Reading: Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
Inst Tools > Blog > PLC Tutorials > Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
In this article, we will learn the step-by-step procedure of connecting the Allen Bradley PLC and a PC (computer) in RS Logix 500 software.
Last updated: October 14, 2021 9:04 am
2 Min Read
In this article, we will learn the step-by-step procedure of connecting the Allen Bradley PLC and a PC (computer) in RS Logix 500 programming software.
PLC Training: Allen Bradley Course
Follow the below-mentioned steps to connect an Allen Bradley PLC and a computer using RS Logix 500 software.
Step 1:
Connect an Ethernet cable between PLC & PC and Enter the following IP address credentials.
IPv4 Address: 192.168.1.33
IPv4 Subnet Mask: 255.255.255.0
IPv4 Default Gateway: 192.168.1.1
Note: You may have different IP addresses based on your plc project.
Step 2:
Double-click the backup program to open it.
Procedure for connecting to Allen Bradley RS Logix 500 PLC
Step 3:
Then go to the “Comms” menu and select “Go Online”.
Go Online in RS Logix 500 PLC
Step 4:
If communication is established, the flag will be rotating as shown in the figure.
Allen Bradley PLC communication is established
Step 5:
Now the PLC program is online, do your activities like testing, troubleshooting, checking the I/O’s status, the configuration of a new instrument, etc.
Step 6:
After completion of your work with the PLC program, we have to take a fresh plc project backup.
Go to “File” and select “Save as” and specify the path to take backup of the PLC program.
Step 6:
Go to the “Comms” menu and select “Go Offline”.
Go Offline in Allen Bradley PLC Software
Step 7:
Go to the “File” menu and select “Exit” to close the application.
Exit the PLC Software
Credits: PLQP Instrumentation Team
  • Connect to the Siemens S7 PLC
  • Difference Between Industrial Computer and PC
  • Troubleshoot Allen Bradley PLC Logic
  • Communication between InTouch Scada and Allen Bradley PLC
  • ON Delay Timer using PLC
Why Use a Current Loop?
How to Program a Star-Delta System using 1 Button in PLC?
Establish Communication Between Two PLC Via PROFIBUS Protocol
Relay circuits
Distributed Control System Interview Questions
Establishing a Modbus Driver for SCADA Indusoft Web Studio
PLC Analog Input Card Resolution Effects on Accuracy
PLC Programming for Multi-Color Sorting Conveyor System
How to Configure PID Controller in Various Schneider PLCs?
FB Block in Siemens PLC Programming
Safety Door Interlock PLC Program
Forcing and Modifying PLC Logic
Yokogawa DCS Tutorials - Configuration of Analog Input (Transmitter)
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
PLC Program to Control Motor Speed using VFD Drive
Motor Speed Control using VFD and PLC Programming
PLC Automation for Product Weighing and Labeling
PLC Controlled Conveyor and Weighing with Labeling Automation
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
Allen-Bradley PLC
Interlock
Process Interlocks and Trips
Relay Wiring
PLC Program Paint Spraying
PLC Program for Paint Spraying
PLC analog output card
PLC Analog I/O and Network I/O
Optimal Control Systems
Parameter Optimization : Servomechanims
Cable Glands
Using of MCT instead of Cable Glands on the Cabinets
Complementary Split Range Control
What is Complementary Split Range Control (CSRC)?
What is Directional Control Valve (DCV)?
Ammonia Gas Detector Calibration
Ammonia Gas Detector Working Principle and Calibration
Types of PLC
Resistance Temperature Detector (RTD) Questions
Resistance Temperature Detector (RTD) Questions – 1
