Reading: Upgrading and Migration of PLC Systems
Inst Tools > Blog > PLC Tutorials > Upgrading and Migration of PLC Systems
In this post, we will learn the difference between upgrading and migrating PLC systems and understand how to implement the correct one.
Last updated: September 21, 2023 1:22 pm
9 Min Read
Be it industrial automation or any other PLC system, every device or equipment reaches a stage after a certain period of time, where there arises a need to either change it or upgrade it.
Upgrading and MigrationWhy is Migrating or Upgrading PLC Systems Required?What is the Migration of the PLC System?What is Upgrading of PLC Systems?Difference between Migrating and Upgrading PLC systems
A PLC, if served for more than 10 years for example, will reach a stage where its technical support no longer exists or the PLC is not available for replacement as it has become obsolete. In this case, you are left with two options – either to migrate to a completely new set of PLCs or upgrade the firmware and program. This difference is really important to understand, as it helps in choosing the right work for the same.
Before going into the topic, it is first of all necessary to understand why we need to do the same. Suppose you have been using an “X” PLC for almost 15 years down the line. It is not like the program will start to malfunction suddenly; it is a completely different theory and entirely depends on how the programmer has written the code. PLC Code once written executes the same way for a lifetime as it is.
The issue starts with hardware and support. A PLC manufacturer mostly won’t keep this “X” PLC in production for such a long period of time if it is not stable or has many limitations in programming.
Sooner, this PLC will start to become obsolete and its replacement will not be available. Even the system integrator or the PLC manufacturer itself will not be able to provide its technical support as the staff for the same will be shifted to a newer brand or its programming cable is also no longer available.
In that case, if suddenly the PLC system fails due to some reason, then you are left with no option but to wait for a longer downtime period to end. Also, if you are still able to get this PLC from somewhere, then its cost will be super-high and out of budget.
With the current supply chain disruptions and the recent scarcity of new industrial automation solutions and parts, it’s not feasible to estimate exactly how long it might take to source a new unit. In that case, you are left with two options – either to migrate to another brand or upgrade the existing one to a newer firmware CPU or program.
So, it is this reason why migration and upgradation play an important role in industrial automation. Also, new solutions bring with them reduced errors, and risks, stronger technical support, service expertise, less capital investment, and efficient operation of plant.
First of all, let us understand the simpler one of the two. Migration means to completely replace an old system with a new system. This is similar to a citizen migrating from his previous city to a new city. Suppose you have an old PLC that has some hardware defects in it after it has been found 10 years old.
Two digital inputs of the CPU have become faulty and the CPU is no longer available in the market. Also, due to some bad luck, the system integrator which provided the PLC has shut down his business or shifted to some newer brands.
In that case, migrating means you will need to buy a PLC of some other brand. Before buying, you will need to consider factors like IO counts, IO wiring, communication port availability, programming capacity, memory capacity, speed of execution, how much it can be expanded, etc.
Once you get through all this, you will then need to buy a new one and write a new program in it according to the manufacturer’s software. Also, you need to share the previous IO list with the new vendor, so that he will do the IO mapping in PLC accordingly and will reduce time to wire the IO’s in the electrical panel. Once done, you can replace the old PLC with the new one and use the system accordingly.
Although new and consistent programming standards can’t be fully applied using this approach, the overall functionality remains as close to the original as possible, and the program can be improved to some extent.
Let us take a second case of upgrading the PLC system. You have the same PLC of the manufacturer as discussed before and its failure has occurred. Now, you find that some higher level of PLC of the same manufacturer is available, with similar coding style and IO functionalities.
Even the vendor is available for support. Instead of changing the vendor to a newer one or completely changing the PLC brand, you will just need to upgrade your system to a newer and higher one. This new CPU will have to be either rewritten with the new coding or just plugged and played, depending on the software. An upgrade thus, requires a more comprehensive IO wiring and PLC coding to be done as we update the system.
Also, rewriting new codes from scratch allows the programmer to eliminate the bugs he had observed in older systems and also plan for efficient and reliable logic in a simpler manner. This is a clean slate approach to upgrading a system.
  1. Migration means switching to a completely new PLC manufacturer, whereas upgrading means switching to a newer CPU of the same PLC manufacturer.
  2. Migration is cheaper than upgrading, as it requires less downtime, less new hardware, less programming time, and designing infrastructure.
  3. Migration is less risky than upgrading, as you already have the program available of the older one, and you just need to copy-paste the same. Though 100% copy is not possible, functionalities can be similar in a large way due to this approach.
  4. Migration can lead to new hardware and this can take time for engineers to understand the system quickly so that then they can maintain and troubleshoot it. In this case, upgradation is much easier.
  5. Migration is less reliable and efficient than upgrading because you do not know how this new PLC will function now in spite of studying it so much.
Migrating and upgrading is a tricky thing to do and requires the detailed expertise of engineers and programmers involved in it. Also, what action to take varies from system to system. Once done, it can make your task completely easier. In this way, we saw the concept of upgrading and migrating PLC systems.
  • Motor Faceplate in Graphics
  • HMI and VFD Control System
  • Update PLC Firmware Version
  • PLC Sorting Machine System
  • PID Controller Control System
PLC Programming Examples on Industrial Automation
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Coil Type Timers in Siemens PLC Programming
MOVE Instruction in PLC – What You Need to Know?
PLC Program for Daily Production Record
Procedure for Siemens S7-300 Download from PC to PLC
  • Rodnei says:
    September 21, 2023 at 3:54 pm
    Migration is cheaper than upgrading,…
    Migration is less risky than upgrading, … (It depends …)
    Are these 2 issues correct?!!!
Function Blocks in PLC (FBs) – What You Need To Know?
PLC Analog I/O and Network I/O
PLC Program for Washing Machine
Best 100 PLC Projects for Final Year Engineering Students
Proper Earthing Practices Used for PLC Control Panel
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
PLC Sequential Lights Control Example
PLC Timer Example: Sequential Control of Three Lights with Reset
Comparison Instructions in PLC Programming
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Ladder Logic for Stair-Case wiring using Toggle Switches
Comparison of Proportional Integral Derivative Controllers (PID)
Relay Permissive and interlock circuits
What is Air Circuit Breaker
What is an Air Circuit Breaker? Working Principle & Applications
Career Scope in Electrical Engineering
Transistor Emitter Feedback Bias
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Random Access Memory Objective Questions – Part 1
Calibrating Transmitter System One Seal with suppressed Zero
Calibrating Level Transmitter with Remote Seals
Closed Tank Level Measurement Formula
Siemens Differential Pressure Transmitter Calculations (Flange Type)
