Reading: Motor Stop Interlock for Changing the Direction PLC Program
Inst Tools > Blog > PLC Tutorials > Motor Stop Interlock for Changing the Direction PLC Program
Write a PLC program with interlock logic where you can’t change the motor direction unless the stop push button is pressed first.
Last updated: March 4, 2021 11:26 am
2 Min Read
Write a PLC program where you can’t change the motor direction unless the stop push button is pressed first.
Motor Stop Interlock for Changing the DirectionPLC Program descriptionConclusion
For instance, If the clockwise (CW) push button (PB) is pressed the motor runs in CW and if the counter-clockwise (CCW) push button is pressed the motor does not change its direction unless the stop push button is pressed first.
Note: the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs and Outputs:
I0.0: CW Push Button (Normally Open contact)
I0.1: CCW Push Button (Normally Open Contact)
I0.2: Stop Push Button (Normally Closed contact)
Q0.0: Motor CW
Q0.1: Motor CCW
Network 1:
  • When the CW PB is pressed and the Motor CCW is not running the set bit in the flip flop is energized.
  • When the stop PB is pressed the reset bit in the flip flop is energized.
  • If the CW PB is pressed while the Motor CCW is running the set bit would never be energized
Network 2:
  • When the CCW PB is pressed and the Motor CW is not running the set bit in the flip flop is energized.
  • If the CCW PB is pressed while the Motor CW is running the set bit would never be energized.
Conclusion
There is an interlock between the two motor directions that it is not allowed to toggle between the two directions unless the motor is stopped.
Author: Karim Ali Anwar
  • Siemens SCADA Tags
  • Motor Ladder Logic
  • Statement List Program
  • Connect a Solenoid Valve
  • Flexible IO Modules
Applications of PLC Programming in Bottle Filling Process
Siemens PLC Organization Blocks (OB)
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
How to Configure PID in Siemens PLC?
Introduction to PLC – Advantages of PLC
D Flip Flop PLC Ladder Logic
Shift Bit Register in PLC
How to Configure IP Address in Rockwell PLC?
Importance of Grounding Electronic Equipment
PLC Automatic Pedal Switch for Speed Control
Unknown Do’s Need to Know as a PLC Programmer
Factory Acceptance Test of PLC Panel
Factory Acceptance Test (FAT) of a PLC Panel
SFC Language in PLC Programming
Ladder Logic Example of Two Motors
Ladder Logic Example of Two Motors Interlinked with another Motor
Allen Bradley RSLogix 500 PLC Programming
how-a-plc-do-the-scaling-for-a-sensor
How a PLC do the Scaling for a Sensor ?
Components of PLC
Download Free Robotics Software
Step by Step Guidelines to Download Free Robotics Software
What is Temperature
What is Temperature ?
Siemens PLC Block Diagram
Programmable Logic Controller (PLC) Questions and Answers – 14
Monsoon Protection for Field Instruments and Junction Boxes
Information and Operation Technology
Information Technology and Operation Technology in Industrial Automation
Loop Splitter Theory of Operation
4-20 mA Loop Splitter
input-output-relationships-of-transmitters
Input-Output Relationships of Transmitters
Brass Cable Gland
How to Choose a Brass Cable Gland Manufacturer?
