    • Process Fundamentals
Reading: How to Use ModScan Software for Testing Modbus Communication?
  • Control Systems
Inst Tools > Blog > PLC Tutorials > How to Use ModScan Software for Testing Modbus Communication?
In this post, we will see how to use Modscan software for testing Modbus communication in industrial applications.
Last updated: September 4, 2023 12:10 pm
Modbus communication is a widely used communication protocol in industrial automation. It is basically divided into three types – Modbus TCPIP, Modbus RTU, and Modbus ASCII. Modbus TCPIP uses Ethernet communication, whereas Modbus RTU and Modbus ASCII use serial line communication.
Apart from PLC, these protocols are also available in many devices like fire alarm annunciators, variable frequency drives, PID controllers, etc. This means, many devices nowadays provide these protocols so that users can get maximum data from them as much as possible.
So, PLC programmers need to know that there are many software available to test the protocol in these devices. One of the most common and simple used software is Modscan. In this post, we will see how to use Modscan software for checking Modbus communication.
ModScan Software
When you download the setup file of Modscan on your PC, you will see the following files below. As per the image, double-click the application file. Directly, the software will run through this, without a need for installation.
Download Modscan Software: Click Here
ModScan Software
As soon as you run this application, you will get four popups asking the user to register. This is shown in the figure below.
Modscan32
You just need to press the Esc button every time a popup appears. It means you can run the software for a demo time of mostly 5 minutes.
Modscan Software Registration
Then, the software will expire and you will have to close the software window and again follow this process to start running it once again.
Modscan Software Link
WinTECH Software Site
Once you have closed all four of these windows, you will get the following window as shown below. This is the main running window.
Here, you have to choose all the parameters required to establish successful Modbus communication with the device connected.
Enter the following details first – register address, length, device ID, and register type (function code).
Once you have entered all these parameters, the next step is to connect the device. Click connect in the connection tab of the toolbar, and you will get the following popup as shown below.
This setting allows you to connect to the device by choosing any three protocols – TPCIP, RTU, and ASCII. If you are connecting to a Modbus TCPIP device, then just select Remote Modbus TCP server as shown below and enter the IP address of the device in the next tab (shown below as 192.168.1.192).
Keep the service port as 502 and just hit the OK button.
Remote Modbus TCP Server
If you are connecting to Modbus RTU or ASCII device, then first click protocol selections as shown below and you will get the following popup.
Before that, change the connect using the tab to the COM port of your PC.
Modbus Protocol Selection
For example, if you have connected your USB to a serial converter in COM1 of your PC, then select the option as shown below and enter details like baud rate, data length, parity, and stop bit.
Modscan Configuration Parameters
After clicking OK, if the device has established communication with the PC, then it will show the values, else it will give errors depicting what is the issue.
You can change the display format option as shown below, for viewing the data in the required format.
Download Modscan software
In this way, we saw how to use Modscan software on a PC to check Modbus communication with the device.
  • MOVE Instruction in PLC
  • Allen Bradley PLC Hardware
  • Motor Classic Control Circuits
  • Control System Cyber Security
  • How to Design an Effective HMI?
MOVE Instruction in PLC – What You Need to Know?
Difference Between PLC and RTU?
Compare Two Offline PLC Projects
PLC Program for Controlling a Water Pump with 3 Power Sources
208kSubscribersSubscribe
PID Block in RSLogix 500
Functional Block Diagram in PLC for Oil and Water Process
Peripheral Inputs and Outputs in Siemens PLC
PLC based Door Open and Closing System
Difference Between CompactLogix and ControlLogix
PLC Light Sequence Control using Bit Shift Registers
Classroom Bell System – PLC Programming Practice Examples
Difference Between Wifi and Industrial Wireless
plc-analog-signals-wiring-techniques
PLC Analog Signals Wiring Techniques
Sorting Defective Parts PLC Logic
Advanced PLC Programming for Defective Parts Sorting
Two wire loop powered transmitters
User Defined Data Types - UDT
User Defined Data Types (UDT) – Purpose, Need, Tutorial
Liquid management using PLC programming
PLC Programming for Loss in Weight Liquid Systems
Step-by-step import export in FactoryTalk View
FactoryTalk View Studio – Import and Export Tutorial
Types of PLC Memory
Types of PLC Memory
Sink or source PNP or NPN Normally Open or Normally Closed Input v. output. output
Dall Tube Flow Meter Working Principle
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Types of Angular Velocity Measurement
Tags in Functional Block Diagram in Studio 5000
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
Ball Valve Pictures
How Ball Valves Work ?
HVAC System
What is HVAC System?
Simple RC Circuit
Impedance in RC Circuits
control of temperature in a vessel
How to Analyze PID Controller Actions
Failsafe interlock Design
Failsafe Wiring Practices
