Reading: Traffic Light Control using PLC Ladder Logic
Inst Tools > Blog > PLC Tutorials > Traffic Light Control using PLC Ladder Logic
Last updated: March 4, 2021 3:55 pm
2 Comments
3 Min Read
We most often come across a three-way traffic jam in our city. This PLC program gives the solution to control heavy traffic jams using programmable logic control.
Traffic Light Control using PLCProblem SolutionList of Inputs and Outputs for Traffic Control SystemPLC Program for 3-way Traffic control SystemPLC Logic Description for 3-way Traffic Control SystemConclusion:
traffic light plc program
Problem Solution
  1. They are so many ways to write a program for traffic light control ex: sequencer output method but in this normal input, outputs and timers are used.
  2. Timers are used to give time delay for output to turn ON and OFF.
  3. Reset coil is used at the end to run the program continuously.
  4. Comparator blocks are used to reduce the number of timers used.
  5. Program done in AB RSLogix 500 Software.
simple traffic light plc design
plc ladder diagram for traffic light control using timers
plc based traffic control system project
Below tabular column gives the Steps or sequence of outputs to turn ON.
traffic light plc programming
RUNG000 :
This is a Latching rung to operate the system through Master Start and Stop PB.
RUNG001 and RUNG0002 :
Starting the timer to turn ON first output West Green so east and west should be in red.
Comparators in Parallel rung are used to turn OFF East red after 15 sec. Timer T4:2 timing bit in parallel contact used to turn ON East red again in 5th  and 6Th  Step. (Refer Above Tabular column for clarification)
RUNG 0003 :
Turning ON North Red up to 3rd step using T4:0 and T4:1’s timer timing bit and comparator blocks.
Rung 0004 :
Turn ON East yellow for 5 sec using comparator blocks. (Step 2nd)
Rung 0005-0006-0007-0008-0009-0010 :
The same procedures followed to turn ON further outputs. ( Refer Tabular column for a sequence of operation)
RUNG 0011 :
Reset coil is turned ON using T4:2 ‘s done bit to restart the cycle from beginning
The program runs continuously until STOP PB is pressed
Conclusion:
The above-explained 3 ways traffic light control using PLC is for example only. It may vary from real-time. We can use this example program to understand the working of timers and comparator block function in AB PLC.
Author: Hema Deepan
PLC Sequential Motor Control
Process Control Loops
PLC Ladder Logic Concepts
What is Loop Checking ?
PLC Test Questions & Answers
Difference between PLC and Computers
Siemens Drum block for Sequencer Operation
Statement List (STL) to Find Highest Value
Studio 5000 Tutorial: PLC Programming for Digital Alarms
What is Seal-in Circuit ?
Mitsubishi PLC Timers with Ladder Diagram
2 Comments
  • Archimedes says:
    March 18, 2019 at 2:55 am
    If it is possible and ok with you, can you get back the pdf downloading for your articles?
  • esperant Mputu says:
    February 15, 2023 at 10:32 am
    I loved the explanation and the graphic, it helped me.
Create PLC Program based on Logic Circuit
What is a Relay? Types of Industrial Relays
Connect to the Siemens S7 PLC
PLC Brands Software Information
Two Hand Control Logic using PLC
Timers using Statement List (STL) PLC Programming
PLC Programming Best Practices and Tips
Compare Online and Offline PLC Programs
Database for each safety module
Global Acknowledgment Instruction in Safety PLC
PLC and MCC Panel Interface Design
Industrial Oven Control Application with PLC Controller
Real-time and historical SCADA Trends
What are Trends in SCADA?
Example Ladder Logic Diagram
What is Relay Logic ?
100 PLC Quiz Questions
100 PLC Quiz Questions : True or False
Difference Between Microcontroller and PLC
Track PLC Operating Modes
#2 PLC Best Practices – Track Operating Modes
Electrical Wiring Terminology
Three-valve Manifold on Remote Seal DP Transmitter
Purpose of Float Valve
What is a Float Control Valve? Types, Advantages, Disadvantages
Weir Diaphragm Valve
Diaphragm Valves Construction, Types, Stem & Bonnet Assembly
PLC program Permissive Circuit
PLC Electric Motor Interlocks
Difference between Stepper Motor and DC Motor
How to Remove Control Valve Stem Packing Procedure
The Replacement Procedure for Control Valve Stem Packing
Transformer Efficiency
