Reading: Why Baud Rate is Important in Modbus Network?
Inst Tools > Blog > Communication > Why Baud Rate is Important in Modbus Network?
Learn why baud rate is a critical parameter in Modbus communication and understand how it affects your industrial automation processes.
Last updated: September 18, 2024 1:14 pm
Communication Control Systems PLC Tutorials
2 Comments
6 Min Read
Modbus is a protocol that is used widely in industrial automation. Modbus has two types of communication – RTU and ASCII. Modbus RTU is used mostly everywhere due to its simplicity in coding and configuration.
What is the baud rate in Modbus?How to set the baud rate for Modbus?Why Baud Rate is Important?Standard Baud Rates
Modbus is a serial communication, which is used due to it’s easy working and also allowing complex communications to be solved. In the Modbus RTU, one parameter that must be taken special care is the baud rate. In this post, we will see the concept of baud rate and understand why it is important for use.
Modbus has the following parameters to set –
  1. address
  2. data bit
  3. stop bit
  4. parity
  5. baud rate
All these five parameters must be set properly for correct modbus communication. Let us see what the baud rate is now.
Baud rate is a measure of communication speed in Modbus protocol. Data is transmitted in the form of bits, and that speed of communication per second is called the bit rate. Now, some bits make one symbol or a group. How much such symbols are communicated in one second, defines the baud rate.
The Baud rate specifies how fast the symbols (data) will be transmitted or received between two Modbus devices. It is also defined as the number of signal changes per second. In contrast, the bit rate is defined as the number of bits transmitted or received in a second.
So, for example, if a symbol carries three bits, then the bit rate will be thrice the baud rate. Do not get confused between both the terms and the major study area that is used in the configuration is the baud rate and not the bit rate.
For example, if the baud rate is 19200, then it means 19200 symbols can be communicated maximum in a second.
Baud rate should be the same in both the master and slave devices. It is not like one device will be set to 19200 and another at 9600. Otherwise, communication will not happen.
Every manufacturer, when giving a Modbus device, will specify a default value in its operating manual. This simplifies the task firsthand. It gives an impression as to how their device is capable of performing. Then, once you have studied that, you can try to manipulate the baud rate.
As baud rate is directly related to speed, the factors to look for changing this parameter are – the distance between two devices, the total number of slave devices connected with the master, noise level, and the amount of data being transmitted. If the distance is large between devices, the baud rate should be kept to a low level.
If the rate is high, then the device will try to throw symbols at a fast rate and there are chances that it will not reach the destined device in such a short time. If there are a large number of slave devices (a maximum of 255 can be connected to a master in Modbus), try to baud rate to a low value. This will ensure that data will reach each device effectively.
Otherwise, data will skip and not reach some devices smoothly. If the nearby EMI (electromagnetic interference) noise is higher and affects the signal performance, then too the baud rate should be kept low. And at last, if the data is bulk and large, then too the baud rate should be kept low. This ensures that each and every data reaches the device in a proper time.
This all shows that a high baud rate is preferable for short distances, a short number of total slave devices, low noise interference, or a low amount of data. One main reason for this is that Modbus is serial communication and data is transmitted serially, meaning each data should reach the device in line.
Standard Baud Rates
The standard baud rate values are –
  • 9600
  • 19200
  • 38400
  • 57600
  • 76800
  • 115200.
The two widely used rates in Modbus are 9600 and 19200. So, to determine the best baud rate, you must look at both the factors – speed and data reliability. Anyone cannot be tampered with, otherwise, communication will not happen properly. Both factors should be considered for proper optimization of data.
In this way, we saw how the baud rate is important in Modbus.
  • Modbus Function Codes and Addresses
  • Understanding RS-485 Communication
  • Modbus Reading and Writing Data Basics
  • How did Modbus Communication work?
  • Python in Industrial Automation System
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
Process Control Loop Testing
Automatic Empty Bottle detection using PLC Logic
Can a PLC Function Without an HMI or SCADA?
PLC Program with 2 Toggle Switches and 4 Motors
2 Comments
  • MD SHAHBAZ ALI says:
    November 12, 2024 at 10:27 am
    My top reason to join with you to know about all the industrial transmitter and instruments valve troubleshooting plz
    November 12, 2024 at 10:28 am
    Troubleshooting
Electrical Ladder Diagram Control using Timers Example
PLC Functional Block Diagram for Logic Gates
FactoryTalk Studio and SQL Server for Data Logging
PLC Sequential Operation Example Program
Basics of Motion Controllers
Converter Instruction in Siemens PLC Programming
Advanced Process Control
What is Advanced Process Control (APC)?
Rack Type PLC
PLC Input Output Modules
Yokogawa DCS CPU
System Cabinet Health Checks – PLC and DCS Industrial Automation
Conveyor Sorting Machine PLC Program
Conveyor Sorting Machine PLC Program with Calculation Function
Turbine Bypass System
Ziegler-Nichols Closed Loop Tuning Procedure
PID Controller Functions
Siemens SIMATIC S7 PLC GSD File
How to import GSD files into the TIA Portal? – Siemens PLC
Hydrazine analyzer Working Principle
Hydrazine Analyzer Working Principle
Turbine Flow Meter
All About Turbine Meters
PLC Controlling a Motor
PLC Motor Control Ladder Logic Programming
Advantages of Industrial Automation
Advantages and Disadvantages of Industrial Automation
Diaphragm Seal Transmitters Errors
What to Choose RTD or Thermocouple ?
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Pressure Transmitter Troubleshooting Tips
