Reading: Cooling Tower fan FRP fan blades saves and saves
Inst Tools > Blog > Root Cause Analysis (RCA) > Cooling Tower fan FRP fan blades saves and saves
Root Cause Analysis (RCA): Cooling tower fan FRP fan blades saves and saves.
Last updated: September 28, 2022 3:15 pm
S Raghava Chari
1 Min Read
Why and Benefits:
Closest to design contour aerodynamic shape – not possible with cast or extruded aluminum blades – hollow FRP blades weigh 1/5 metal blades;
In addition ever remain stronger than cast metal blades of questionable quality and corrosion proneness.
Hence the motor power consumption reduces by 10‑15% and the blades last and last. Both save power costs 15% for all time to come and maintenance costs 80%.
Another valuable benefit is easy and quick fan blades availability at far lower costs from a local vendor for max cell availabilities.
Author: S. Raghava Chari
  • Plug Valves Leaks
  • Rupture Discs bursts
  • Repeat Safety Valve Popping
  • Fan Bearing Change Times cut by 90%
  • Boiler Feed Water Shell Flange Leaks
Cooling Tower Fans Frequently Failing
Poor Bagging Scale Availability Threatened Production Cuts
Flanged Rotameter Caused Pipe Weld Cracks and Gives Wrong Readings
Too often done riskily repaired Roof Hot Spots eliminated forever
11 KV Bus A to Bus B Phase Check Problem
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Captive Power Plant Trip Root Cause Analysis
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Inability to Test Repaired HT Motors in Workshop Posed Problems
Thermocouple Extension Lead Problem
[RCA] Pump Low throughput Eliminated
Gearbox within week Failing Journal Bearing upset Plant Operations
Seal Pressure Instruments Root Cause Analysis
Junction Box Cooler
Junction Box Internal Corrosion Problems and Solutions
Multistage Flash Drums Erratic Level Readings
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
Tilting Pad Bearing
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
CO2 Stripper Collapsed Internals Revamp
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
Welding Machine Fail in Dusty and Corrosive Areas
Thyristor Chopper Circuit Quiz
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
PLC Program for Automatic Door Control System
PLC Automatic Door Control System – Programming Example
What is a Photoelectric Sensor
What is a Photoelectric Sensor?
Digital Electronics Objective Questions – Set 1
Differential Pressure Sensor with pair of Strain Gauges
Differential Pressure Sensor with Pair of Strain Gauges
Difference Between Contactor and Relay
Magnetostrictive Transducers Objective Questions
