Reading: Timer during Motor Direction Change PLC Program
Inst Tools > Blog > PLC Tutorials > Timer during Motor Direction Change PLC Program
Write a PLC program where if the motor reverse direction PB is pressed, the motor stops for 3 seconds using a timer and change its direction.
Last updated: March 4, 2021 11:25 am
Write a PLC program where if the motor reverse direction push button (PB) is pressed, the motor stops for 3 seconds and reverse its direction. For instance, if the motor in clockwise (CW) operation and the counter-clockwise (CCW) push button (PB) is pressed, the motor is off for 3 seconds and then operates in the CCW direction, and vice versa.
Inputs & Outputs:Timer during Motor Direction ChangePLC Program description:Conclusion
Note the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs & Outputs:
I0.0: CW Push Button (Normally Open contact)
I0.1: CCW Push Button (Normally Open Contact)
I0.2: Stop Push Button (Normally Closed contact)
Q0.0: Motor CW
Q0.1: Motor CCW
T1: CW_delay timer
T2: CCW_delay timer
M0.0: marker 01 for negative edge detection
M0.1: marker 02 for negative edge detection
Motor in Forward and Reverse Direction
Forward reverse motor control diagram with timer
Also Read: S_PEXT Instruction
 Network 01
  • When the motor is in the CCW operation and the CW PB is pressed, the timer T1 is energized for 3 seconds.
  • If the stop PB is pressed at any time the T1 is de-energized.
Network 02
  • When the motor is in the CW operation and the CCW PB is pressed, the timer T2 is energized for 3 seconds.
  • If the stop PB is pressed at any time the T2 is de-energized.
Network 03
  • When the CW PB is pressed and the Motor CCW is not running and T1 is not energized, the set bit in the flip flop is energized.
  • If T1 is energized, the negative edge would energize the set bit in the flip flop after 3 seconds when the T1 pulse fails to zero.
  • When the stop PB is pressed, or the CCW PB is pressed, the reset bit in the flip flop is energized.
Network 04
  • When the CCW PB is pressed and the Motor CW is not running and T2 is not energized, the set bit in the flip flop is energized.
  • If T2 is energized, the negative edge would energize the set bit in the flip flop after 3 seconds when the T2 pulse fails to zero.
  • When the stop PB is pressed, or the CW PB is pressed, the reset bit in the flip flop is energized.
Note: it’s very important to keep the order of the networks.
For instance, if you replaced network #01 with network #04 the program would not be executed properly as we need.
Conclusion
  • In the begging, if any PB is pressed it should operate the motor in the dedicated operation.
  • If the other direction PB is pressed this would de-energize the running direction and energize a pulse timer which is detected by a negative edge in the other direction flip flop.
Author: Karim Ali Anwar
  • 4 Way Traffic Light Control
  • Extended Timer Logic in PLC
  • Pulse Generation using PLC
  • Jog Function in Motor Logic
  • Latched Motor PLC Program
#20 PLC Best Practices – Identify Critical Alerts
Your First Steps Through STL Language
How to Protect Siemens PLC using Password?
Connect to the Siemens S7 PLC
Steps in PLC System Design
How to Check Address Overlapping in Tia Portal?
Surge Protection Device
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
Parking Garage Indicator PLC Automation
Parking Garage Indicator: PLC Automation System
Midline output instruction
What is Midline Instruction in Siemens PLC?
Connecting Blocks in Functional Block Diagram
Connecting Blocks in Functional Block Diagram – Studio 5000
SCADA Multiple Choice Questions
Online and Diagnostics of Siemens PLC
How to Use Diagnostic Buffer for SIEMENS PLC?
Siemens PLC motor direction control example
Siemens TIA Portal: Motor Forward Reverse PLC Logic
How to do Force in GE PLC Proficy Machine Edition?
DCS Marshalling Cabinet
How to Select a Inductive Proximity Sensor
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Radiation Pyrometer Working Principle
Questions on Single Loop Controller
Single Loop Controller Questions
How to program a running hours meter in PLC
Allen Bradley Studio 5000: Motor Running Hours PLC Program
Reduce Control Valve Noise
How to Reduce the Control Valve Noise?
