Root Cause Analysis (RCA) provides a solution to Reformer Fan Bearing Change Times cut by 90%.
| Category: | Mechanical |
| Equipment Type: | Miscellaneous Rotating Machine Problems |
Unbolt the over 250 Nos. 10 mm dia casing bolts
Position a crane suitably before plant shutdown (SD), after SD lift the casing upper half (above figure), place it nearby; lift the rotor 20 mm using a chain pulley block suspended from crane hook for Antifriction bearings (AFB) pull out; change the failed AFB, assemble back, etc.
Author Solution
Though the crew assured the instruction manual offered no easier bearing changing method, the author felt designers would have envisaged an easier bearing changing method:
He carefully viewed the fan 10 minutes and suggested to replace the AFBs thus:
- Arrange bearing pullers and electric bearing heaters close by before fan SD.
- Unbolt both side Pillow Block’s upper halves
- Unbolt both sides the top ½ ring bolted to the fan entry filter
- Lift the fan rotor with a crane carefully and slowly till it contacts the casing top; the rotor tip to case bore distance is usually sufficiently large and bearing OD will be clear the pillow block step
- With the crane holding the rotor, replace both the bearings.
- Lower the rotor carefully and guide both end AFBs into the pillow block seat
- Mallet tap the shaft and seat the both end AFBs in the pillow block
- Tighten Pillow Block top halves. The fan is ready for use! Just 2 hours task- not 2 shifts i.e., 16 hours.
The study-based solution Benefits
The plant resumed full capacity production within 3 hours and with just a few easy maintenance efforts and needless 13 hours ½ capacity runs.
Author: S. Raghava Chari
- Dozing System Problems
- Pump Low throughput Eliminated
- Fan Motor Journal Bearing Failures
- Turbine to Gearbox Alignment Drifts
- Storage Tanks Ammonia Gas Venting Issue
