Electrical engineering root cause analysis (RCA) related to HT motors corrosion problem, motors burnouts, and their solutions.
Article Type: | Root Cause Analysis (RCA) |
Category: | Electrical |
Equipment Type: | Motors |
Author: | S. Raghava Chari |
HT motors Corrosion Problem
Motors ventilating tubes severe corrosion posed problems are:
- Fan blown air carried hygroscopic corrosive dust corroded and stuck hard to the carbon steel ventilating air tubesÂ
- Consequent reduced winding cooling and in turn high windings temperature especially in the motors with no winding temperature indicator threatened premature winding burnouts
- Holes seen on the tubes after 5-years despite anti-corrosive bore painting added to the above threats and demanded immediate solution
Authors Solution
After several deep-thinking days the author proposed the below given solutions:
- Re-tube the motors with thinner walled SS-316 SS tubes; his reasons are:
- Air velocity and turbulence influence heat transfer most and tube material thermal conductivity least.
- SS does not corrode; hence no non-cleanable hard-stuck and poor thermal conductivity dust coated tube bores → better than design heat transfer → effective winding cooling → acceptable winding temperatures → vanished winding burnout threats
A lesson learnt
Expanding the tubes without the end-shields in position in the first instance distorted the motor frame; hence the motor body necessary extensive repairs delayed the motor reassembly by a month and absent spare motor threatened long plant shutdowns (SDs).
Having learnt the lesson the hard way, the crew re-tubed with end shields in position, did not expand the tubes but just m-seal sealed the tubes to motor body joints as the author advised.Â
RCA solution Benefits:
Implementing RCA solution Benefits are
- Thanks to no corrosion, the dust did not stick hard to the tube bores
- Hence, during plant cleaning shutdowns long brushes removed most of the dust
- Water soaked squeegee brush mop out followed by dry squeegee mop out tubes were metal clean
- These steps preserve the designed in winding cooling; hence winding burnout threats vanished forever.
Author: S. Raghava Chari
- Poor Power Factor Problem
- Aluminum Cable Terminations
- HT Motor Direction of Rotation
- Inability to Test Repaired HT Motors
- General Corrosion of Electrical Motors
