  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Questions on Allen-Bradley MicroLogix 1000 PLC
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Practical Questions > Questions on Allen-Bradley MicroLogix 1000 PLC
Suppose we have an Allen-Bradley MicroLogix 1000 PLC and two pressure switches we need to connect to it.
Last updated: February 12, 2021 9:35 pm
Practical Questions
3 Comments
1 Min Read
Allen-Bradley MicroLogix  Programmable Logic ControllerAllen Bradley PLC Course
Determine the necessary contacts on each pressure switch (NO versus NC).
We need to connect to the PLC inputs in order to make the lamp turn on when pressure A exceeds 25 PSI and pressure B drops below 139 PSI, given the following program running in the PLC:
Allen-Bradley MicroLogix 1000 PLC Logic
Answer :
Both pressure switches need their normally-closed (NC) contact terminals connected to the respective PLC input terminals.
Share Your Answer / Comments
Credits : by Tony R. Kuphaldt
  • Top 100 PLC Questions
  • Motor and Push-button Logic
  • Troubleshoot Allen Bradley PLC Logic
  • Types of Allen Bradley PLC
  • PLC Memory Mapping and I/O addressing
Calculate Temperature of RTD
Determine Level of Liquid in the Vessel and its Specific Gravity
Process Control Loop Testing
Hydrostatic Pressure Measurement Questions
Calculate Hydraulic Pressure of a Process Vessel
3 Comments
  • AVINASH SHINDE says:
    February 13, 2021 at 8:54 am
    Allen Bradly Micrologix 1000 PLC now obsolete Now Ab micrologix 1400 PLC is available.
  • LESTA says:
    February 14, 2021 at 10:40 pm
    yez
  • obert ende says:
    February 19, 2021 at 6:25 am
    I really enjoyed it
208kSubscribersSubscribe
Recent Comments
Related Articles
Differential Pressure Sensor with pair of Strain Gauges
Differential Pressure Sensor with Pair of Strain Gauges
PLC Program for Valves
PLC Pump Permissive Interlocks
simulate a thermocouple
Calculate the appropriate millivoltage values of a Thermocouple
PLC Circuit Answers
PLC connected to Three Pushbutton Switches
solenoid valves trip
Identify Solenoid Valves Energized or de-energized?
Problem with Pirani Gauge
water seal drum lever transmitter
Determine LRV and URV settings for the Level Transmitter
Calibration setup for a low-range electronic pressure transmitter
Instrument Lab Exercise – Ranging and Manometer Usage
More Articles
PLC Questions - 1
Sketch a Ladder Diagram for PLC to Energize the Lamp
Vortex Flow GIF
Working Principle of Vortex Flow Meter
LAYERS OF PROTECTION ANALYSIS
Layers of Protection Analysis (LOPA) Interview Questions
Robotic Process Automation
What is Robotic Process Automation? Advantages, Applications
Working of Proximitor
Different Types of Turbine Protective Devices
Confined Space
PLC Programming Basics for a Packing Machine Control System
PLC Packing Machine Control System Program in XG5000
Purpose of an Electrical Substation
What is a Substation? Purpose of an Electrical Substation
