Root Cause Analysis (RCA) related to the Condensate Pump Frequent Wrecks Threatens Long Plant Outages.
| Category: | Mechanical |
| Equipment Type: | Miscellaneous Rotating Machine Problems |
Problem
Several large steam turbines condensers condensate collects into two buried tanks. The tanks to 20% is above ground (below figure).
Tank 1 has top mounted turbine driven submerged pump and tank 2 motor driven same standby pump.
During many pump changeovers many pumps’ carbon bushes supporting the long shaft coupling to the drive failed. At nearly all spares used up condition the belabored engineer sought the author’s SOS help.
Author Solution
The root cause analyzing witnessed a pump changeover: Operators opened the 3” waterside valve (above figure) to fill the condensate collection tank. They were about to push the motor start PB.
Hold, shouted the author and asked, “Have you opened the steam side valve?” The perplexed operator grinned and said, “Steam side valve, Sir, no supervisor told me to open it”.
The author called the operations engineer and he too was ignorant of the steam side valve. The author explained, “the condenser is under high vacuum. Hence, unless the pit tank top is open to the same vacuum water cannot flow into the tank.
Hence, you must open both the ¾” steam side and the 3” water valves and wait for 5 minutes to be sure of enough condensate collection to submerge the pump. So far you have been wrecking pumps because of dry running!”
The sheepish operator opened the steam side valve also, waited 5-minutes and then changed over to the motor driven pump safely. Thus, the author prevented another wreck and all future wrecks!
By a memo, the author requested the operations manager to revise the pump start up procedure and to hold classes for all operators, and shift engineers in Arabic.
Author: S. Raghava Chari
- Turbo-Compressor Problem
- Compressor Anti-Surge Control
- Plant Air Compressors Problems
- Plant Turbo-compressor Problem
- Failing Plant Air Compressor Drives
