  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Control Systems > Design Process Graphics in Factory Talk View Studio with an Analog Input
In this article, you will learn the configuration of Analog input (P-AIn) Process Graphics in Factory Talk view Studio.
Last updated: July 23, 2022 12:07 am
Control Systems
We are going to Configure Analog Input as a temperature transmitter in FT view Studio with PlantPAx DCS Library 4.10.00.
It Helps you to view Analog Input as a better functionality with user-based objects which helps you understand and troubleshoot the operation.
Factory Talk View Studio Process Graphics
Step 1: Open Factory Talk View Studio SE Application as shown below and click on Local Station/Network Distributed as per system architecture.
Step 2: After selecting the local station/Network Distributed click on a project created previously or create a new project.
PlantPAx New Project
In the language section, select the language appropriately or else it can lead to errors in process graphics.
Step 3: After Opening the Project Right Click on Display and Click on New, to create a new display.
FactoryTalk View Studio Process Graphics
Step 4: After creating a new project (I have created an Analog-Input display) open the P-AIN Graphics Library from the global objects section.
Step 5: Analog inputs in the library are applicable for the Analog input block, Analog input advance block, etc.
Analog inputs in library
Select and copy PV Indicated by value Analog input from the library as shown below.
Since there are other analog input display bars also but which we are selecting are standard one which has all relevant objects needed for operation.
Step 6: Once copied in the display, right-click on the object and click on Global Object parameter values.
In#102: Enter Object Tag
In#103: Enter Path
In#120&#121: If an additional display parameter requires then you can enter X (*) or CC, which means it will help you to display the parameter popup as per your coordinates set in runtime (It is optional).
In#122: Enter as value 1 and click on OK.
FactoryTalk View display parameter
Step 7: Same you can configure for required analog inputs such as Flow Transmitter, Pressure Transmitter, Weight Transmitters, etc.
Step 8: Click on the Runtime button to launch runtime.
FactoryTalk View Studio Runtime button
Step 9: Click on create SE runtime (Client file)
FactoryTalk View SE Client View
Step 10: write the file name as you want, I have written it as PlantPAx, and click on continue.
FactoryTalk Vie Studio File
Step 11: Select application type if it is a network distributed, then need to select HMI Server name and Initial Display name, if required you can select macros or else leave blank.
PlantPAx File
Step 12: Click on the Advanced button deselect all and select maximize the window and click on save and run.
FactoryView Talk Studio Client Window
Step 13: After clicking on run you will see Runtime Screen with Analog input as shown below.
Step 14: Click on Analog Input to view Faceplate as shown below.
Home Button shows Analog-Input value in units with trends as shown below image.
FactoryTalk View Studio trends
The settings button indicates your threshold and dead band values you can configure
here as well as in logic.
Raw Input in PlantPAx
This button indicates Raw input and Process value from raw input through scaling.
Note: Signal failure is showing because I have not connected any IO modules.
Process value in FactoryTalk View Studio
The alarm Button shows HI, HIHI, LO, and LOLO alarms tab, they will flash when the analog input value reaches beyond defined limits.
real time data in PlantPAx
Trend Button shows Actual real-time data or value of transmitter you can view logged value for a specific time.
Difference Between Serial and Parallel Communication
What is a Transducer ?
Relay Operation, Types, Symbols & Characteristics
DCS Quiz
Heuristic PID Tuning Procedure
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Facebook Copy Link Print
208kSubscribersSubscribe
Basics of Process Control Systems
Recognizing a Porpoising PID Controller
4-wire Transmitters Current Loops
Basic Concepts of the Safety Relay
Design and Implement Motor Control – Electrical Engineering
Design Process Control & Safety Systems
Design View of Supplying Process Control and Safety Systems
On-Off Controller example
ON-OFF Controller Principle
Industrial Automation Mobile Apps
Tips for Reducing the Noise Signals
Split range control scheme
Overview of Split Range Control
Control Valve Direction of Control Action
PID Controller Action : Directing Acting & Reverse Acting
PID Simulator
PID Simulator Download
Difference Between PNP and NPN Sensors
Discover More
Two Tanks Filling using PLC
PLC Ladder Logic for Tanks Filling as per Priority
two-way communication between PLC systems
Transferring Data Across PLC Systems – TSEND_C and TRCV_C
Induction Motor Rotor Frequency
parallel-resistors-circuit-example
Series and Parallel Resistors
Interferometer Principle
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Pressure based Flowmeters
Pressure based Flow Meters
Sensor Based Projects List - Electronics & Electrical
350+ Sensor-Based Projects List – Electronics & Electrical
