Electrical engineering root cause analysis (RCA) related to poor power factor boosted as P.F was very low in an electrical substation.
| Category: | Electrical |
| Equipment Type: | Motors |
Poor Power Factor Problem
The power factor was low around 0.7 due to 50% loaded transformers feeding induction motors.
The State Electricity Board (SEB) threatened to discontinue the power supply of the PF if it is not raised to the statutory minimum 0.8
Solution & Benefits
Two capacitor banks installed on the 11-KV bus improved the power factor to > 0.9 and met the statutory requirements. About 10% less power bill is a bonus benefit.
Author: S. Raghava Chari
- Problems with Switchgear
- What is an Electrical Drive?
- Aluminum Cable Terminations
- What is a Magnetic Contactor?
- Arc Fault Breaker Problem Solved
