Reading: PLC Programming for Tank Heating Control using Heater
Inst Tools > Blog > PLC Tutorials > PLC Programming for Tank Heating Control using Heater
Temperature Control using PLC. Implement Logic for PLC Tank Heating Control using ladder diagram language and simulate the process.
Last updated: November 3, 2023 2:39 pm
4 Comments
3 Min Read
This is a PLC Program for heating liquid in the tank by heater.
Tank Heating ControlProblem DiagramProblem SolutionInputs/Outputs ListPLC Program for heating liquid in the tank by heaterLogic DescriptionResult
Problem Description
Controlling the heating process for the liquid in the tank.
Implement a PLC program for this application using ladder diagram language.
Problem Diagram
PLC Program for Tank Heating Control using Heater
Problem Solution
In this system, we will consider S7-300 PLC and TIA portal software for programming.
In this system two sensors are used for level measurement in the tank, heater is used for material heating purposes in the tank.
We used a temperature sensor (it can be RTD or thermocouple) also for temperature measurement in the tank.
Two valves are used for the material inlet and outlet. The inlet valve is used for feeding the tank and the outlet valve for discharging the tank.
If the system detects a low level, the system will start to feed the tank. The feeding cycle will be OFF when the tank detects a high level.
After the high-level, the system will start the heating process till set temperature.
Inputs/Outputs List
Inputs List
  • START PB :- I0.0
  • STOP PB :- I0.1
  • Low level switch :- I0.4
  • High level switch :- I0.3
Outputs List
  • Inlet valve :- Q0.0
  • Heater :- Q0.1
  • Outlet valve :- Q0.2
Memory List
  • Master coil :- M0.0
  • Actual temperature :- MW12
  • Set temperature :- MW14
PLC Logic for Heater 1
PLC program for heating liquid
Logic Description
Network 1:
Master coil (M0.0) will start when START PB (I0.0) will be pressed and cycle can be stopped by pressing STOP PB (I0.1).
Network 2:
When low level switch (I0.4) is detected, inlet valve (Q0.0) will be ON.
Network 3:
When high level switch (I0.3) is detected, heater (Q0.1) will be ON.
Network 4:
If actual temperature (MW12) is greater than set temperature (MW14), outlet valve (Q0.2) of the tank will be ON.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of heating the material in the tank as per requirement in industry, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Result
Author: Bhavesh
  • Liquid Level Switch Control Logic
  • PLC Seperate Different Size Objects
  • Control Level of Series Tanks
  • PLC Water Level Control
  • Selective Execution of Application
Procedure for Siemens S7-300 Download from PC to PLC
PLC Programming using Level Switches
Cars Garage Counter From the Same Door PLC Logic
OMRON PLC Math Instructions: +(400), -(410), *(420), /(430)
Types of Industrial Control Systems
Function Blocks in PLC (FBs) – What You Need To Know?
4 Comments
  • Malvern Jones says:
    October 28, 2018 at 6:57 pm
    The above example is a very crude example of “temperature control” as the temperature of the liquid will not be controlled at the set value. It will instead rise above the set point and fall below the set point.
    The variation between the highest and lowest temperatures that will be experienced will depend on the power rating of the heater, compared to the cooling of the vessel. It true temperature control is required, then PID temperature control should be used in the program.
  • Jairo Francisco Oliveira Paula says:
    August 13, 2019 at 4:12 am
    I have no experience but I would like to create simulator supervisors and use this example for academic purposes .. thank you very much
  • BISWANATH says:
    July 16, 2021 at 10:44 am
    ITS NOT WORKING AS PPER the ladder diagram.
    the nt:-2 the o/p will dependent upon high level sensor :”Q0.0″
  • Negussie says:
    November 17, 2021 at 2:19 pm
    Thank you it helps me a lot.
Most Asked Questions on SCADA with Answers
PLC Ladder Logic Questions and Answers
PLC Digital Input and Digital Output Modules
PLC Controlled Conveyor and Weighing with Labeling Automation
Difference between Machine Expert Basic and Machine Expert – Schneider PLC
PLC Programming Example on Bottle Line Control
Basics of Motion Controllers
Difference between Analog Signal and Digital Signal
Traffic Lights Ladder Diagram using Timers
Check Block Consistency Tools
Check Block Consistency Tools in Simatic Manager
PLC Programmer Tools
Allen Bradley RSLogix 500 PLC Programming
Relay Motor Logic Circuit
Motor Control Circuits
Annunciator Panel
What is a Annunciator Panel?
PLC and MCC Panel Interface Design
How to Read an Electrical Wiring Diagram
How to Read an Electrical Wiring Diagram?
Nuisance Alarms
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Parts of Safety PLC
SIS Software Simulation – Safety Instrumented System
Purpose of Isolation valve
Repeat Failures of Letdown Valves
Aluminum CNC Machining Complete Guide
Aluminum CNC Machining: A Complete Guide You Cannot Miss
Synchronous Motors Quiz
SIS PFD - Safety Instrumented System
SIS PFD – Safety Instrumented System
Process Switches Normal Status
