  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Doubtful Temperature Readings threatens Soaking Pit Wrecks
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Root Cause Analysis (RCA) > Doubtful Temperature Readings threatens Soaking Pit Wrecks
Instrumentation engineering root cause analysis of doubtful temperature readings of temperature recorder that threatens soaking pit wrecks.
Last updated: September 28, 2022 2:51 pm
S Raghava Chari
3 Min Read
Soaking Pit Doubtful Temperature ReadingsProblem Repeats Eliminated
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Instruments
Author:S. Raghava Chari
The pit supervisor asserted the temperature recorder read temperatures are incorrect and stubbornly refused ingots charging, though the temperature recorder and supporting temperature indicator read the same. The instrument crew repeatedly calibrated both and assured all are OK!
The author was called upon to resolve the issue checked the pit wall temperature with an optical pyrometer and agreed with the pit supervisor.
He checked with the crew who made the thermocouples and found that they had by mistake made the TC out of Pt. Rh 10%-Pt. wire pair and not out of recorder & indicator calibrated Pt. Rh 13%-Pt. wires – the problem root cause.
He appreciated the pit supervisor for his judgment; Charged, Ingots would have melted and ruined the revamped pit. Clearing the solidified steel out of the pit and revamp would have put the pit and reduced the rolling mill output several weeks.
Since that plant’s most temperature measurements calibration is Pt. Rh 13% – Pt.
The author eliminated the recurrence of the problems thus:
  1. Made Pt Rh 13-Pt TC wires the plant standard
  2. Exchanged the unused Pt-Rh Pt TC wire rolls with Pt Rh 13 – Pt wire rolls
  3. Changed the measuring circuit card of all Pt Rh 10 – Pt calibrated instruments with Pt Rh 13 Pt cards and marked the scales Pt Rh 13 Pt and verified the calibration
Author: S. Raghava Chari
  • Target Flow Transmitters Failed
  • Multistage Flash Drums Readings
  • Rotameter Caused Pipe Weld Cracks
  • Level Instruments Stopped Working
  • Differential Pressure Transmitter Problem
Recommended Articles
Control Valve Passing Problem after Overhauling Job
Pressure Switch Frozen Screwed Cover Extends the Plant Shutdown
Problems with Demister Pads – Root Cause Analysis (RCA)
Pulverizer Electrical Problem Solved
Poorly Engineered, built & often Failing Plant Air Compressor Drives
Within Few Weeks Failing Acid Dozing Pumps
208kSubscribersSubscribe
Recent Comments
Related Articles
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
BP Refinery Explosion
Learnings from the BP Refinery Explosion at Texas City
Mechanical Temperature Indicators (MTI) Problem
HT motors Corrosion Problem
Fasteners and General Corrosion of Electrical Motors
Erratic Radar Level Gauges
Erratic Radar Level Gauges Delays a Refinery Commissioning
HT Motor Direction of Rotation (DOR)
HT Motor Direction of Rotation (DOR) Changed
More Articles
Ladder Logic for Motor Control
PLC Programming for 3 Motors control in Ladder logic
hall-effect-sensor
Hall Effect Sensor Working Principle Animation
four-way-solenoid-valve-diagram
Four Way Solenoid Valve Working Principle
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Overview of Proximity Switches
Robotic Instrumentation Objective Questions
Three Wire RTD Wheatstone bridge Circuit
RTD Wheatstone Bridge Circuits
Functional block diagram for analog alarms
PLC Logic for Analog Alarms using Functional Block Diagram
