failure indication low or high.
Unfortunately manufacturers use different signal levels to indicate failure which prevents tight analog signal integration and interpretation in single loop controllers, control systems, and safety systems.
Image Source : eddl.org
Some transmitters may use 3.75 mA while others may use 3.6 mA or less. Some transmitter may use 21.75 mA or more while other use 23 mA.
This inconsistency of signal levels for failure indication makes it difficult to take full advantage of the failure information in control strategies.
The NAMUR NE43 “Standardization of the Signal Level for the Failure Information of Digital Transmitters” recommendation was created to standardize failure indication from transmitters and interpretation in control systems to enable better analog integration.
NE43 defines 3.8 to 20.5 mA as a valid (‘Good’) measurement value where 3.8 to 4 and 20 to 20.5 mA indicates saturation.
A signal of <3.6 mA or >21 mA indicates a transmitter failure (‘Bad’).
4-20mA Alarms Ranges NE43
By using transmitters and systems that both conform to the NE43 recommendation, it is possible to flag faults to the operators and control strategies.
However, note that all device errors, severe and trivial, are flagged the same way so the operator cannot tell the difference and that if any error occurs it is flagged and the measurement value is not provided.
FOUNDATION fieldbus and PROFIBUS-PA transmitters use digital communication with separate status indication for each measurement including measurement validity flagged in realtime as ‘Good’, ‘Bad’, or ‘Uncertain’.
This allows operators and control strategies to severe problems from trivial issues. This allows the control strategy to put the loop in manual in case of failure, with the option to trip. For non-severe issues the value is still displayed with ‘Uncertain’ status.
Smart valve positioners are not in the scope of NAMUR NE43.
However, signals <4 mA and >20 mA also have specific meanings. Control systems and single loop controllers with 4-20 mA output use a similar scheme to achieve tight shut-off for control valves. That is, they may set current <<4 mA or >>20 mA.
Some control systems set the output current to 0 mA to achieve tight shutoff. This is impractical in the case of smart valve positioners since they need 3.6 mA to operate and will be completely switched off at 0 mA.
Therefore make sure to configure the control system or single loop controller to provide at least 3.6 or 3.8 mA for tight shutoff to ensure that the smart valve positioner can continue to operate and respond to HART communication.
Source : Eddl.org
SIS, PLC and BPCS
Pressure Transmitter Tips
Selector, Override control
Calculate Process Variable
Instrument Air Manifold
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
Moving Data between PLCs – Siemens Basics – TSEND TRCV
Tuning a Temperature Process Control Loop
Selector Control Functions
PLC Application for Stamping Operation – Example Programming
5 Comments
  • Bhagath says:
    August 30, 2016 at 6:33 am
    Please share topics on floating voltages and grounded voltage… Thanx.
  • Paulo R M Monteiro says:
    December 20, 2016 at 10:37 am
    Excellent.
  • surendra says:
    April 8, 2017 at 8:28 am
    very good ..article…!!!…Thanks
  • Shan Ahmad says:
    September 18, 2018 at 11:40 pm
    Fine tips
  • Minhaj alam says:
    February 14, 2019 at 8:44 pm
    Inst video is very good
List of Instrumentation Project Engineering Documents
Compare Online and Offline PLC Programs
Multiple Pumps Control using PLC
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
PLC Programming to Control Lights in a Sequence
What is Integral Wind Up ?
Feedforward Control with Dynamic Compensation
PLC Light Sequence Control using Bit Shift Registers
DCS Alarm and Setpoint
Setpoints and Alarms in Control System
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
PLC Program for Food Processing
PLC Program for Food Processing Industry
Latched and Momentary Operation of Motor PLC Program
Transistor Output Wiring
PLC Output Types
Car Parking System PLC Program Example
Schneider Electric: Car Parking System with Calculations in PLC
Things to Take Care of When Designing SCADA System
Sensors and Transducers Test
Why does SMPS Need isolation - Switch Mode Power Supply
Why does SMPS Need isolation? – Switch Mode Power Supply
Difference between Transmitter and Transducer with Examples
Hydraulic versus Pneumatic Systems
What is the consumed tag in Studio 5000 software?
Produced Tags and Consumed Tags in Studio 5000
Linear Heat Detector Working Principle
What are Linear Heat Detectors?
What is FAT and SAT?
Switch or Transmitter
