Reading: Write a PLC Program for Selector Machine using Structured Text
Inst Tools > Blog > PLC Tutorials > Write a PLC Program for Selector Machine using Structured Text
Learn how to write a PLC program for a selector machine. Understand the logic and structured text language used in this post.
Last updated: September 18, 2024 3:22 pm
6 Min Read
In this post, we will see a PLC program for writing a selector machine logic using structured text language.
Write a PLC Program for Selector MachineStructured Text Language
Let us understand the case scenario first. There are four tanks supplying ingredients to a common mixture tank. According to the recipe made by the operator, the selected ingredients will be fed to the common tank for a set time. If any of the tank levels are low, the process will not run and halt at the corresponding stage.
The operator will manually fill the tank and wait for the level to become normal. If the collection tank level becomes high, then the process will abort or reset; this is because the recipe is designed properly, and filling the tank fully means there is some abnormality in the recipe or process.
After the recipe time is completed successfully, the cycle will reset and wait for the next start operation from the user. Pressing the start button starts the process, pressing the stop button pauses the process, and pressing the reset button resets the process.
According to our requirements, these are the following PLC IOs:
  1. Digital inputs – start push button, stop push button, and reset push button.
  2. Digital outputs – tank-1 discharge valve, tank-2 discharge valve, tank-3 discharge valve, and tank-4 discharge valve.
  3. Analog inputs – tank-1 level, tank-2 level, tank-3 level, tank-4 level, and common tank level.
Let us now see the logic for this process. Refer to the below image. First, we will create a logic for starting, stopping, and resetting the logic. We will use two main bits in the logic – cycle running and cycle started.
Cycle running can be started or paused anytime, but the cycle started is a latched bit. It latches once the cycle starts and resets only on reset condition. If the start button is pressed, then we set both these bits.
If the stop button is pressed or if the cycle is not started, then we reset the cycle running bit. If the reset button is pressed, then we reset the cycle started bit.
Next, we use the batch cycle counter for the process timer. We use a set value of 10 seconds. If the cycle is running, then the counter increments every second. If the cycle is not started, then the counter remains in reset condition. And when the counter is done, then we reset the cycle started a bit.
Now, we will write the logic for the step counter. We use three-step setpoints, which will be written by a recipe in HMI. If the current batch timer value is less than setpoint-1 and the cycle is started, then we are in step number 1.
If the current batch timer value is greater than setpoint-1 and less than setpoint-2 and the cycle is started, then we are in step number 2. If the current batch timer value is greater than setpoint-2 and less than setpoint-3 and the cycle is started, then we are in step number-3. If the cycle is not started, then we are in step number 0.
Next, we need to turn on the valves according to the recipe. The recipe will change its set values according to the current step number. So, we create a case statement of four values.
  • If tank number 1 is selected, then we turn on valve 1 and turn off the remaining valves.
  • If tank number 2 is selected, then we turn on valve-2 and turn off the remaining valves.
  • If tank number 3 is selected, then we turn on valve 3 and turn off the remaining valves.
  • If tank number 4 is selected, then we turn on valve 4 and turn off the remaining valves.
Now, we will write the logic for pausing and aborting the logic. If any of the tank levels is less than 100 liters, then we reset the cycle running bit.
If the common tank level is more than 500 liters, then we reset the cycle started a bit.
If the cycle is not running, then all the valves will remain off.
In this way, we saw how to write a PLC program for a selector machine using structured text.
  • PLC Program for Sequential Motor Control
  • Run Motors Sequentially using PLC Program
  • Sequential PLC Program Pneumatic Valve
  • PLC Program for Water Level Control Logic
  • Structured Text PLC for Sequential Process
Functions of SCADA
How to Check Address Overlapping in Tia Portal?
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Basic PLC Ladder Programming Example
Function of Racks in PLC – Types of SIEMENS S7-400 PLC Racks
How to Choose a Suitable HMI for Your Application?
PLC Program using START and STOP Buttons
Exhaust Fan Control: Example of PLC Timer Programming
Single-acting Pneumatic Cylinder Operation with Limit Switch
How to Select a SCADA for New PLC Project?
PLC Analog Input Card Resolution Effects on Accuracy
OMRON PLC program for waste-burning automation
Waste-Burning System OMRON PLC Program Example
Types of PLC
Types of PLC
Free Download PLC Book
Profibus DP Master
DP Master System Configuration in PLC
PLC Subroutine
Allen Bradley PLC Subroutines
PLC Program for Burglar Alarm Security System
PLC Program for Alarm Security System
PC-Based Motion Controller
Various Types of Delta PLC used in Industrial Automation
Example of Automated Guided Vehicle with PLC
Programmable Read Only Memory Objective Questions – Part 1
Process Control & Instrumentation Objective Questions – Set 6
Capacitor Principle
Capacitor
Selecting the Best Inductive or Capacitive Sensor
What is OTDR Testing
Understanding the Difference between HOP Test and OTDR
Electrical Engineering Interview Questions
Difference Between Industrial Computer and Normal Computer
Difference Between Industrial Computer (IPC) and Normal Computer (PC)
