Instrumentation engineering root cause analysis of failed target flow transmitters (TFT) at midnight.
| Category: | Instrumentation |
| Equipment Type: | Sensors |
Target Flow Transmitters Failed
The Author’s elation of solving a tough problem economically when he left the plant was short-lived; around 2 AM the night superintendent reporting the ammonia flow meters erratic readings gloomed him!
As he believes in checking the problem when it is fresh for accurate diagnosis, he rushed to the plant. It rewarded him! He found a profusely iced transmitter bottom portion.
He realized after few minutes of thought that the already low-temperature liquid ammonia throttled from around 6-bars pressures to 3-bars by the header pressure control valve cools to near 0o C, and hence the frozen iced transmitters’ bottom portions at night, stuck transmitter parts, and erratic readings – the root cause.
The bright sun during the day does not let ice form; hence, the turbine flow transmitters (TFTs) read the flow correctly during the day – the problem root cause
RCA Solution
After few minutes of thinking, he thought of adding a 300x300x6 mm thick aluminum sheet with a middle opening to let the head internals pass (previous problem).
It serving as a heat sink that would dissipate the cold and hold the head at a near ambient temperature high enough to prevent icing.
The crew did that by the next midday though the TFTs were doing fine. No disturbing calls that night let the author enjoy his sleep!
RCA solution benefits
RCA solution benefits are:
- Practically no cost solution restored the TFT readings reliably and durably and helped the plant realize the TFT’s expected benefits
The solution is least expensive and simple compared to the obvious solution of steam heating, which involves high installation costs, recurring excessive steam consumption, and steam leaks posed housekeeping costs.
Author: S. Raghava Chari
- Level Transmitters Zero Drifts
- Pitot-tube Replaced with Orifice
- Mechanical Temperature Indicator
- Pressure Transmitter Stopped Working
- Seal Pressure Instruments Problems
